Question about Kodak EasyShare C875 Digital Camera
I have a Kodak easyshare M340. I have put the setting as general picture taking and Flash to be Auto, but when I tried to take a picture the flash may or may not flash. Even when I put the flash setting to flash, it may or may not flash. Help.
  • 906 Answers
Link
Try checking browsing your manual. This will be helpful to know more about your camera.
God Bless
Posted on Jul 30, 2010
When I plug the USB cable from my Kodak M340 camera into the USB port on my computer (running Windows 7) the camera instantly turns off. The battery is fully charged (green LED is steady when the charger...
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Dec 19, 2010 | Kodak EASYSHARE M340 Digital Camera
I have a Kodak EasyShare M340 it was working fine earlier today but now when I turn it on the screen is black and when I take a picture it comes out black too, even with flash I can see the saved pics on...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Nov 20, 2010 | Kodak EASYSHARE M340 Digital Camera
The setting is corrupt and when i take pictures day time it not clear and does not flash
If you have the settings on AUTO the camera will automatically adjust to what it thinks will make the best picture.
Try and use the SCN.
You can also switch the flash on and off as you wish.
For more tips and tricks on picture taking please follow this link:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=38/13915/39&pq-locale=en_US
If successful please give me the feedback as a rating or recommendation. Thank You
Dec 22, 2009 | Kodak EasyShare V1003 Digital Camera
Kodak es c875 flash problem
Try to do this press the flash button then chose the Fill Flash so if you take picture it will always fire the flash., May be your using the Auto Flash.
If your flash will not fire using the Fill Flash setup it means the Flash is defective call tech support toll free 1 800 235 6325 ext 12
You may also see the flash setting if you press the menu button and under menu button look for setup
Nov 15, 2009 | Kodak EasyShare C875 Digital Camera
I have a Kodak M340 Digital camera. At first the flash would malfunction when taking a picture. Recently the unit will not turn on when the on button is pushed. It is not the battery as they have been...
KODAK Li-Ion Rechargeable Digital Camera Battery KLIC-7001? If yes please try to clean the 3 metal contacts of your battery., then turn On camera., if its failed and since you verify that the camera is fully charged it means the contacts of the battery between the camera is already defective., call kodak for repair Toll free 1 800 235 6325
Oct 26, 2009 | Kodak EASYSHARE M1063 Digital Camera
My kodak easyshare m340 screen after taking a picture lasts too long before the next shot comes up on the screen. How can I get the screen to show the picture then go away faster??
One thing you can try is to use a faster memory card. Some cards are very slow, and that is why many are cheap.
Here is a review and some interesting points:
Kodak easyshare m340 review
Some points copied: "The M340 performed well on Shooting-Digital.com's shutter lag test, averaging just 0.33 second from shutter press to image capture. In the best-case scenario, the camera can power up and fire a shot in 2.45 seconds. Even better, you only have to wait 1.74 seconds between shots. In comparison, the PowerShot A1100 starts up and shoots in only 2.26 seconds but takes 2.35 seconds between shots; the sluggish Coolpix S230 needs 5.79 seconds to start and 5.69 seconds between shots."
So, if your camera is slow with a fast card, it may need repair. Check with Kodak.com at the support/ repair department.
Oct 23, 2009 | Kodak EASYSHARE M340 Digital Camera
My Kodak EasyShare M1033 will not auto-focus. I was using it on vacation with no issues for 5 days and all of a sudden it won't focus. I did online chat with the Kodak helpdesk but he had no clue. This is...
Try to set the camera on auto mode
make sure that the flash is also set in auto
take pictures in different lightning condition out door and in door
if the problem still persist its either the lens assembly or the camera sensor is defective
Jun 14, 2009 | Kodak EasyShare M1033 - black Digital...
Flash not working
Note that the SCN setting on the option dial is for Text and will not engage the flash. Make sure you are using an option for which auto-flash is enabled. Otherwise, it is possible the flash is spent. The bulbs do wear out eventually.
Sep 29, 2008 | Kodak EasyShare Z710 Digital Camera
Dark pictures from kodak cx7430
Is your camera set to auto mode? I'm not sure if the CX7430 has manual settings or not, but try making sure its on auto.
Its possible the lens or the CCD (the device responsible for actually taking the photo) is going bad.
This guy - Darntoothysam has a CCD assembly as a low cost fix, 15 dollars.
http://cgi.ebay.com/Kodak-CX7430-EasyShare-Camera-Parts-CCD_W0QQitemZ250111578019QQihZ015QQcategoryZ64352QQcmdZViewItem
Nov 15, 2007 | Kodak EasyShare CX7430 Digital Camera
Kodak EasyShare C875 Digital Camera Logo
122 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
