Question about Refrigerators
No water but ice is fine
My ice dispenser works but no water will come out Problem - GE GSL25JFPBS Side by Side Refrigerator
I have a Kenmore 74962, 19 CU Foot fridge, the ice maker works fine, but the water dispenser does not. I already replaced the filter in the bottom of the firdge. When the water dispenser is engaged, it still makes the sound like it used to when it worked, but no water comes out.
  • gibsonjunkie May 23, 2008
    I also got ice but no water. Tried a new filter - it is obviously getting pressure because when I twist it off water sprays out for a second, but no water gets to the door dispenser. I replaced the main solenoid valve kept the water line to the dispenser disconnected and activated the switchand got water, so I know that water is passing through that far, but I can't get it to activate through the dispenser. Is ther another valve in the door?
    Genius:
  • 1,073 Answers
Remove the filter and reinstall , it may not have seated into the filter housing it will take a little while to fill the filter cartridge as you hold in the water paddle
you also may have a water valve problem, something in the water valve that goes to the water in the door that is not allowing the water to come through the valve
Posted on Apr 24, 2008
When the paddle is released water /ice keep coming out until the freezer door is opened GE GSL25JFPBS Side by Side Refrigerator
the return spring on the paddle has probably broken keeping the micro switch on and dispensing,or the dispenser board is defective causing this
Apr 07, 2013 | GE GSL25JFPBS Side by Side Refrigerator
Ice maker not working on GE side by side
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
iyooyi76
Jun 01, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Ice maker works, dispenser does not..water works fine
Yes, Just make sure you have the plug out of the wall! Sea Breeze
Jun 15, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Ice and water not dispensing
check the water solenoid in the back of the unit where the water line hooks up. sounds like the solenoid is not powering to admit water to the ice maker or dispenser.
Jun 01, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Water dispenser wont work, the ice dispenser works fine. And the ice maker is working.
Hi, Try these out.
  1. Clean the drain tube
  2. check refrigerator and ice-maker for level
 please rate my solution..
Apr 10, 2009 | GE GSL25JFPBS Side by Side Refrigerator
turn freezer side to zero for 1 minute press water dispenser
Mar 29, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
Water dispenser not working, ice is working
The mother boards go all the time on these from what I read. I had the same problem. It is located under the silver plate in the back of the frigerator.
Mar 23, 2009 | GE GSL25JFPBS Side by Side Refrigerator
GE side by side refrig. quit dispensing water
take out the bottom bins in the refrigerator and remove the cover thats on the back for the light and then use a hair dier and thaw out the coil of tubing until the ice melts.
Refrigerators Logo
368 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
