Question about Zanussi FLE1416W Front Load Washer
Keeps on heating and no cool rinse put in new thermostat still heats and heats zanussi fle1416w
    Sniper:
  • 174 Answers
Sounds like you have it connected to hot water supply. This is a cold water fill only machine.
Posted on Jul 30, 2010
Testimonial: "thankyou baffled how this happened as perfect b4 bearings changed washed great just noisey thanks again for advice will look into this "
  • John Wilkinson Aug 03, 2010
    Ii take it it was not connected to hot water. If it really is heating on the rinses it can only be a sticking heater relay on the main circuit board.im presuning that the water is pumping out ok because you have not mentioned any retained water at the end. the electronic (£120) spare part has to be configured before will work. its not simple to do without it being shown to you.sorry if you find this unhelpful.
I have a 5-ton Nordyne heat pump. The compressor has quit working. How can I get the emergency heat strips to come on using emergency heat on the thermostat.
Your thermostat should have an emergency heat setting. Putting the thermostat in that position should make the electric heat strips only work and keep the compressor from coming on. If your thermostat doesn't have an emergency heat selection disconnect the compressor outside at the power source. Turn the thermostat 5 degrees Above the Rim temperature the electric heat strips should come on.
Jan 02, 2018 | Heating & Cooling
I just put in this new thermostat, I believe all the wiring to be correct i have one extra wire (brown) that should be a common wire used to keep the display lit. when I turn the unit on cool ( with the...
Heat pumps require specific heat pump thermostat. If you are trying to install a thermostat that is generic forget it. A heat pump is a diff animal than a central unit. Get the thermostat that matches your system. A generic won't cut it.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 13, 2011 | Heating & Cooling
Zanussi zbf260x built-in oven keeps tripping out
Probably due to a fault on the oven heating element. Check continuity and earth with a multimeter if you can but it's odds on you will need a new heating element.
Dec 26, 2009 | Zanussi ZBF260 Electric Single Oven
My montero keeps overheating. I put a new
These newer engines and air lock when changing the thermostat. Somewhere in the thermostat housing you should see some kind of a plug. You need to do this while engine is cool. Take the cap off the radiator. Remove the plug. You should get air out of the system. Keep letting air out as you put more coolant if needed. When all the air is gone put the plug back in and top off the radiator and you should be good to go.
Dec 02, 2009 | Mitsubishi Montero Sport Cars & Trucks
No heat changed thermostat flushed engine new coolant
did you release air from cooling system when replacing coolant!! if air is trapped in system it will not heat up proper. turn fan on high heat locate bleeder for cooling system, open bleeder with car running. if there is any air in system you will see it come out of bleeder. keep checking for heat. when you get heat bring coolant to proper level. leave top off of coolant recovery tank while bleeding system. put cap back on when done.
Nov 17, 2009 | 2001 Plymouth Neon
Engry problem
HI
Its true you are using power to heat the water....
BUT
all the time its heating through different temperatures, different stains are removed. Also its agitating for all this time. If you put hot water in only it wont wash as long. Also the incoming temperature could be too hot for some fabrics. Also you wil be using your hot water to do all the rinses.
Its up to you, but, zanussi know what they are doing
Feb 17, 2009 | Zanussi IZ12 Front Load Washer
Zanussi FLE1416W Front Loader
Most possible reasons that the door switch or timer unit is defective. The dishwasher should heat the water to about 55 C as the heating cycle starts. In these cycle, the dishwasher pauses after has filled with water and wait for the water to reach the temperature. If the water isn't being heated (because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. if you think that a user manual may help you more, it can be downloaded ($8.95) at url: http://www.download-manual.com/shop/Zanussi-FLE1416W-User-Manual-pr-8261.html
Jan 22, 2008 | Zanussi FLE1416W Front Load Washer
Problems! zanussi zsf6120
You can check the heating element with an ohmmeter and it should read a few hundred ohms. Don't know about the thermostat but it should be inline electrically with the heating element and should ohm as a short when cold.
Nov 23, 2007 | Zanussi 24 in. ZSF6120 Free-standing...
Zanussi FLE1416W Front Load Washer Logo
64 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
