Question about Dishwashers
Soap dispenser will not open during cycle. - Dishwashers
  • 909 Answers
Hi, with dishwashers, there are two methods that allow the dispenser door to open. 1)With the electronic type, at a certain time in the program, a solonoid will be given the electrical signal to open up the dispenser door. Whereas 2) on various other types.the dispenser door will open on a thermal signal. This signal will only take place if the rotors top and bottom are turning properly. So, remove the top and bottom rotors and carefully clean them so none of the holes are blocked in any way.(If they are equalibrium is not reached and the rotor/s will not turn and will then not disperse hot water onto the dispenser) which in turn will not allow the door to open. Please note, your heater must be in operation for this to work.
Posted on Jul 30, 2010
Soap dispenser will not open during was cycle.
Probably a faulty solenoid on the dispenser. Not replacable new dispenser needed
Jan 20, 2010 | Dishwashers
Our dishwasher won't release the soap during the cycle.
We discovered there was a dish blocking the soap dispenser during the cycle. Once moved over, the soap dispenser opened.
Dec 13, 2009 | Frigidaire Dishwashers
My soap dispensar inside does not open during wash
its just a bad (failed ) dispenser. replace it . this should correct problem . mm
Dec 07, 2009 | Washing Machines
Soap dispenser does not open during cycle
Had similar problem. Water was not hot enough. Check your manual for proper water temp.
May 29, 2009 | GE Dishwashers
The soap dispenser opens but the soap is not dispensed and the dishes do not get cleaned. Can you help?
Make sure that there is nothing blocking the soap door from opening fully when the dishwasher is shut. This happened to me and I also thought that the soap door was opening during the cycle when it actually only partially opened during the wash and then popped open fully when I opened the dishwasher at the end of the cycle. So some, but not all, of the soap was used.
Dec 28, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Soap door won't open during wash cycle
its either the dispenser or the timer/pcb.
Mar 01, 2008 | Dishwashers
Dishwasher soap dispenser won't open during cycle
I had the same problem with my GE Adora. The dishes were getting cloudy and the soap dispenser would not open. Turns out the hard water deposits were causing the soap dispenser to stick shut. I purchased and used Dishwasher Magic which is a dishwasher cleaner designed to remove limescale, rust and buildup. I used as directed and now my dishes are sparkling and the soap dispenser pops right open.
Oct 26, 2007 | Dishwashers
GE Monogram DIshwasher
Before taking anything to bits, check you aren't just loading the machine in such a way that something (for us, it's usually a frying pan) is stopping the soap dispenser from springing open all the way. A.
Apr 21, 2007 | GE 24 in. Monogram ZBD6880KSS Stainless...
Dishwashers Logo
13 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
