Question about Neso Technology Pixo A700 17 in. Flat Panel LCD Monitor
When plugged into my PC, this monitor tells me "Out of Range."
When I plug this monitor into my desktop PC, it tells me "Out of range."
I'm not sure what this means, but if it's a resolution thing, I've tried reducing it, in the computer, all the way to 800 x 600, and it still tells me "Out of Range" - the monitor keeps displaying a 1360 x 768, despite most definitely not being what I set the computer to, so I'm not sure what to make of that.
My mom mentioned something about it possibly being the wrong type of monitor, and that if I went into the BIOS, it'd be able to tell me how to fix it by switching what type of monitor the computer was trying to output to, but there's no mention of monitors that I can see in the setup thing. (I'm pretty sure that's the BIOS. You press, like, F11 to get to it early on in the computer's booting? Or was it Delete... but you get there while the computer is booting. I just have **** memory.) It could be that I don't know what to look for, or something, but I don't even know if this is really something to consider.
The computer is running Windows 7, with NVidia GeForce 6150SE nForce 430 for a graphics card; I'm baffled by this. It could be that the monitor just doesn't work or something, but it turns on and everything, so I don't want to just ditch it.
  • 11,361 Answers
It can be failure inside the monitor, but try it with another PC first.
The possibilty can be poor DC in the power supply which will be the first thing to check or failed EPROM which nothing you can do unless you have the way to reprogram it.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Posted on Aug 01, 2010
Beeps out of range when there are batteries and the ac adaptor is plugged in
Transmitter is in range and plugged into the wall and still keeps beeping non stop. Can you tell me what seems to be the problem?
Jul 01, 2011 | Sony 900mhz Baby Monitor
"out of range" when connecting ps3 -> benq t221w
It display out off range because the PS3 is feeding the monitor with higher resolution that the monitor cannot suppoert, try setting the PS3 to the lowest resolution first and go up from there.
May 18, 2010 | BenQ T221W Monitor
Out of range no display
Try pressing F8 when starting the PC, but BEFORE Windows starts loading. In the menu, select Safe Mode. Windows now startd with a very low resolution. You can right0click your desktop, select properties, then the Settings tab, and drag the reslution slider all the way to the left in Windows XP, or for Vista and 7, rightclick the desktop, sleect the lowest option, go to screen settings, and drag the slider all the way to the left.
After that, click OK, then restart your PC. Now you can try to increase the resolution step by step, and if it goes wrong start in safe mode and set it back a step. That way you will achieve the highest possible resolutioon (and better image quality)
I hope this helps,
Yannick.
Dec 07, 2009 | Princeton Digital VL173 Monitor
Princeton Monitor is "out of range"
The monitor is not getting a video signal. This is probably an issue with your computer. It could be a memory, hard drive or motherboard issue.
Make sure you are getting power to the pc (fans running, hard drive spinning...etc). Then check your memory. Try switching memory slots, or try different memory.
Turn on computer and see if you hear any bios beeps.
Try a different hard drive if you have one.
Good luck,
Hank
Aug 04, 2009 | Princeton Digital VL1916 19" LCD Monitor
Showing message out of range
Your monitor settings within windows are set too high for the monitor to display... When computer first boots.. be ready and press the F8 key...
Enter safe mode.. Reset the display properties in control panel to 800 by 600 for a start. Setting the resolution too high past the monitors ability will give you that message.. Most monitors are able to display 1024 by 768 just fine.. Out of range.. means the display settings within windows are out of the monitors range of ability to display the screen resolution you have set... Good luck!!
Feb 18, 2009 | Dell Dimension 8200 PC Desktop
Out of range external monitor
The max resolution supported by that LCD HDTV is 1366 x 768. If your screen resolution in XP is set higher than that, you'll run into issues. Reduce your screen resolution first, then run the nVidia multiple display setup.
Jan 28, 2009 | IBM NetVista PC Desktop
Relisys Monitor model TL528A - Plug it in, screen is blank panel light is yellow. push ON button and I get a 5 second message stating: OUT OF RANGE HS: 53.5 KHz VS: 84.8 HZ WORK RANGE ...
It normally means that you have connected the monitor to a computer whose resolution and frequency are beyond the range that this monitor are capable of.
To fix this, you can do one of two things: reconnect the old monitor and reduce the resolution to 800 by 600, which every monitor can handle and then reconnect the new monitor and change the resolution settings again. by default, Windows will restrict you to only settings that the monitor can handle. The second option would be to start your computer in safe mode (F8, just before you get the windows screen during boot). and change you monitor settings that way, rebooting afterwards.
Jul 10, 2008 | Computers & Internet
New computor, hp slimline new monitor soyo 19 inch
You need to lower the resolution into the monitor's range. 1024x768 is the usual safe one. Now, if you could tell the operationg system you are running it would be a little easier to help. I'm going to assume it's xp for now.
You need to plug a different monitor into the computer, preferably a CRT, as they support a HUGE range of resolutions. Then you schould be able to see the screen.
Right click on the desktop and click properties.
Click on the settings tab on the far right of the new window.
Now you should see a resolution dropdown.
Change it to 1024x768 and click OK.
Go ahead and plug the LCD back in and you should be good to go.
Mar 26, 2008 | Gateway FPD2275W LCD Monitor
H.V. frequency over range
I have a philips 105s5 crt monitor.First problem is vertical dead.Replaced this ic .Power ok but screen appear" H.V frequency over range" .How to solve this problem.Please suggest me.
Dec 23, 2006 | ViewSonic G70F 17'' Monitor + Wyse Winterm...
Neso Technology Pixo A700 17 in. Flat Panel LCD Monitor Logo
137 people viewed this question
Top Neso Technology Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Neso Technology Computer and Internet Expert? Answer questions, earn points and help others
