Question about Sharp AR-207 Copier
Toner explosion there is toner spilling out of the cartridge - inside the machine, down the front and on the rug. Sharp AR-207 copier
    President:
  • 2,072 Answers
You need to either replace the toner cartridge or empty the sump on the front of the cartridge. The waste sump is in the front of the toner cartridge, It has filled up and has nowhere else to go but out of the sump and where ever it lands. Sometimes they fill up before the toner cartridge is empty. It happens
Posted on Jul 30, 2010
My machine model is SHARP AR 5520,the problem is that the machine is returning all the toner into the waste bin,all the toner will be sent into waste within an hour or two.this happened when i refilled the...
hello,
problem is your toner cartridge. inside of the toner cartridge have a toner roller it's didn't circling.or you are using duplicate toner powder.it's doesn't match with sharp ar 5520 developer. or your developer was expired.
first use original toner and try to make copies .i think your problem is solved.
Feb 05, 2011 | Sharp AR-5316 Advanced Digital Imager...
I have replaced the toner and it still flashes u 2 40 and i have tried pressing the # interupt c interupt 16 start but nothing happens....help
Corrupt or dirty toner unit chip. Remove toner cartridge, if dirty, clean chip and it's receiver on rear of machine. relocate cartridge and reset code using service code # * C * 16 press start key.
Good luck
Sep 14, 2010 | Sharp AR-207 Copier
My Sharp AR-207 gets a U2 error code. Nothing happens now. What is wrong, and how do I correct?
When your copier toner cartridge sensor is blocked.then problem arise ut or bios battery is not configure program.
reset : # - interrupt - C -interrupt press 16 press start key.
Jan 28, 2010 | Sharp AR-207 Copier
U2-40 error is comming in sharp Ar235, kindly help with details
You must be reset your copier.
press,# -interrupt-c-interrupt.
Press 16 press start key.Then machine is ready.
Jan 22, 2010 | Sharp AR-5320 Black and White Copier
Changing a drum cartridge
Open the right side door, open the front door, remove the toner cartridge and look inside. There should be a blue screw above the hole where the cartridge goes, loosen it and then remove the developer unit. At this point you can grab the black cover just to the right where the toner cartridge fits and pull out the drum unit.
Jul 30, 2009 | Sharp AR-M207E Black and White Copier
SHARP ARM 207 ERROR F2 04
Incorrect toner cartridge or has been refilled and gone past its life.
Replace toner
Jun 30, 2009 | Sharp AR-207 Copier
I have a sharp ar 207 copier. It is giving an error code of U 2. When you press "copy" it gives a code of 40. I cannot locate the service manual. Can someone help?
you have a problem with the chip on the toner cartridge
you have to reset this via simulation 16!
if it's a refilled one have the recycler do it and replace the chip
if it's an oem ask sharp
Jan 25, 2009 | Sharp AR-207 Copier
Crum data read trouble in sharp ar 207
The CRUM chip is what tells the copier that the correct toner is installed. It is specific to the toner cartridge. If it is a new cartridge then it should have a new CRUM chip and there should be no problem. If it is a recharge it's possible that the chip was not changed or the wrong one was used.
Oct 16, 2008 | Sharp Office Equipment & Supplies
AR-207 copier has "CH" flashing what to do?
CH code is usually associated with the Crum chip located on the back of the toner cartridge that gets 5 volts dc from the power supply and resets a counter on the main board to tell the copier approximatley how much toner you have when you insert an new toner. What may have happened, is the same 5 volts dc is shared with the laser unit and the when the laser goes bad it may cause the CH code just before it gives the E7-03 code for the laser due to the 5 volts being drawn down by the bad laser. If turning the machine off and back on with the new toner doesn't fix it then you either have a bad chip on the new toner or a bad LSU (laser Scanner unit)
Please don't forget to rate our answers please.
Dec 14, 2007 | Sharp AR-207 Copier
Sharp AR-207 Copier Logo
129 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
