Question about Hayward SAND FILTER, PRO SERIES
I have a hayward S244T sand filter and the lettering on top of the handle is gone and I don't know anything but filter and backwash I would like to know if it has a recirculte position and where it is on the handle
    President:
  • Hayward Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
The 'manual' for their multiport valves, found here, shows the layout of your settings.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Jul 30, 2010
I cannot read the diagram on top of my hayward sand tank filter pro-series s244t filter,close,waste which way
go to westport pools.com and see if you can find a picture of it or go to hayward filters..
Jan 06, 2014 | Hayward SAND FILTER, PRO SERIES
Hayward 220T pool filter is leaking water; could it be the multi-port valve needs to be replaced?
if coming out of top where handle is yes if out backwash line yes make sure unions are tight also
Dec 30, 2013 | Hayward SAND FILTER, PRO SERIES
Hayward sand filter
Reference your pressure gauge as the 12:00 position. Going clockwise-
12:00 is Filter, normal running position
2:00 is Waste, water goes from pool and exits the waste line, bypassing filter.
4:00 is Closed, used only when servicing equipment
6:00 is Backwash, reverses water through the filter and goes out the waste line.
8:00 is Recirculate, water bypasses filter and returns to pool.
10:00 is Rinse, water goes through filter and exits to waste line, used briefly after backwashing to clear sediment from filter.
Note that the "pointer," not the handle that you grab, indicates which setting you are on.
May 19, 2013 | Pool & Spa
The labels at the top of my pool has faded. I don't know which slot is for backwash? Does anyone know which slot is for what? I need to re-label my lid to know which one is off, on, pump, backwash...
typical is opposite of filter easiest solotion would be to try it water should come out of the waste/backwash port 1200 oclock is filter 6oclock might be backwash
Jun 26, 2011 | Hayward SAND FILTER, PRO SERIES
I have a brand new S244T sand filter. During backwash cycle large amount of water discharges out of the waste line. Filter doesnt appear to be backwashing normally. Hayward is sending a replacement head. I...
When backwashing with this valve, it is supposed to come out the waste line. Also when in "rinse" and "waste" it will also come out the waste line. It is acting just how it is supposed to act.
May 26, 2011 | Hayward Pool & Spa
We have a Hayward Pro Series sand filter S244T. It was installed 3 years ago. There is no indication of flow through the glass bulb on the back of the valve when the valve is in normal operating...
The sightglass is designed for backwash only, it allows you to see the degree of clarity in the effluent water. There should not be flow through the sightglass when the filter is in normal operation. Sometimes the pump will be alot louder when you backwash because there is alot less back pressure and it sometimes causes pump cavitation. The pump should quiet down when in normal filter mode. If not, there may be problems with the bearings and/or cavitation.
Aug 15, 2010 | Hayward SAND FILTER, PRO SERIES
Out of the ground pool-hayward sand filter
This one is easy...
You simply fill your pool to the normal level which is at the top of the skimmer.
Now apply the "Shock" treatment to begin clearing the water.
With the pool full, attach the hose for back flushing to the filter 'Outlet" or discharge side and then move the selector handle to the "backwash" position and turn the pump on. It will begin discharging water out of the hose. Run it this way until it begins sucking air.
You have now "backwashed" your filter.
Fill the pool back to the normal level and finish treating water to get the Ph and Chlorine right.
Enjoy swimming.
Jun 01, 2008 | Dehumidifiers
Hayward SAND FILTER, PRO SERIES Logo
196 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
