Question about Whirlpool LER5636P Electric Dryer
Dryer quit drying
I bought it second hand. It quit drying. The warranty had not yet expired but they did they didn't warrant safety thermos. Can't find a model number. Looked everywehre. It's whirlpool gold, if that helps, with 9 temp cycles.
    Genius:
  • 1,028 Answers
If fairly new and element back 279816 is pt # for saftey element 279838 i think
Posted on Apr 27, 2008
I have a 2007 kenmore 700 series gas dryer. 77751. it has quit drying clothes. if i turn it on, let it run for a few seconds, then open it and stick my hand inside, i can feel some heat. if i then close it...
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Dec 28, 2010 | Kenmore Dryers
New dryer looks like never been used (got in purchase of home), pulled lint trap to see for lint (clean) flashed light inside trap (clean), drum turns when on and clothes become warm/hot but not...
it is either the coil is going bad or the thermo safety is bad, there should be a wiring diagram(usually located in the back of the dryer behind the knobs, just unscrew the back plate) and you will see the safety limit. You can bypass and see if that is the problem, if it is make sure to get a new one as if you leave it bypassed and use it down the road it may cause a fire. Hope this helps tim
Sep 02, 2010 | Dryers
I have checked and cleaned the vent hose and screen. However the back of the dryer gets very hot. Also the top gets to hot to even place your hand on it Frigidare GLER341As2
There is a safety thermo switch that is located on the top rear by the controls, it may be going bad, as if the coils get to hot it is suppose to shut the dryer down.
Jul 24, 2010 | Frigidaire GLER341A Electric Dryer
Whirlpool Dryer Does not dry
Its the thermal fuse. when you jump or, by-pass the cycle thermostat, you are basically by-passing the fuse as well. replacing the thermal fuse will fix thsi issue.
The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jun 21, 2009 | Whirlpool LER4634J Electric Dryer
Conia CCD4501 cloths dryer not blowing hot air anymore
If you can turn it on and have the door open, hold the door switch in and see if you have a glow from the heating element. If not, your element is broken. That is if it is an electric dryer. If it is a gas dryer you need to check the pilot light or the thermo sensor.
Jan 13, 2009 | Conia DVD8500 DVD Player
Kenmore dryer will not come on at all
Hi thanks for the question. at the back . remove the panel. on the heater on right at the top. small disc . this is a hi limit cut off. check this part if failed replace. also clean all venting. as this could cause the hi limit thermo to fail . thanks the appliance doc
Oct 06, 2008 | Dryers
Candy washer dryer not drying
there is a safety feature which advances the timer to a stop position if it overheats on dry. this is caused by poor air flow.
to cure, take the dryer duct off mand clean of lint. this especially accumulates at the bend where the duct enters the tub.
Sep 05, 2008 | Washing Machines
Not drying no heat.
be element are thermo fuse on element no easy to change remove 2 screws on door hinge 2 screws on the ather side frount comes off there the element
Feb 29, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
81 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
