Question about Ricoh Aficio AP3800C Laser Printer
Remove Misfeed B Fusing Unit Error- After 1 page is printed
We are getting this paper jam error Remove Misfeed B Fusing Unit, but I can't actually find anything jammed. Sometimes I am able to reset, and it will print one page, but the error is shown as soon as the page is output, even though no jam occurs.
Any clues?
  • 3 more comments
  • SimonCC Apr 26, 2008
    Hi
    Can you point me in the direction of where the sensors/levers are?
    Am I looking on the fusing unit itself or somewhere else?
    Cheers,
    Simon.
  • SimonCC Apr 29, 2008
    Getting paper jam messages in Fusing unit area even though there is no jam. First page comes out then error shown. If this is a switch or sensor problem, then I am wondering whether this is on the Fusing unit itself, or somewhere else on the printer.
    Need some guidance as to where these sensors/switches are, that could report a false jam.
    I have the fusing unit out on the desk, any clues as to where the roller pin is and what it looks like? I can turn the blue knob on the side of the unit, and the orange belts rotate freely.
    Fuser Oil unit comes out fine, can't see any problems either side of this.
    Error shows as soon as the printer is switched on now. So the fault condition is now permanent.
    Error shown is Remove Misfeed B Fusing Unit. Only reset done is to switch unit off and on, close covers as stated in display panel.
    Brigadier General:
  • 6,966 Answers
With the indulgence of pagebor,
It would seem that the "paper jam error" is common with this model. Apparently, the roller pin on the fuser unit is the culprit. The roller pin could be loose or even dislodged.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 29, 2008
  • 2 more comments
  • Louie  Role
    Louie Role Apr 29, 2008
    Hi again,
    Appreciate the postback. Could check if you could separate the fuser oil unit from the fuser unit? If yes, then it would be on the left and right of fuser oil unit. Both ends has roller pin that has to fit just right with no wobble, looseness or misalignment. This document might help you in the removal (page 7).
  • Louie  Role
    What is the exact error or status message pls? have you done again a reset?
  • Louie  Role
    Thanks for your reply. Based on the error message, you are on the right track on focusing on the fuser unit. To my knowledge, the blue knob maybe turned freely as you have indicated, but the fuser oil unit should have some resistance.
    Unfortunately, the only available option now is to remove/open the fuser unit again. The alternative is to replace the fuser unit assembly.
  • Louie  Role
    In a similar problem, it turned out that a pair of gears were not meshing together properly caused by one of them that has a crack. When tested manually, checks OK, but when under load (pulling/pushing paper) partially opens.
    Genius:
  • 2,785 Answers
Just open the printer and check for any dislocation of the sensor or levers.
Posted on Apr 26, 2008
Ricoh c8 problem solution
hi sir help me rico sp 100su c8 error whats the problem
May 19, 2014 | Ricoh Aficio SP 100SU e Laser...
Trying to print A3 full colour on my bizhub c250.2out of 3 times paper crashes at the oven and get the massage: misfeed detected, i remove the jam paper. but i would like to know what can cause this...
Fusing unit life is over or it can be the paper size problem.if you are using manual by pass tray for A3 printing then make sure machine is detecting A3 in manual by pass tray.if its OK then problem is in fusing unit.
May 31, 2012 | Konica Minolta bizhub C250 All-In-One...
Printer has error code H3-30 that wont clear with the #*C* code and will come up with a paper jam error. The last thing that was being done was a 2 side booklet was being printed and the last page...
Check the follwing portions
1.Paper Feed Rollers
2.Drum/assemly unit
3.Fusing Unit.
Hopethis helps. If it does, please accept and rate the solution! Contact me withany more questions you may have. Thanks for using FixYa!
May 25, 2011 | Sharp Office Equipment & Supplies
My copier ( Sharp AR 201 ) , causes misfeed every time I try to make a copy. I have tried all the trays , including bypass tray. But it didn't work. I guess it gets jammed when it goes up to the fusing...
If the rollers are old and dry they can cause a misfeed.
When they are dry; paper is less likely to be pulled into position for printing. If a feed roller is slick on one edge, the apposing side may direct the paper on an angle (somewhat sideways) and a crooked alignment results in paper being caught up in the gears, wrapped around rollers, torn in pieces, etc. Check the roller surfaces.
Jan 12, 2018 | Office Equipment & Supplies
I have a Sharp Al-2040cs when I turn it on the misfeed indicator is blinking. I checked it there no misfeed paper or piece of paper inside. How can I fix this problem?
The MISFEED Indicator blinks when a MISFEED has occurred. Remove the misfed paper referring to the the description of MISFEED REMOVAL beginning on page 65 of the pdf Manual at:
http://files.sharpusa.com/Downloads/ForHome/HomeOffice/PrintersFaxMachines/Manuals/cop_man_AL2030_AL2040CS.pdf
When the MISFEED Indicator is blinking you should look closer at the paper feed area (see page 66 of the PDF). You may need to remove the paper tray to find any remnants of paper. If after closing the side cover the light does not stop blinking you will need to follow through as per the illustrated instructions.
Remember after removing jammed paper, you need to press the clear key to clear the MISFEED error.
If after doing all this the error signal has not cleared, power down the printer; unplug from the power supply; let rest 5 - 10 minutes; plug back i to power supply; turn printer on and see if this resolves issue.
Trust this is helpful. Please vote. :)
Dec 12, 2010 | Sharp AL2040CS Digital Laser Copier,...
Ricoh 3045 printer stopped printing error code SC545
Hello, you´re found problem in the fusion unit. Clean the thermistor, and try again. Before try it, most reset the Sc code with service code....Good Luck!
Feb 08, 2010 | Ricoh Office Equipment & Supplies
Help
H5-01 indicates tha the paper sensor is defective in the fusing unit. The only way you can try to reset that one is buy turning the power off, wait 30 seconds and turn the power back on.
If the error code returns the fusing unit will have to be fixed to take care of the paper sensor.
Jul 20, 2008 | Sharp AR-M237 Digital Copier
Laser Printer HL-1440
Hi , The error message your getting refers to the following for the Ready & Alarm Buttons Flashing.
1. Paper Jam
2. Misfeed
3. No Paper
I hope this helps!!
Dec 05, 2007 | Brother HL 1440 Laser Printer
E350 misfeed on print/copy 2nd page
Does this happen from all cassettes or only one? What are you getting for a jam location??
May 11, 2007 | Toshiba e-Studio 350 Copier
Ricoh Aficio AP3800C Laser Printer Logo
294 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
