Question about HP Computers & Internet
No sound! 2 sets of desktop speakers didn't work so I added a usb audio--it worked a few days then quit. I bought a second usb audio--still no sound. Computer sucessfully added usb hardware, volume levels are on high, drivers have been upgraded, and device mgr. says all devices working properly. Advice please?
  • dayars3100 Jul 30, 2010
    Hi--I wasn't unhappy with the other advice, I couldn't figure any way to send for more!
  • 4,281 Answers
Make sure there is not any loose connection betweeen speakers. Make sure all usb ports and it's driver working fine. Go to device manager and uninstall all usb drivers and audio driver also uninstall audio driver from control panel> add remove program then reinstall audio driver usb drivers are automatic install . Then check. Also scan computer with updated antivirus. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Jul 30, 2010
    President:
  • HP Master
  • 2,923 Answers
Based on your statement, I'm sure that you have successfully re-installed the driver.
Is it a desktop or a laptop? If it's a desktop computer and you can take the sound card out from the computer, it would be better to take the sound card out and install it in to different computer.
Be sure to install the driver properly. If the same problem occur, then you need to replace the sound card. But if the sound card works correctly on different computer, then you need to consult a pro that will check the internal components.
Thank you and good luck!
  • 1 more comment
    thanks----I have re-installed the driver, yes it is a desktop pc.
    Opening the computer and finding the sound card is kinda past my high tech limits. Any advice on how to recognize it once inside? I have an older hp desktop, is there a chance I can steal the sound card from it and substitute? Thanks you for helping!
    Yes it is a desktop---yes, I re-installed the drivers.
    I can open my computer, but recognizing the sound card is beyond
    my low-tech knowledge. Any advice on how to know which is the sound card?
    Also, my computer is an HP and I have an older hp not being used. Any chance the sound cards would be compatible?
    Thanks much for your help----David Ayars
    Hi again! Yes, I re-installed drivers. It is an HP desktop. I can open the computer, but recognizing the sound card is beyond my low-limit tech.
    Any advice on recognizing the sound card? Also I have an older hp, any chance the sound card would be compatible so I could switch?
    Thanks for helping, David Ayars
I have a sceptre flat screen i bought 2 years ago (40") the sound just quit can hook up external speakers?
Read the owner manual or check all the inputs on the rear to see if it has those connections---it is also possible a surround system routed from a box (cable or sat) might work to bypass this issue.
and do not forget to check in the set menu that the speakers did not somehow get switched to OFF.
Dec 08, 2012 | Sceptre Televison & Video
No sound
You have multiple playback devices go to: Start > Control Panel > Hardware and Sound > Manage Audio Device> Sound. Set speakers as default. Right click has Show Disabled and Disconnected devices.
Oct 14, 2012 | Sony VAIO VGC-RB38G PC Desktop
My pc left speaker does not work. but in other devices speaker works
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line or use a can of compressed air specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
or if its a desktop swap the speakers around if one still does not work its either a faulty speaker or the speaker connection
hope this helps
Aug 21, 2012 | Intel Desktop Board DG41WV Motherboard
My new Vidwo carde disabled my PC sound jack, but I have audio from my USB headset. How do I get my audio jack and external speakers to work.
Find and Try reinstalling Driver for onboard audio look in device manager and see if there is an exclamation mark next to your sound hardware, also there maybe an audio out jack on your vid card that has priority over your onboard since its hd
Jun 19, 2012 | Compaq Computers & Internet
Monitor speakers not working
You need to reinstall the software driver for the sound card. Usually, a virus/mal/ad/spy-ware will disable sound quite readily!
gurutim
Mar 21, 2009 | Westinghouse 19" Widescreen Flat Panel LCD...
Im using a Non USB headest, it has power, but no sound.
Download and install the sound drivers for your audio. Go to your manufacturers website and get it.
Mar 12, 2009 | HP Audio Players & Recorders
Audio volume keeps changing by itself
No, the headphone output is designed for 2 speaker output. Just recently I had a customer who had no sound coming from the desktop speakers yet the headphones worked just fine.
I believe that your model has a sound circuit integrated into the motherboard. It may have a “plastic cap” covering the audio ports (next to the USB ports). If you remove the sound card and enable the integrated audio in the BIOS, you can check to see if the sound card is actually the problem.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 16, 2008 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Relisys Sound
CJ,
1. Check make sure the audio cable are plugged in from the monitor to the PC output audio jack (light green).
2. Open your on screen display and go to Volume settings. See if it set on mute or set to 0.
3. Turn of your monitor & PC and unplugged all the cables from your monitor and PC wait for 10 seconds and then replugged it all the cables and audio cable back. Then turned on you PC...
4. If it still doesn't work.. open the back cover see if the speaker cable are plugged in.
5. If that doesn't work...then your monitor AD board built-in speakers are defective.
6. Why not just used a external speakers, it give better sound quality.
Have a nice weekend!
Aug 17, 2008 | Relisys RLT1720 17" LCD Monitor
Audio on home PC not working...
I dont has audio in my desktop. Please can you help my.
May 15, 2008 | Computers & Internet
Mulitmedia speaker and mic not working
For the first problem open your multimedia properties box under the audio tab you will have a sound recording device specified, check whether you have your device listed, usually you have your say ( Realtek HD Audio input or the respective company input device who supplied your audio drivers). If its not listed ten you might be having problem with the drivers or hardware you will have to call the service engineer to have to problem solved.
for the second one try the same solution. select the proper devices under the audio tab in multimedia settings.
Jan 01, 2008 | Acer Aspire T160 (AST160UA3400) PC Desktop
Computers & Internet Logo
32 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
