Question about Dishwashers
I have a Kenmore Ultrawash. The last few weeks there is food grit left on everything on the top shelf. This happens even after we rinse all plates and dishes. We just have to put everything back again. It is horrible. The dishwasher is about 7 years old.
  • 909 Answers
Believe it or not, but this is a common thing. Basically, you need to remove both rotors, top and bottom and carefully clean them. If blocked, the rotors dont turn properly or at all and this leaves grit and grime still on the cutlery which you are experiencing now. (make sure the water holes are totaly clear).Once spraying properly, rotation will take place and will wash the grit off the cutlery.
Posted on Jul 30, 2010
  • gail_master Jul 30, 2010
    I have a spinner at the bottom of the dishwasher and 1 on the middle basket. I cannot get them out. Any suggestions?
    i have 1 rotar on the bottom and 1 on the bottom rack. I cannot get them loose. What could I do?
Kenmore dishwasher ultrawash debris on glasses
Fill the soap cup with vinagar and run it while its empty.
Mar 09, 2012 | Kenmore Dishwashers
After dishwashing everything has a film on it.
I often get calls similar to this client: Over the past several weeks-months, have been getting a whitish film/deposit on pots, tops of some plastic cups, etc. You don't really see it on plates.
Typically this is caused when someone switches detergent usually to a liquid gel. It is almost always because we use too much soap.
One of my most appreciated recommendations follows:
My suggestion is to throw the liquid away and use the Cascade Complete or Finish tablets. Place one in the bottom of the dishwasher. Do not put them in the dispenser.
The reason for this is you want the soap (abrasive) at the front end of the cleaning process so that the last little bit of food that is left on the dishes (I'm assuming you are rinsing your dishes) is blasted off and then the dishwasher can "sanitize" the dishes with water that is too hot for you to handle. That is the real purpose of a dishwasher.
Keep in mind that if you rinse your dishes well before placing them in the dishwasher you can probably use the shortest cycle and save quite a bit of money on electricity and water over the course of a year.
Also, take a coffee cup and fill it half way with white vinegar and place it upright in the top rack with your next load of dishes. Do this for the next several loads and then once per month for as long as you own and use a dishwasher.
Sep 12, 2011 | Kenmore Dishwashers
There is so much debris left on the dishes after the dishwasher has run, it's almost not worth running it. The debris is mostly small hard bits on the inside of glasses from the top shelf. Is this a...
this is a maintenance problem.. if the bits look like grains of sand it is actually food particles that breaks down during the cycle spraying the cups and glasses (usually the top shelf that gets hit worst). solution is to run a dishwasher cleaner through the system on a hot wash. To remove and wash bottom filters and spray arm jets. Lastly when loading the DW make sure excess food are scraped/rinsed off ...you will get better results. Thanks
Jun 22, 2010 | GE Dishwashers
Food remnants left on top rack of glasses and ceramic mugs.
Before loading into the machine clean the particles that are sticking to the dishes.
Check the drain filter at the bottom rack and clean. It is user cleanable
Apr 06, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Our Kenmore Ultrawash dishwasher leaks rinse aid. There is always a thin blue line coming from the rinse dispense, even after a wash, but more so between washes. We are usually careful not to overfill, but...
sorry but fixya has no way of checking what/where it leaks from . we do not have field reps that can physically observe things like this suggest you call a sears repair shop
Nov 04, 2017 | Kenmore Dishwashers
Dishes do not come out clean?
is the salt container cap damaged or loose? is the rinse aid topped up? if all ok then are you scraping most of the food from the plates, this can cause old food to mush, pulp and leave grit on dishes.
Mar 18, 2009 | LG LDF6810ST Stainless Steel Built-in...
Top rack in Kenmore ultrawash not being cleaned
Check to make sure the upper wash arm is not plugged with debris. All Plates on the bottom rack and bowls on the top. Position the arm at 12 o'clock and check at the end of the cycle to see if it has moved positions.
Jan 20, 2009 | Kenmore 15899 Built-in Dishwasher
After my dishwashing cycle is complete there is a residue left on the dishes -- I only fill the soap half way and i use a rinse agent.....
Dishwashers work best when the following "rules" are followed.
1. Rinse food off of the dishes before you place them in the dishwasher.
2. Face plates toward the center and do not over crowd them.
3. Always put glasses on the top shelf and always put plates on the bottom.
4. Run the hot water in the sink until it is as hot as it will get before you start the dishwasher.
5. If your dishwasher has a pot scrubber cycle use it and it will make a difference.
Doing these things should solve your problem. If not, let me know.
Jan 04, 2009 | Tappan 18 in. MDR251RE Built-in Dishwasher
Kenmore Ultrawash QuietGuard 3 Dishwasher not draining or rinsing
Hi Claire,
Are you using rinse aid?
that may help with the film.you may also have stuff down in the trap causing the water to drain slow.
Nov 05, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwashers Logo
50 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
