Question about HP LaserJet 1300 Printer
Sent a paperclip through the printer, now prints with a dark streak down the paper. Tried replacing the cartridge, no luck. Any ideas?
    Genius:
  • 1,478 Answers
There are a few possible reasons that can cause this problem, first, the fuser assembly may be damaged or at the end of its life. The solution is to replace the fuser assembly. Repairing a fuser assembly is generally not recommended because the fuser is considered a consumable printer part and not worth the time or effort to fix. Second, some toner/ink may have spilled in the printer. If so, you'll need to clean it out.
Take care.
Posted on Jul 30, 2010
Wen i print, there's a dark streak down the left edge of the paper. Hw do i solve this problem?
Hello, this one is fairly simple to diagnose, Change the toner cartridge, does the problem go away? if yes the toner is the problem. If the problem remains it would most likely be the fuser, in which case it would likely need servicing and the fuser replaced.
Jan 14, 2011 | HP LaserJet 1020 Printer
HP Laserjet 6L Dark Printing
Check your Toner, and also the thermal roller of the printer..
Thank you
May 29, 2008 | HP LaserJet 6L Printer
I get a dark streak down the left hand side of every page.
It is either toner cartridge or fuser.
Print a few sheets of anything.
While printing, open the cover and pull out the toner.
Look down at the paper. If you see a dark streak, you have to replace the toner.
If the page is streakless, replace the fuser.
Jan 04, 2011 | HP LaserJet 6mp Printer
How do i stop my printer from leaving ink streaks down the right side of my pages?
I was going to suggest removing the fuser and looking at the rollers, but on this printer it's a major operation.
Instead let's run the half test. Put paper in the manual feed tray(tray 1). Print to the printer. When the sheet of paper gets pulled about 3/4 of the way in, open the top cover. Pull out the toner cartridge. Look down at the paper. Does it have a streak down the right side? If yes, replace the toner, if no, have the fuser replaced.
Oct 21, 2010 | HP LaserJet P2015dn Printer
The left hand side of each page prints some streaky dark lines. I've tried to clean it and put it in cleaning mode but nothing works. Help please!
Remove the toner cartridge. Turn it over and slide open the gate that covers the drum. Do you see streaks on one end of the little colored cylinder? (drum)
If so then the streaks are coming from the cartridge.
90% or better of the time, especially on HP's the print quality issues are coming from the cartridge.
Good Luck and Thank You for using Fixya.
May 13, 2010 | HP LaserJet CP1515n Printer
Dark black streak down the middle of the page
sounds like your cartridge is leaking. I'd try replacing the cartridge
Apr 30, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Leaving black streaks down paper? Ink cartridge
If this started after cartridge was replaced, then it is probably defective.
Take the cartridge out and take a look at the print head. Clean the print head.
Put the cartridge back in
Try and feed paper (not printing anything on it, if you can not get it to just feed paper, print a blank page) and see if it still has lines. If so, you are probably going to have to clean ink from inside the paper feed area. If not, try using it for a while and if it starts again, get a replacement cartridge. You might want to save some of the bad prints to show the clerk and try to get the new cartridge under warranty.
Mar 18, 2010 | IBM Infoprint 1612 Express Printer
How do i clean the rollers they are leaving streaks on the paper
Hi, after you power on and printer is ready to use, enter the setup, scroll down to maintenance, click on this maintenance and wait for minutes for the printer to do all necessary cleaning on the printer that you need.
I wish you best of luck.
Dec 28, 2009 | Brother HL-4040CN Laser Printer
Horz. streak approx.3/4 down on each page I print
Sounds like some of the magenta toner is left behind on the drum. The only way to fix it is to get a new cartridge.
Dec 09, 2008 | Xerox Phaser 7300DN Laser Printer
Dell A960 printing blank pages
I just sprayed windex on bottom of cartridge several times and wiped with paper towel until dark streak of black appeared. Then I dried off cartridge and replaced. It works now. Must have been clogged.
Nov 18, 2008 | Dell A960 All-In-One InkJet Printer
HP LaserJet 1300 Printer Logo
23 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
