Question about Polaroid TLA-01911C TV
Hi polaroid tla-01911c white screen no sound cannot change channel if this is manually fixed or cleaned what am i looking for plz help
Polaroid LCD has white screen and no sound
Posted on Jan 11, 2011
Fix sound on Polaroid TLA-01911C TV
Audio amp may be blown. A cable may be bad.
What are you connected to?
Apr 04, 2014 | Polaroid TLA-01911C TV
When I turn on my tv the screen is white and nothing else happens.
This is a common symptom of a power supply failure on the TLA-01911c. The board has parts called capacitors that filter the output power and when they go bad the power supply does not power up right. The unit can either have no power, just a flashing power light, just a white screen or it could take a long time to show a picture. Here is a link to a repair guide that shows what to replace on the power supply board to repair the unit.
http://www.ccl-la.com/blog/index.php/repairing-a-polaroid-fla-01911c-with-a-bad-power-supply/
I hope this helps you get your TV bad up and running,
BuddyMc
Jul 13, 2012 | Polaroid TLA-01911C TV
POLAROID TLA-01911C turns on but only white screen. no sound
Hello
The main board has the fault. Your set need a thorough check before confirmiing the fiault.
This is the picture of the board. OK.
Feb 16, 2012 | Polaroid TLA-01911C TV
My TV has a white/gray screen when I turn it on. I get nothing else, no sound either.
A white or gray screen usually means the power supply board is not functioning correctly. Below is a repair guide showing what to look for on your power supply board. Open the back of your TV and look at the power supply board as shown in the repair guide. If the capacitors are bulging on the top then they have failed and replacing them should get the board and TV back up and running. This is a very easy repair if you can do a little soldering.
http://www.ccl-la.com/blog/index.php/repairing-a-polaroid-tla-01911c-with-a-bad-power-supply/
I hope this helps,
BuddyMc
Sep 12, 2011 | Polaroid TLA-01911C TV
Need a manual for Polaroid TLA-01911C
http://www.hdtvreview.com/Polaroid-TLA-01911C-hdtv.html
May 07, 2011 | Polaroid TLA-01911C TV
Hi the tv just went to a white screen..nothing..what could be the issue..
Ur tv still have sound when the screen are white?Yes?The Tuner board is dead,need it replaced.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
May 21, 2010 | Polaroid TLA-01911C TV
PROB LEM WITH POLAROID TLA-01911C
The white screen and nothing else usually indicates a failure of the filter capacitors in the power supply board. When these capacitors go out the voltages are not correct so the TV can not power up right. You can rebuild the power board by replacing the bad capacitors and this should bring the TV back to life. Here is a link to a repair guide for this power supply board.
I hope this helps,
BuddyMc
Dec 28, 2009 | Polaroid TLA-01911C TV
Polaroid TLA-01911C TV - I seem to have the same
You probably have a bad inverter PCB. It is a skinny board by itself over on the left side of the back of the panel.
Oct 12, 2009 | Polaroid TLA-01911C TV
Polaroid 19" TV TLA-01911C has no picture. Powers up, see logo
I had the same problem. I replaced 14 capacitors on the Power supply board. I used Panasonic FC series. You could look for swollen capacitors or ones that are oozing. For sure replace these. My set had capacitors that are known to cause problems so I replaced all of them even though I saw no swelling of oozing. Be sure you label all connections carefully when you disassemble.
Jan 17, 2009 | Polaroid TLA-01911C TV
Polaroid TLA-01911C TV Logo
1,053 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
