Question about Maytag MGR5770 Gas Kitchen Range
My whirlpool sf32speed front left burner is not sparking. Should the wire/cable be replaced or can it be cleaned?
the dr
  • 447 Answers
SOURCE: problem with electric range
Most likely the switch has welded closed
Posted on Sep 28, 2007
  • 146 Answers
SOURCE: electric start gas range
You either have a short in your electronic ignition or the ignition board is defective. Check the wiring to the ignition board for shorts. also check and make sure you ignitors are well grounded.
Posted on Dec 21, 2007
  • 217 Answers
SOURCE: Igniters do not spark on one side of cooktop
Is the gas able to flow freely through and out of the bad burners? Sounds like they may be clogged somehow
Posted on Jul 11, 2008
  • 12 Answers
SOURCE: magic chef range surface burners not always lighting now. Random
sounds like a preasure problem
If you need further help, reach me via phone at https://www.6ya.com/expert/jeremy_075aa344198c3329
Posted on Feb 20, 2009
  • 1244 Answers
SOURCE: Whirlpool Super Capacity 465 Electric. Left Front
there are 3 screws under the front of the top with the oven door open actually there are 6 screws but only 3 you need to remove to raise the glass top up!! to service the burners
Posted on Jan 20, 2010
One burner won't spark when another is aflame. Multi-ignition BlueStar 4-burner range.
I would check that the plates are on correctly. Make sure they are aligned and sitting properly. Sometimes they move while cleaning and give you a bad ground connection for the spark.
Feb 15, 2016 | Kitchen Ranges
My Whirlpool kitchen Range is Model # SF 3300 EK40, and the left side Igniter (IGNTR Surf) no longer sparks when either of the left side top burners are turned on. Instead, the right side Igniter sparks,...
Hi
You are right it is the igniter that is bad and should be replaced. Please check this video on how to replace it:
Hope this helps...please post back for further assistance.
Daniel
Feb 14, 2011 | Whirlpool Ovens
My whirlpool gas cooktop on sparks on left front burner. Model scs3014gq1
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Apr 01, 2010 | Whirlpool SCS3014 Gas Cooktop
Whirlpool gas cooktop will only spark on left front burner
i made this video to help you troubleshoot kitchenaid and whirlpool cooktops
Apr 01, 2010 | Whirlpool GLT3615 Gas Cooktop
Infinite switch sparking!!!!
You have a short somewhere between the switch and the burner connector. Probably a wire's insulation has worn away or melted and is allowing the wire to contact the metal housing somewhere. You will see arc marks wherever the short is located. Look carefully where the wire passes through any holes or where sharp turns are encountered.
Aug 12, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Whirlpool stove top- two problems. 1) burner is not burning hot, low flame 2) igniter on different burner doesnt work, no spark at that burner.
Hi
If the burner is not burning hot, and there is a low flame then this is often a pressure regulator problem. Most often the regulator is found where the gas line enters the gas range. I have a picture of what the flame characteristics should look like. If the igniter on different burner doesn’t work, and there is no spark at that burner then you will have to check the same items as mentioned above. This is a typical spark module wire diagram.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 08, 2009 | Whirlpool GLT3615 Gas Cooktop
Electric start gas range
All burners apark at the same time. If they don't light then electrodes (where the spark jumps off of) are either worn out or cracked or there is dirt in the area of the sparking. Clean thoroughly to diagnose this correctly.
Nov 27, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Two burners wont ignite
Sounds like the electric sending unit for the right burners is not working. Do you hear the cliking noise on the right side when you turn the knob to LITE? If not then you need to replace the electric sending unit, they are located under the knobs, they are a smal square box that goes on the switch valve rod, they have tow wires on the side, just unplug and lift, and look for greasse or anything that might interrup contact, you might be able to use the same ones, or just replace with new ones....Good Luck
Eddie Rentas
Tupper LAke NY
Jul 14, 2008 | Cooktops
The front left burner on the stove does not ignite.
you have one of three problems. first check to se if it's sparking when turning on, if not try cleaning sparker with a small wire brush, second try turning on another burner and see if it sparks then, if it does the switch is bad (under the knob), third is to replace spark module. ( on the back of unit small blu, white, box with four wires going up to cooktop)
Apr 03, 2008 | Kitchen Ranges
Burner won't light
Clean the gas nozzle w/small wire are located at the back of the gas cook top /shut off the gas clean small gas nozzle clog / w moisture /rust dust and any foreing material.
Dec 19, 2007 | Thermador SGS36GS Gas Cooktop
Maytag MGR5770 Gas Kitchen Range Logo
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
