Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
Runs first 30+ sec then bogs out/dies when throttle pressed
I've only used it about 45 minutes so it's not broken in. when I started it at first it would not run / start with choke on(fired and died) but it starts without chk fine. when started w/o chk it revs and spins the chain for about 15 seconds then the chain stops and it idles after that I can cut with it for about 5 seconds then it boggs out --- please somebody tell me if I can adjust it and how so
please and thanks mucherbuncherly
    President:
  • 2,220 Answers
If still under warranty have it serviced (authorized dealer not Joe's lawn mower). There should not be a fee (paid by Husqvarna). There have been carburetor problems. If you adjust it your warranty will likely be void; Joe's small engine service just as likely to void any warranty. Are you using a fresh 40:1 fuel oil mix. The will not start with choke set is normal. Start procedure in your OM says listen for sputter and disengage choke. Almost all new saws have similar start procedure.
Start Procedure
Cold:
  1. Ignition on/off to on.
  2. Set compression release – optional step even if saw is equipped with a compression release.
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4).
  4. Set compression release – optional step even if saw is equipped with a compression release.
  5. Push (open) choke pull starter until it starts. (usually first pull).
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed.
  4. Push (open) choke, pull starter until it starts. (usually first pull).
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Jul 30, 2010
  • dontbother10
    dontbother10 Jul 30, 2010
    My bad Husqvarna 50:1 fuel/oil mix.
    Oil Mix Ratio:
    The following ratios have been recommended for the last 10-15 years.
    Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1.
    1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
    4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
    McCulloch, Poulan & Wen; recommend 40:1.
    1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
    4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
    Chinese chainsaws recommend 25:1.
Starts and idles fine runs half throttle when fuel is applied
Harry, dirty carb or injectors.
Check the attached links,Manuals and guides, Good luck with your Bike
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
ATV TROUBLESHOOTING AND MAINTENANCE
ATV Service and Repair Manuals
http://www.carlsalter.com/motorcycle-manuals.asp
Jan 06, 2016 | ATVs
2006 attic cat 400 runs great in 4x4 but when you hit the switch to 2x4 runs bad like it's booging down
'03 400 backfiring/bogging under throttle - ArcticChat.com ...
www.arcticchat.com > ... > ATV's > General ATV Discussion
Apr 3, 2007 - 7 posts - ‎7 authors The engine would only sputter and bog down, kinda like the choke was hung. ... I didn't remember the fan running, so I checked the fan fuse, but it was ... of the windings and cause a misfire, so bad that it would kill the bike. '07 F8 intermittent start and bog issue - ArcticChat.com
Dec 23, 2012
Arctic cat suzuki 700 efi wont start - ArcticChat.com ...
Apr 28, 2012
400 4x4 idles but bogs out when throttle pressed ...
Jun 29, 2011
cat is slowly dying
Oct 10, 2008
More results from www.arcticchat.com
Oct 21, 2015 | ATVs
Chainsaw cranks and runs but after minute or two it dies. will start again but dies when trying to throttle up
Check the fuel tank vent. Does the saw leak fuel when laying on its side.? Faulty vent can cause the saw to bog down when running
Nov 20, 2012 | Husqvarna Garden
Engine looses power after 30-45 minutes.
When it starts to die just try slackening the fuel filler cap, if it picks up again it is a tank breather issue, if the breather is in the cap change it.
May 01, 2012 | Garden
6.5 turbo diesil starts and runs for 30 sec. or so
Fuel filter is plugged or, if your in a cold climate the fuel could be gelled.
Jan 04, 2010 | 1996 GMC Suburban
2003 Impala 3.4 missing/dying
1 Inspect Timing Belt SlipPED or Broken Timing Belt. 2 Inspect Timing Chain SlipPED Timing Chain. 3 Inspect Timing Set SlipPED Timing Chain or Worn Timing Gear(s). 4 Inspect Fuel Injector Dirty or Worn Fuel Injectors, or Vacuum Leak in Fuel Injection System. 5 Inspect Carburetor Incorrect Carburetor Adjustment, or Vacuum Leak at Carburetor. 6 Inspect NEEDLE Seat Dirty, Worn, or Damaged Carburetor NEEDLE and Seat. 8 Inspect Timing Specification Incorrect Ignition Timing. 9 Inspect PCV Valve Clogged Emission System. 10 Inspect Wireset Worn, Damaged or Faulty Spark Plug Wire(s). 11 Inspect Distributor Cap Distributor Cap Cracked or Burned. 12 Inspect Spark Plug Fouled, Damaged, or Broken Spark Plug(s). 13 Inspect Intake Manifold Gasket Leaking, Worn, or Damaged Intake Manifold Gasket. 14 Inspect Crankshaft Gear Worn Timing Gear(s). 15 Inspect Camshaft Gear Worn Timing Gear(s). 16 Inspect Distributor Cap and Rotor Kit Distributor Cap Cracked or Burned. 17 Inspect Valve Burned, Worn, or Sticking Exhaust Valves. 18 Inspect Camshaft Worn Camshaft LOBE(s). 19 Inspect Valve Lifter WornValve Lifter(s). 20 Inspect Belt Incorrectly Routed, Adjusted(Tensioned), Missing or Worn Drive Belt(s). 21 Inspect Alternator Low or No Voltage OUTPUT From Alternator/Voltage Regulator. 22 Inspect Voltage Regulator Faulty, Shorted or Incorrectly Connected Voltage Regulator. 23 Inspect Relay - Charge Lampat Damaged or Faulty Charging Relay.
Aug 31, 2009 | 2003 Chevrolet Impala
Runs great for 30 sec. to 1 min. then dies slowly
Is it your chain saw Husqvarna 40?
Try carb adjustments H-3/4 turn ,L-2 turns and T a little higher
I presume that compression and ignition sistem is adequate for the engine to run.Good luck
mihai
Apr 04, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
1,201 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
