Question about Kodak Easyshare M753 Digital Camera
When you turn on the camera the screen is completely black, shutter is completely open, Camera is fully charged
  • 906 Answers
Link
You may want to browse your camera's manual first for some primary trouble shooting. If still cannot find anything, kindly refer this to your nearest Kodak Help Center.
God Bless
Posted on Jul 30, 2010
When i turn the camera on and switch to picture mode the screen is completely black, and if i take a picture, the picture turns out completely black
Very easy to fix for your camera. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Recommend Fix 5A in the link, by gently flicking with your fingertip as described in the article.
Dec 22, 2010 | Canon PowerShot SD1000 Digital Camera
Viewing screen is completely blank and will not take pictures
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Dec 26, 2009 | Canon PowerShot A620 Digital Camera
My Canon PowerShot SD1000 shoots completely black pictures. The lens is open and there is no damage to the lens or the screen. The battery is fully charged and I've even tried a different memory card. It...
Nov 06, 2009 | Canon PowerShot SD1000 Digital Camera
When I turn on my Canon PowerShot S2 IS camera and set it to shoot mode, the screen is black. A while back, I was able to get the screen to show by toggling with the camera and constantly turning it on and...
For your model camera, pay close attention to the "UPDATE" at the beginning of the above linked article. Who knows, maybe Canon is actually fixing this problem?
Oct 15, 2009 | Canon PowerShot S2 IS Digital Camera
Canon Powershot A510 black screen when taking photos
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 20, 2009 | Canon PowerShot A510 Digital Camera
My lcd screen is black
hi there guys, if the screen is black and the camera takes black pictures, then you should look if you are getting a on screen display on camera mode. if you are then i would say one of two things, either the shutter is not opening or the ccd( electronic imaging device) is not functioning. to check the shutter you should look into the lenses centre part and check for movement from the shutter to see if it is opening.
Jun 06, 2008 | Panasonic Lumix DMC-LZ2 Digital Camera
Viewfinder Blank but shows information
From your description it would seem that the shutter component in your lens has failed. Although it is a little strange because the two symptoms you describe are not usually seen at the same time. The fuzzy pictures with streaks on them is a result of a shutter that doesn't close properly, the black screen with just the camera system text on it is a symptom of a shutter that is not opening properly. As for what caused the problem - possibly corrosion or contamination. Was the camera exposed to excessive humidity in the time it was unused? The shutter components are extremely delicate and can easily become stuck or sticky. This is what I believe has happened to your camera. It may not have failed completely but it may be sticking open or closed such that it is not performing its intended function. This will require full disassembly by a professional. David Millier Advance Camera Repair
Feb 23, 2007 | Nikon Coolpix 5700 Digital Camera
Blank Screen and faulty shutter blades
I found out the hard way that you should never use alkaline batteries in a Digital Camera. I thought my camera had a fundamental flaw (power kept going off whenever I tried to take a photo or record a video and the shutter blades half closed) even though it was only 2 months old. I nearly wrote it off but all along the problem was that I was using alkaline batteries, which incidentally were enclosed with the camera in the box!! Once I switched to NiMH (Nickel) batteries the camera worked fine and the fault completely vanished! These NiMH batteries are avaiable in most electrical shops i.e currys/comet in the UK. They must be charged before use. They are more expensive than alkaline batteries (£8-£9 for 4) but as they are rechargable they last a long time.
Oct 03, 2006 | Sony Cyber-shot DSC-S600 Digital Camera
No pictures recorded/black screen
it seems that shutter blades are stucked and are not working. when you say shutter is fully open i think you are talking about the lense cover, not the internal shutter assembly. the red light is the indication of OUT OF FOCUS SUBJECT OR FLASH NOT READY. if the shutter blades aare not open the camera would not be able to do the focusing and will flash the red light thus you would not get any image. contact the repairer.
Jun 20, 2006 | Kodak EasyShare LS443 Digital Camera
Kodak Easyshare M753 Digital Camera Logo
164 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
