I need to know how to convert a 15 amp thermofax to a 12amp , 3m thermofax
    Problem Solver:
  • 5 Answers
I can do it. U2thermo@yahoo.com dave
Posted on Jun 10, 2014
Any luck on this? I'm in the same boat.
Posted on May 28, 2011
  • dave kelly Jun 10, 2014
Where can i get a 12amp 250v fuse for my LG front loader
10 or 15 amp will do, purchase from any electrical outlet. Best to use 10 amp & investigate why fuse blew.
Dec 19, 2013 | LG Washing Machines
I have a 45 EGA 3m Thermofax machine that will not shut off. How do I fix this problem Please and THANKS?
that model needs a conversion kit it was common for that model to do that and once u convert it 8it will no longer be a fire hazard
Mar 12, 2011 | Office Equipment & Supplies
Gemini GA 2000 both 4 internal fuses keep blowing off.2 8amp and 2 12amp.Please what course this problem.
the power unit that feed the Amp is short this is why the fuse burn
its an hardware issue
if you want to fix the Amp let me know
ecrdn@yahoo.com
Jack
Oct 14, 2010 | Gemini Sound Products P07 2-Channel...
I have 2 -4550 and 2- 9750 3m thermofax machines. I need part that makes the machine shut off. the contacts i believe, where can i purchase these parts.
Hello, I rebuild these machines. I dont think you need any parts to fix your machines. I find the reason for machines not shutting off is the machine needs the drive clutch and transmision needs cleaned. If you want to talk call 614-580-9676. Im eastern time zone.
Dave
Aug 26, 2010 | Office Equipment & Supplies
3M model 45CG Thermofax Machine how to change bulb?
On either side of the drive table are single wires that go to each end of the lamp. Remove one screw on each side of the snap-in levers. Turn red handle on left side of unit as you are looking at it. Lift up each lever (screws you just removed) carefully. You can slide the entire unit out from under the clear plastic, then you will be able to see the lamp. It is a long halogen lamp. Do not touch the lamp with your fingers!! The oil on your skin will cause that area to overheat, boil, and blow. Disconnect wires on each side. Loosen bracket screws (2 on each side). Lift lamp out of heatsink tray by porcelain ends and slide out. Replace in reverse order. REMEMBER: DON'T TOUCH LAMP WITH FINGERS. USE GLOVES OR HANDLE BY PORCELAIN ENDS. GOOD LUCK!!
Apr 05, 2009 | Office Equipment & Supplies
Please help ! 1999 BMW 3M convertible
I had a similar issue. I took it to a dealership and they gave me the code for free.
Apr 01, 2009 | 1999 BMW M3
Thermofax machine repair
Not really sure what you are asking? Is it a thermofax that is making noise that you use to make transparency with. Or is it transparency making? I never worked on a transparency maker in 20 years of office machine repair... What is it? Is a old machine? If it is that old it may be time to replace it....
Mar 30, 2009 | Office Equipment & Supplies
3M Projection Panel
Based on your post/description, I will assume that you would want to connect a PC to a Projector.
For a 3M DY-0205-1002-9, pls contact:
3M Customer Information Center
Hale Avenue Business Center
3M bldg. 506, POCS Destination Code 0444
835 Hale Ave. North
Oakdale, MN 55128 Fax: 651-736-6320
or try
3M Visual Systems
1-800-328-1371
(Fax) 512-984-5105
Internet: www.3m.com/presentation
Email: OHP - presentations@mmm.com
EPS - techsupport@mmm.com
Should you opt for a replacement, you may want to consider DVI to VGA Analog Video Cable or similar products.
Alternately, you can use a converter box that will accept VGA inputs but whose output is DVI-D compatible. A fine example is VGA to DVI Converter/Scaler but of course any comparable brand/model should also work.
Hope that these be of help/idea. Pls post back how things work out or should you need further information.
Good luck and kind regards.
Dec 23, 2007 | 3M Projection Panel 6400 Multimedia...
319 people viewed this question
jasbo
jasbo
