Question about Microsoft Windows XP Professional SP3 Full Version OEM for PC
My xp pro os wont boot after running chkdisk at startup.. It checks the disk says ''clean'' then acts like it is going to boot up windows but just hangs there indefinitely .. tried safe mode and it hands after displaying the drivers.. cant have xp disk tried bootfix but no change
    President:
  • 2,668 Answers
Open XP in safe mode with command prompt.
Open a command window (start/run type cmd in the box then enter) and you will get the following.
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
You will then have a flasihg curser after
C:\Documents and Settings\PC name>
Type
CHKDSK /f /r
You will then get
C:\Documents and Settings\PC name>chkdsk /f /r
The type of the file system is NTFS.
Cannot lock current drive.
Chkdsk cannot run because the volume is in use by another
process. Would you like to schedule this volume to be
checked the next time the system restarts? (Y/N) y
This volume will be checked the next time the system restarts.
Type exit and restart.
make sure there is a space between each / and the previos word/command
The /f and /r do the following
/f: Fixes errors on the disk. The disk must be locked. If chkdsk cannot lock the drive, a message appears that asks you if you want to check the drive the next time you restart the computer.
/r: Locates bad sectors and recovers readable information. Again the disk must be locked.
Posted on Jul 30, 2010
No OS found on disk
Make sure no other disks are plugged in (USB/CD/DVD), check BIOS for Boot Order, ensure your hard disk is 1st in order. If it still doesn't find the OS then you may have corrupted data, and potentially a defective disk. You can visit the hard disk manufacturer for a test utility for your hard disk and boot from it and scan the drive. It may even fix some errors.
You may also need to boot from an OS disk and select recovery console and run chkdisk /r on your main drive.
Jan 11, 2014 | Microsoft Windows Vista Home Premium with...
Blue dump error 0x0000007b error coming
Try running the Check Disk Utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Jun 02, 2012 | Computers & Internet
I have a hp pavilion 2120tx with windows 7 and i want to dual boot windows 7 and windows xp [windows 7 first]
You can create a Dual Boot in ur machine....
C: XP
D: or E: or F: as Win7
You need to re-format your disk, back up all critical data in your disk....
once done...boot with XP disk in CD drive....
after format, create multiple partitions....C: , D: , E: etc as per your preference
install XP in C:
once done...start PC and let the machine boot from C: XP...once you get Desktop in XP
install Win7 in D: or E: as prefered....once done..
in the startup screen you will get these 2 options
1 load earlier version of Windows
2 Windows 7
to make Win7 as default, right click on My computer (Win7), Properties / Advancd System Settings / Advanced Tab / Startup and Recovery / Under System Startup - Chose the Default OS by the down arrow and the time to it must be displayed in the startup to chose the OS....by this method you can chose Win7 or Xp to load...make your choice as prefered...
reg
for more info on formating and loading OS visit my site
www.sureshayyar.110mb.com
May 08, 2010 | Computers & Internet
My laptop boots and then reboots in a continuous cycle .wtf is up with it ?
this is a case of os corruption somehow..!!..may b a virus/trojan or hardware or software is responsible..
all u need is the os boot cd anyway..
probably now u got two way out:
gotosome cyber n download win xp pro sp2, using any bit-torrent client(likeutorrent) from torrent site (eg. mininova.org so on)..make a boot diskn try..
1) copy the file in windows repair mode or from any identical os n put it in place as stated above..
OR 2) reinstall os..
(totake data backups u gotta connect the hdd to another pc/laptop, for suchcases a hdd-case is available in the local spare market, it'll makebehave ur hdd to act as an external removable drive)..
this canalso b a symptom of faulty/defective of RAM..pen clean/remove carbon& or oxide formed on the teeth with an eraser n resit it..[it'll bmore prominent, that if itz cause by ram or not,..if during normaloperation, a Blue Screen appears/Memory Dump]
though, sometimes itz also caused by the m/b..
if once u can login, do the following:
hv a licensed and UPDATED antivirus installed (i prefer avg/kaspersky, , without updation a full version antivirus is useless)..
download, install n run microsoft kb890830..http://www.microsoft.com/downloads/details.aspx?FamilyId=AD724AE0-E72D-4F54-9AB3-75B8EB148356&displaylang=en..
download n run Startup Control Panel..http://download.cnet.com/Startup-Control-Panel/3000-2094_4-10039330.html..'removealltheunnecessary startup items from here..(if u can't find what toremove,post me/us in ur comment with all the items listed in each nevery tabs herein)..
remove all unnecessary software from add/remove programs..
download, install n run 'Advanced System Care Pro'..http://download.cnet.com/Advanced-SystemCare-Pro/3000-2086_4-10399324.html..
disable thefollowing: a) 'Automatically Restart' right click onmy computer->properties->advanced->startup nrecovery->(uncheck on the) Automatically Restart; b)'ErrorReporting 'right click onmy computer->properties->advanced->errorreporting->disable error reporting->(uncheck on the) 'but notify mewhen critical error occur'..
