Question about Cameras
I just got my Xacti CS1 and after I shot a couple of test videos, I checked the playback. On the camera screen, playback is flawless, it's quite great, however, when I play the videos back on my macbook in quicktime player, the video is choppy. It will skip a couple of frames every second. It just freezes and then all of a sudden it's a completely different frame like the video was cut and spliced together. What's wrong?
  • 6,826 Answers
Http://us.sanyo.com/dynamic/product/Downloads/VPC-CS1_OM_English-6223243.pdf
p.60 of the manual describes different recording modes with lower resolutions (1280x720) pixels and lower frames per second (30fps).
I would choose from the menu to record in a lower resolution and lower fps mode so that the quicktime program can display the video at a good rate for you.
I don't know what kind of macbook you have, but usually such problems are due to the older macs not having enough speed to display high definition video with all its data all at once.
I used to have problems a few years ago, before i upgraded my hardware on PC's, with choppy video that was High Definition.
Posted on Jul 30, 2010
Testimonial: "Thanks a lot, this helped! :D "
Can i take video in a dark room
Unfortunately, the Sanyo Xacti PD2 only supports a flash for still shots and dose not have a lamp light for the video side of the camera. You'll have to provide your own source of light for good quality video in a dark setting.
Hope this helps.
Feb 09, 2014 | Sanyo Xacti VPC-PD2 Digital Camcorder - 2"...
Viewer screen is white, i can record and playback but the screen is white, its an xacti waterproof 6mg model
hi Usually white screen problem is defective lcd unit. your local repair shop would charge $45 to 75 depend on what they want to charge. Thanks and best regard!
May 24, 2011 | Sanyo Xacti VPC-T700 Digital Camera
Each shot I take horizontal lines appear on the screen this has only just started happening it is a Sanyo Xacti VPC 560EX
This is due to defective lens parts, Lens related parts need to be exchanged. So your camera require service (repair) as you won't be able to fix this problem
Have a nice day Rating the solution is highly appreciated
Mar 06, 2010 | Sanyo Xacti VPC-S60 Digital Camera
The pictures on my camera come out fuzzy most of the time but not always. How do I fix this?
Take a couple of test shots with your camera mounted on a tripod or a very firm surface. Are the pictures better?
Sep 26, 2009 | Sanyo Xacti VPC-S770 Digital Camera
Computer cannot read and play the .mp4 video files from my Sanyo XActi CMOS 1920X 1080 .Is there a software I can download from the net?
Yes.
This is what the Sanyo CG9 Users Manual has to say about viewing videos taken with the camera:
"About video clip files recorded with this camera
You can use Apple’s QuickTime to play back video clips on a computer.
Playback may be possible using other software that supports the ISO
standard MPEG-4 AVC/H.264 (AAC audio)."
There are many ways to view mpeg-4 videos, but the one that is recommended for your camera from the CG9 support webpage is apple's quicktime available from apple here.
Jun 06, 2009 | Sanyo Xacti VPC-CG9 Digital Camera
Xacti camera shoots stills with a grid pattern
The grid pattern is in the settings of the camera, its designed for architecture photography, you can remove it in the menu.
Jan 08, 2009 | Sanyo Xacti VPC-S60 Digital Camera
LCD Screen Stays Black
Had the same problem. It nearly drove me mad, however, the fix seems quite simple. The screen in playback mode seemed to be fine but if I swithed to record or photo mode I just got a black screen. I could see some pixel movement so I figured the screen was okay and that the iris was the problem.
Anyway, to fix it I simply gave a few sharp taps on the camera body near the lens. This unstuck the iris and I was greeted with a clear image in the LCD viewfinder. The camera now works fine.
By the way, this seems to be a fairly common problem with a lot of the different models and not just limited to this one.
Hope this helps.
Nov 25, 2008 | Sanyo Xacti C6 Camcorder
Dvr4-alert full screen playback
That's because this is a quad. It compresses all 4 video feeds into 1 file. When you play it back, it decompresses the video and shows you each camera. Playback through this unit is the only way to see 1 camera at a time.
To be able to copy 1 camera shot to a DVD, this is what you need to do: You need to have a TV with Video in and Video out jacks.  Connect the Quad to the TV Video in jack and connect the TV Video out jack to your DVD Video in jack. Playback a single camera shot on the quad to the TV and hit record on your DVD. - The DVD will record whatever is shown on the TV.
Oct 26, 2008 | Home Security
Need codec (?) so that I can playback video files taken with my Xacti C40
I use VLC from www.videolan.org that is a free and open source software.
May 12, 2008 | Sanyo Xacti C40 Camcorder
Cameras Logo
151 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
