Question about Zanussi FJS1225W Front Load Washer
Zanussi E30 problem
The error E30 appears after the machine tries to empty itself before starting the cycle. It has been intermittent, but now the cycle will not start at all. I have checked the filter and that is clear. The machine went through a complete cycle when it eventually started although now it just won't get past the pre wash emptying. Please can you help?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 174 Answers
Hi this can be caused by an earth leakage on the motor or more likely the heater it only needs a few mAmps to do this. you need an insulation tester to find which is the culprit. or try disconecting the heater to see if you can get the machine past the fill stage.
Posted on Jul 30, 2010
Tumble dryer displaying E90 error
do you have the machine's manual ? if you do try and find out what the message mean
Mar 23, 2012 | Zanussi ZDC5350W Electric Dryer
Zanussi zfw 1631 w skipping through programmes straight onto drain from wash. has been coming up with an error code e30
I'm going to take a stab at the filter on the empty pump being blocked.
I have tried to find an error code that matches for you and loads of forums talk about a possible blocked pump filter (Though I have seen a motor fault mentioned too!).
Try checking the filter out, it's the biggest cause of questions being posted on this site for washing machines
Jun 29, 2011 | Zanussi Washing Machines
E30 error message what does it mean, Cheers, Dave
E30 can be a faulty pressure switch,Heating element earth fault or the main P.C.B.(Programmer).Does the machine fill with water then empty.
Most common fault is the heating element,once this is replaced it should cure the fault.
May 03, 2010 | Zanussi ZWF1430W Front Load Washer
Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
Nov 04, 2008 | Zanussi ZWD1680W Front Load Washer / Dryer
Zanussi zwf1631w jetwash front loading washing m/c
had to call an enginer out, the problem was down to a faulty motor rota, to identify if e30 is this fault, rotate the drum (so the motor rotates) and try to start the m/c. if it runs ok you know to change the rota. hope this may help someone
Sep 12, 2008 | Zanussi ZWF1440 Front Load Washer
Washing machine displays E30
I have just had the same fault on a ZWF1631W machine. The machine overfills and goes straight to drain.
The level is controlled by an air pressure switch.
Remove the machine top, the switch is the round white plastic one. On mine, one of the wires had broken off. I had to replace the connector with .25" crimps.
If not, the switch may need replacing.
Sparks
Mar 07, 2008 | Zanussi ZWF1630 Front Load Washer
Error code e30
This error relates to the motor drive. Plug off the wall, open up behind, look for broken belt. If the belt is good its the motor brushes. Secure connections to the motor, look for loose wires.....
& pl rate if helped...............
Dec 04, 2007 | Zanussi FJS1225W Front Load Washer
The Washing Machine fills and then empties with not running a wash cycle
possible a pressure stat fault. some pressure stats have a too high water detector which turns on pump
Mar 27, 2007 | Zanussi F1245W Front Load Washer
Zanussi FJS1225W Front Load Washer Logo
704 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
