Mi samsung mp3 is frieze,I plug in the computer for erasethe music already has,but nowin the mp3 screen sad conected charging what can I do? thanks. the model is samsung YP-TPJ.
  • 871 Answers
Hey adritukis
try to disconnect the battery of your mp3 player see if it will work,
try also to do a hard reset on your player. maybe this will help.
i am not sure if you got the model correctly, however, as what i have said. this will work with all types of players which have freezing problems.
you may want to check the firmware for this also because there may be some updates.
try holding the power button down for about 15 seconds. that is the hard reset for some other players
some players also has hard reset by holding all the buttons. try this too.
if ever my solution has helped you solve your problem.
dont forget to rate.
thanks
Posted on Apr 24, 2008
    Genius:
  • 3,422 Answers
Try reseting the player i believe this will fix the problem.I'll let you know if there is a manual available for your model.
  • Priya darshan Apr 24, 2008
    hold (MENU) and (A<->B/o) buttons and your mp3 will shut down.This is the way it will reset ur mp3
    If that doesn't help then just connect it to your computer and copy all the files off it. (The same way you put song ONTO it, except the other way round) but if you have all your songs on your computer then there would be no reason to back it up.
    Because it's getting more frequent, I think it may be the memory that is corrupt. If the player's relatively new, it might still be under warranty so you could just take it back to the retailer to have it repaired or exchanged .
    HOWEVER, the memory might not be corrupt, it might still just be a few files. Trying coping everything off it and then just copy a fews songs back on to it and see if they all work.
    Goodluck..
Se apago mi sony nwz s545 y oquiere prender como ago para restablecerlo
This worked on me: I just plugged the USB conection to my "Phillips DVD player with USB conections" insted of plugging it to my PC. So I just played a song on my DVD player and when I stopped the song, turned off the DVD player... I unplugged it from the USB port and !!!!! appeared again what I was waiting for so long: The welcome screen "Every moment has its music." plus the "Creating Library" And finally I said "THANKS GOD!"
*** I tried many ways to find a solution (pressed the RESET buttom, charged the battery... but nothing happened... my screen was totally black = OFF).
Well.. I hope this is helpfull for all of you.
Jan 04, 2011 | Sony Network Walkman NWZ-S545 Digital...
My mp3 player will not take downloaded music- it comes up with an format error message on the unit. does this mean the unit is not formatted?
try to convert the musics using this program link if do not work conect to the computer then go to mi computer then rigth click on the mp3 icon then chose format
if work please rate my solution like very helpfull and vote me thanks
Dec 28, 2009 | Bell Technology Techsolo Slick Stick MP3...
I got a Nextar MP3 player model #MA797-801, but it doens't work on my Windows Vista, but it should. I'd plug it into my computer to charge, but it hasn't, but I was able to put music on it. However, the...
I have the same model - you have to press and hold the Play/Pause button (the button to the left of the 4-way button) until the unit turns on.
It took me awhile to figure it out.
Jul 10, 2009 | Nextar Audio Players & Recorders
My mp3 doesnt connect into my usb it just disconnects and starts to charge can you help me
I assume from your description that either you are running a version of Windows older than XP/2000 or you need a special driver. Here is a link for the driver(s) you will need. Just enter your model number and select your version of Windows. Download and run the file and you should be up and running shortly.
May 30, 2009 | Samsung YP-U3 MP3 Player
SAMSUNG U3 MP3 PLAYER HELP!
sir kindly check the connector and clean the usb port using lighter fluid...thankksss and hope too help you
Nov 28, 2008 | Samsung YP-U3 MP3 Player
Help please
did you use the safely remove hardware button on your taskbar
if not the computer was still writing to the device when you removed the usb connector and damaged the software on the device
my sis did that and killed a very expensive Mp3 player
(iPOD video 40gb)
its toast
Jul 25, 2008 | Insignia NS-DV2G MP3 Player
MP3 will not stop charging
It could be the usb cable,so shop around for another usb cable for it, if that doesn't work take it (The mp3 player) back to best buy and tell/show them what happened.
Jun 18, 2008 | Samsung Yepp YP-P2 Digital Media Player
Samsung mp3 player YP-F1 screen diplay won't turn on-even when fully charged
I have samsung yepp YP F1. After full charge, it only appear "loading" and somebody told me to reformat the unit. My question is how do i reformat the unit. thanks - - ronnie
May 09, 2008 | Samsung Yepp YP-F1X MP3 Player
32 people viewed this question
 Grubhead
Grubhead
