Front load washer door gasket keeps tearing purchased in 2006
  • adcarteriv Apr 06, 2009
    I was able to get the rubber boot to re-seat but I do not know where this spring thing came from. I need to know where and how to reinstall the spring for the rubber boot?
  • 145 Answers
This normally happens when clothes are not put in all the way and catch on the boot or the unit is off balance alot causing alot of stress and leaving bigger openings for things to get caught in.
Posted on Apr 24, 2008
Torn door gasket
it is possible for you to change it
it depends on where you are then could point you in the right direction
Feb 08, 2014 | Miele W4840 Front Load Washer
Water leaks out front center of door during the
Check the door gasket for any damage. A rip or a tear could be the cause of the leak.
Jul 20, 2010 | GE WSXH208A Front Load Washer
My LG front loading washer is leaking at the door.
carefully check gray door gasket fot tears/waves/stretching on outer edge. if so, replace gasket. be sure gasket and door glass are clean where surfaces meet.
Apr 28, 2010 | LG WM2688H Front Load Washer
Water leaking from front door
Check gasket for rips or damage. Replace if necessary.
Clean gasket after every use. Wipe with a bleachy rag. Use only HE detergent in small amounts.Dog hair, etc can get stuck in the gasket causing a small leak. Oversudsing can also cause leaks.
Apr 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
We discovered that our front door inner gasket is torn. Therefore, it's leaking during every load out of the door. I will be ordering the part but concerned that I won't be able to replace it. Do you...
If you've not done this before, expect to spend a lot of time. I've replaced these without disassembling the washer's front, but it's an arm-twisting experience to put the inner part of the gasket on, and to attach and tighten the clamp holding it. Haven't tried removing the front panel, if you can, do it - the job becomes much easier.
PS Check shocks and if the washer is leveled enough, door gaskets tear from excessive loads and excessive vibration.
Mar 29, 2010 | GE WBVH6240F Front Load Washer
Rubber ring ripped
You can buy and fit a new door gasket if you have the required mechanical knowledge
Take the power off , the top off remove the fitting band take off the old gasket and re-assemble in the reverse order
Jan 03, 2010 | GE WSXH208A Front Load Washer
Chenging the rubber gasket attached to kenmore H2e front load washer
The following link provides you with step-by-step instructions on how to change the door bellow:
This is not a difficult repair. Just follow the steps provided. If you have any questions, please let me know. I hope you find this information helpful.
Sep 02, 2008 | Kenmore Elite 45986 Front Load Washer
MAHW2000AWW washer front load washer leaks. Leaks from the front door.
Some of the new front load washers develop damaged hinges from too much laundry detergent..With that said, when you close the door..does it close easily or do you have to work it in? Try using your knee against the hings side to 'nest ' the door when you close it.. .. Also.. take a good look at the gasket material for any abnormalities or tears in it.. Hope that helps...
Aug 18, 2008 | Maytag Washing Machines
GE front load washer door gasket keeps tearing purchased in 2006
make sure that no sharp objects are on the clothes and lift out of the machine instead of pulling out of the machine when the load is done, there have been no issues of any kind on door gasket failures due to product design or part failure to date
Apr 24, 2008 | Washing Machines
Washing Machines Logo
257 people viewed this question
Top Washing Machines Experts