Increase the size of Virtual Memory, Initial: 1440; Maximum: 2880
always better to seek professional advice of ur system admin/vendor....
Nov 12, 2009 | HP Compaq Presario V6000T Notebook
My laptop has crashed and when I try to reboot it just cycles through the reboot over and over. Even when I press F8 I can't get into safe mode to reboot. I don't have my windows XP CD to repair the...
thisis a case of os corruption somehow..!!..may b avirus/trojan or hardware or software is responsible..
goto some cyber n download win xp pro sp2, using any bit-torrent client(like utorrent) from torrent site (eg. mininova.org so on)..make a boot disk n try..
OR2) reinstall os..
(to take data backups u gotta connect the hdd toanother pc/laptop, for such cases a hdd-case is available in the localspare market, it'll make behave ur hdd to act as an external removabledrive)..
this can also b a symptom of faulty/defective ofRAM..pen clean/remove carbon & or oxide formed on the teeth with aneraser n resit it..[it'll b more prominent, that if itz cause by ram ornot,..if during normal operation, a Blue Screen appears/Memory Dump]
download n run Startup Control Panel..http://download.cnet.com/Startup-Control-Panel/3000-2094_4-10039330.html..'removeallthe unnecessary startup items from here..(if u can't find whatto remove,post me/us in ur comment with all the items listed in eachn every tabs herein)..
disablethe following: a) 'Automatically Restart' right click on mycomputer->properties->advanced->startup n recovery->(uncheckon the) Automatically Restart; b)'Error Reporting'right click on mycomputer->properties->advanced->error reporting->disableerror reporting->(uncheck on the) 'but notifyme when critical erroroccur'..
Nov 10, 2009 | Dell Latitude D600 Notebook
My matser hd oin is aet to master. My slave is set
If you have the XP install disc just disconnect your master HD and use XP disc to format the slave drive. Exit after format, remove XP disc and reconnect Master. You now only have 1 drive with an OS.
Oct 05, 2009 | Symantec Norton Partition Magic-8.0...
How want to downgrade win vista to xp pro hp compaq v3000
If you have a Windows XP Pro installation disk, put it in the optical drive, restart your computer, on startup, go to BIOS settings (usually press [Delete] and set the optical drive as first boot device. Save changes and exit. When the computer starts it usually says to press any key to start from CD. Press any key and the windows installation will start. Make sure you format C: and you will downgrade to Windows XP Pro. If you want to upgrade to Vista again, you will need to know the keyboard sequence to start Vista from Its partition or have Vista install disk.
May 25, 2009 | HP Compaq Presario V3000T Notebook
I have a gateway lb3 500 ancient 98se i tried to load xp pro and it crashed i cant seem to even get a 98 startup disk to work to recover it . how can i recover it to load the xp pro onit
Try running linux on it. Linux will run much better on older hardware. Depending an the specs of the system, it may not be able to handle running windows. Try ubuntu (www.ubuntu.com). If it used to run Windows XP or 98 and it wont now, try checking the hard drive. It may be corrupt. You can find hard drive check tools all across the web, google for drive fitness test by hitachi, it works great. Burn to a disk and boot to it on the older machine and do a full advanced test on the drive.
Dec 07, 2008 | Computers & Internet
Acer aspire 3610 not booting pass flash screen
you can reinstall os with ur xp.
with xp disk in drive at startup do you get option to boot from cd.
if not go into bios at startup and enable cd boot in boot options as first;save and exit;restart.
I assume you know how to install windows(xp)
Mar 03, 2008 | Acer Aspire 3610 Notebook
Startup screen freezes
using the system restore disk, boot the laptop and choose repair, run chkdisk /r this repairs the system files, if this does not fix the problem, using the same system disk do a restore.
BPCS
Dec 06, 2007 | Dell Inspiron 8500 Notebook
Open Questions:
See all Microsoft Windows XP Professional SP3 Full Version Questions
Microsoft Windows XP Professional SP3 Full Version OEM for PC  Logo
73 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
