Question about Kenmore Dryers
The dryer door will not stay closed, so it shuts off after starting
    President:
  • 3,773 Answers
Check your door latch.Shut the door and pull it open. If it pulls open very easily then you need to change the door latch. Make sure the door is not sprung
If it is then put a small screwdrive in front of the latches inside the door and push very gently in degrees. Then remove the screw driver and test it. Do this over and over (very gently) until it closes properly.
Or you can remove the hinges off the door and straigten them.
Leo Ponder
imufo2@sbcglobal.net
Posted on Jul 30, 2010
LG dryer doesn't dry clothes on one cycle. Lint collects around bottom of door rubber seal. Have noticed, the door is not closed tight. How to get door to stay closed tightly?
It sounds like you have a plugged up vent causing air to try to blow out around door instead of out vent. Also check door latch to see if anything is broken.
Mar 28, 2016 | LG Dryers
How do I know the door switch is bad
If light stays on when fully closed, door switch needs replacement, easily removed. Short term fix, disconnect the switch and tape the two spades together. Warning! Dryer will run even with door open.
Nov 29, 2014 | Sears Kenmore Elite Electric Dryer 69278
Door will not stay shut
There has to be some sort of spring on the door latch assembly that keeps the door closed. If broken or no tension the door will not latch and spring open. And when the door springs open, a safety switch shuts the machine off.
Nov 21, 2013 | Bosch Nexxt WTMC3321US Electric Dryer
Dryer light stays on when door is shut nd wont run
check the door switch,i don't work on lg but on any other dryer if the wsitch is broke the dryer won't start and if the light is on the switch shuts off the light and dryer will start.if you send the model number i can look up the switch for you.open the door and look around the frame where the door closes into,there should be a push button switch or a little paddle that the door hits,when you push in on the switch it should make a clicking sound or i've seen the paddle broke off.hope this helps or if you removed any wires to the door switch you might of wired it wrong
Mar 30, 2013 | LG Dryers
Wont start are do nothing wont come on but light inside stay on all the time even when door close
Sounds like your door switch needs to be replaced. When the door is closed it is supposed to shut off power to your light, and send a signal to the timer that the dryer is ready to start. If your light is on with the door shut, then it won't start. Pretty simple replacement that you should be able to do yourself. Good Luck, Appliance Specialists
Dec 08, 2010 | Dryers
Dryer won't start; light stays on whether door is open or closed.
Sounds like the door switch is not functioning or shorted......in other words the dryer thinks the door is open so it won't turn on.
Jun 22, 2009 | Dryers
Door does not stay closed
your door clip needs to be replaced or realign
your door
Jun 11, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Dryer door won't stay closed
hi,
shut off the breaker- pull the female receptacle clasp out of the front with flat screwdriver and needle nose and squeeze the back of it gently with pliers, replace, if its busted and you get mad, you can buy a standard padlock and latch and install that, that helps in other ways as well, careful to steer clear and watch the inner wall for wires and clearances if your going to retrofit that.
J
Jun 17, 2008 | Whirlpool LER5636P Electric Dryer
Dryer stays on for 3 secs and turns off; sometimes won't turn on at all.
sometimes the movement will cause the door to open, thus shutting off the dryer. Does the door shut tight when you close it? there is a little clip that if broken, the door will pop open easily. After it shuts off is it easy to start again?
Mar 12, 2008 | Dryers
Dryers Logo
222 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
