Question about Samsung RS2630SH Side by Side Refrigerator
My fridge is not functioning well.
Basicly, both parts of my refridgerator are not working. none of them are keeeping cool and their right tempretures are not what they should be.
    Genius:
  • 1,224 Answers
Possible freon leak have repair man come out and check the freon levels and give you full diagnostics
Posted on May 13, 2008
Small fridge no fan /freezer works but fridge doent cool
Unless the fan works there will not be any flow to the fridge section as the cooling comes from the freezer coils. check the fan and replace after checking the power to the fan.
Jan 30, 2013 | Kenmore Refridgerator Air Flow Diffuser...
My Amana refridgerator does not cool but the freezer works
If you have noticed a rise in temperature in the fridge, and there seems to be fromst building up in the freezer than your problem is one or more parts of the defrost system is malfunctioned and in return your problem arises. There are three parts to the system, the defrost timer or in some cases control board, defrost thermostat also known as a bi-metal, and the defrost heater. The defrost system is set up to operate as so. The defrost timer or control board will turn the machine off, in some cases every 8 hours, some 12. During this time period the defrost heaters, located behind the freezer wall and rest underneath the evaporator, yet wires to them run up the side of it, are energized and emit heat that raises upward to melt the ice that has formed on the evaporator coils. The bi-metal or defrost thermostat is at the top of the evaporator. When the heat from the heater starts to reach the bi-metal, it breaks the circuit turning the heater off. The whole purpose of this is because the freezer cool the refridgerator side by drawing air across the coils and blowing to the other side via the evap fan motor. In my opinion, if you change one part of the defrost system change them all because usually when one part fails another will follow, so save yourself the time and the food loss, the cost difference is minute.
Sep 07, 2012 | Amana Refrigerators
Top freezer refridgerator freezer works refridgerator not cold. back coils are warm.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Mar 24, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Fridge part is not cooling well
You have a blockage in the system. Need a technician to come and replace the drier and regas system. Will run correctly after that.
Sep 18, 2009 | Whirlpool ET1FHTXM Top Freezer...
MAYTAG REFRIDGERATOR NOT COOLING
Check to see if the evaporator fan is blowing. Sometimes removing the back panel to expose the fan and hand turning it can make it come back on. If this doesn't work then the fan is bad. Also make sure that there is good circulation to the fridge side. Food can sometimes block air flow.
Jul 01, 2009 | Maytag MSD2651 HE Side by Side...
Maytag refridgerator not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 06, 2009 | Maytag MSD2651 HE Side by Side...
Fridge not holding tempreture
if there is frost present on the rear vertical wall of the freezer compartment then the defrost function is broken and needs to be repaired the freezer is like an ice block and yo get cooling up to the refridgerator compartment air has to be able to flow and that can't happen if the frost is not eliminated
Dec 15, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refridgerator isn't keeping cold
its in the freezer when you open yhe door the compressor is in the back take the cover off and see if trhe compressor is running
Apr 03, 2008 | Refrigerators
Kenmore refridgerator c1065094881
It sounds like your defrost cycle has stopped working. unplug your fridge for 24 hours and let it defrost. plug it back after 24 hour and if it starts to cool in the fridge part at about 40 degrees F. you will have to replace one of three parts the Defrost Timer, Defrost Themo or Defrost Element. I hope this helps you.
Dec 22, 2007 | Refrigerators
My LG LRBN20514ST Fridge is not cooling
where to look for the defrost timer on the LG top freezer modle
GR-S392GCA
Aug 26, 2007 | LG LRBN20510WW Bottom Freezer Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
176 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
