Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Cuts off starts up, when i let off the brake it cuts off. help
  • 15,935 Answers
Check the rider safety switch under the seat for proper operation.
A small jumper wire around the switch will tell you if it is indeed bad - if when you try again - it does not stall.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Jul 30, 2010
2010 subaru forester engine cuts out
consider this
when at the stop lights , you will have your foot on the brake as it will still be in drive or in gear and you don't want the car to move
a simple test is to apply the hand brake to stop the car and don't touch the foot brake
if it idles ok but cuts out when you apply the foot brake , replace the brake booster as it has a vacuum leak that is causing the problem
you can do this test in the garage by starting in neutral and allowing the engine to idle , then apply the foot brake
iof it dies it is the booster
Oct 01, 2016 | 2010 Subaru Forester
Hi all can anyone help diagnoise a solid brake pedal on a 54 reg espace
get to an accredited brake specialist shop as it indicates a problem brake booster problem or damaged brake master cylinder
Jul 11, 2017 | Cars & Trucks
My brake lights won't cut off when I cut the car off what can I do
Brake light switch is not cutting off either because it's bad or the pedal is not reaching the switch head when released. Check both starting with my last suspicion.
Oct 29, 2015 | Cars & Trucks
2000 mercury mystique when i brake to stop vehicle is cutting off
Sounds like a throttle body issue or idle valve problem. I would clean the throttle plate and idle valve
Jun 11, 2014 | 2000 Mercury Mystique
2004 ford fiesta zetec 1.4 14v diesel...cutting out!
engine cutting out is a sensor probably the timing sensor. needs replacing. as for braking would think you have a leak in the air line. even with the engine not funning you should be able to apply the brakes upto 3 times.. think this model is not fitted with abs like my sisters. when engine is running rev upto 3000 rev's if it starts to judder. also listen for hissing sound, if you find one repair it. most problems are down to a leaking air line.
Nov 29, 2013 | Ford Cars & Trucks
When i first crank the car it idles at like three or so then goes to zero and cuts of it does this a few times especially if i push the brake, i have learned to rev engine lightly and press brake and put...
Might be a leak on your brake booster (this will most probable give you a hard brake pedal or a "sucking sound " when applying brakes) also check the vacumm pipe from the engine to the brake booster. It might have a leak, so when you press the brakes it influences the air mixture.
Dec 14, 2012 | 2000 Nissan Maxima
2004 dodge ram 1500 5.7 hemi will not start unless brake is depressed then dies when you let the brake out. whats going on with this truck?
there is a cut out switch thats gone faulty to start the motor the brakes need to be on,, but the switch is faulty and is cutting the motor out now!
Aug 09, 2010 | 2004 Dodge Ram 1500
My 2004 dodge tratus wont start
dealer only factory immobilisor has cut in
Mar 15, 2010 | 2004 Dodge Stratus
Engine problems
ok,what was the fix to get running,I new to this problem of yours,
Dec 25, 2009 | 2001 Chevrolet Astro
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
69 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Mike Squire
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
