Question about Coleman Heating & Cooling
Freezes up. turn on fan and ice comes through holes on bottom of unit. then it will work again.
  • country_l255 Jul 30, 2010
    We had a air conditioner man come and fill it up with freon so it's full we herd that it could be the defrost board?
    President:
  • 1,796 Answers
Hi!!
Most likely your unit is low on R-22 Refrigerant, refilling the system will fix the problem.
Don't forget to rate this post. Good Luck!!
Posted on Jul 30, 2010
Testimonial: "Thanks alot for your advice, we will check the sensor."
  • Rene J Solis Jul 30, 2010
    Ok, we can rule that one out!! : )
    There is a skinny tube (usually covered in plastic attached to the front coil, that is the thermostat sensor, designed to cut the compressor when the set temp. is reached and avoid coil freeze up, if the sensor is not attached to the coil, or is defective, it will send the wrong signal and the compressor will keep going. So check thermostat operation.
    Another cause of evaporator coil freeeze up is a dirty/clogged filter or evaporator. Make sure both are clean.
  • 767 Answers
Hello my name is Heath it will be my pleasure to assist you. There is a couple reasons why air conditioners freeze up. One is lack of air flow check the filters and be sure the evaporator coil or the indoor coil are not plugged with dirt or debris. The second reason is the unit is low on freon and starving the condenser so the evaporator freezes up.
Water leaking from the freezer unit.
The drain hole is probably frozen over. When it goes into defrost mode every 10 hours or so, the evaporator heater removes the ice from the evaporator. There is a drain hole under the evaporator with a hose attached that goes down to a pan by the compressor fan where it is evaporated so as to not leak water on the floor. When it freezes over the drain, the water fills the bottom of the freezer until it comes out the door. A common fix to prevent the drain from freezing over is to take a bare copper 14 or 12 gauge wire and put a couple turns around the evaporator heater and stick the other end into the drain. This heats the wire enough to keep water from freezing b over the drain hole.
Dec 09, 2013 | Jenn-Air JFC2089HE French Door...
Hotpoint FFA71 NOT DEFROSTING
Self defrosting feature is not working. Check defrost thermostat, defrost heater, defrost timer for proper operation.
Until repair is made, defrost the unit and turn back on until it freezes up again. Check the ice block at rear of freezer. If the ice is confined to the area around the refrigeration line coming into the freezer it is low refrigerant level. If the block completely covers the evaporator it is a non working defrost mechanism.
Nov 21, 2013 | Hotpoint FFA70 Bottom Freezer Refrigerator
Freezer won't freez and the bottom nearly cools
I think you need to repost or clarify. You are asking why the freezer on your maytag gas dryer wont freeze. Assuming you have a split frig/freezer.... and assuming the compressor is working.... most common problem is either the fan motor is bad or possibly seized up with ice. Also the coils may be completely iced over. You can take two approaches here... Either turn the unit off and let it completely defrost, and let all the ice melt. Also best to tilt it to drain pooled up water after it melts. Or... you can remove some panels (sometimes difficult to do), and access the fan blower and coils. Once you get to the fan blower and coils check and make sure fan is blowing. let all the ice melt. A blow dryer works good for this, or just let it sit, and again make sure you tilt it and drain any pooling water. Also you should clean all the dirt, fuzz, and scum from under the unit around all the coils, and fans behind and below the unit.
Sep 18, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Bottom freezer is leaking water. Water seems to
You have a clogged defrost drain. The problem is fixed by unplugging unit from wall, open both doors, blow fan for 24 hours to SAFELY remove the ice covering the drain hole. If you use ANY other method, you may regret it. Once ice is melted, remove debris that is likely blocking the small drain hole, if no debris in drain pan, direct some high pressure air down the drain to block the debris INSIDE the tubing. Furthermore, its a good idea to make the drain hole in the drain pan larger, as sometimes a bubble of water can freeze in the drain hole, and ice could be the cause of your blockage from that bubble.
Jun 28, 2010 | Amana ARB1905C Bottom Freezer Refrigerator
WATER FREEZES ON THE BOTTOM OF THE FREEZER
I have an LG armoire style fridge/freezer and it had lots ice in the bottom and would eventually drip onto the floor. The problem was with the defrost controller. The moisture that enters the freezer when it is opened condenses and freezes on the freezer coil/fins. There is a heating element that sits under this coil which gets turned on by the defrost controller to melt the frost/ice. As the frost/ice melts it drips into a metal tray which channels the water to a drain hole to have it drop into the drip tray underneath the unit for it to evaporate. The problem is that the before the water has time to leave the freezer, it freezes thereby plugging up the drain hole and thus causing subsequent defrost cycles to have the water flow into the bottom of the freezer where it freezes. Eventually the bottom of the freezer fills up with enough ice for the melted water to flow onto the floor. I had my defrost controller replaced (just outside the warranty period!) and it worked for about 1-month and then same thing happened again. Instead of paying for another defrost controller that would probably not work 100% my serviceman used the old paper-clip trick. He took a paper clip, stretched it out and then wrapped one end around the heating element and placed the other end into the drain hole. Thus when the heating element comes on the paper clip keeps the drain hole warm/hot and prevents the water from freezing. It has been 9 months since this fix and I haven't had any ice pooling in bottom of the freezer.
When I had the problem and started diagnosing it I opened up the freezer, pulled out the racks, draws, and eventually the door. Then I removed the ice maker and then a few screws and carefully removed the back white wall panel disconnecting the fan and any other electrical connections. Behind the panel you will see the cooling coil/fins, the heating element, the drip pan, and drain hole. Most likely you will see a sheet of ice everywhere. The best way to remove the ice is to boil a bunch of water in a tea kettle and slowly pour it on the ice to get it to melt so that you can start breaking out the pieces. Have a sponge and bucket ready to remove the water as the ice starts to melt. Eventually you should get all of the ice removed and get the drain hole unplugged. After all the ice is removed, you still need to fix the real problem by replacing the defrost controller, using the paper clip trick, or both.
Sep 22, 2009 | Maytag Refrigerators
My bottom refrigerator is not cold. The freezer is okay.
Check to make sure the fan in the freezer compartment is working and not blocked. This delivers the cold air to the refrigerator. The fan should run every time the freezer calls for cold.
Jul 22, 2009 | Refrigerators
LG Bottom Freezer Frost Issue
It sounds like your defrost controller has gone bad. I have an LFC25760 and had ice build up in the bottom of the freezer such that water would start leaking onto the floor. The ice build up in the bottom of the freezer was due to a failing/bad defrost controller. Behind the back white wall in the freezer compartment exists the cooling fins along with a heating element underneath. Due to moisture that comes into the freezer from opening it, frost/ice builds up on the cooling fins. Thus the defrost controller turns on the heating element to melt the ice/frost off of the fins which then drips into a metal pan which channels the water to a drain hole which drops into the drip pan underneath the fridge next to the fan. The problem is that the defrost controller doesn't keep the heating element on long enough or the cooling cycle comes on too soon thereby freezing the water and plugging up the drain. I had my defrost controller replaced (just outside the warranty period!) and it worked for about 1-month and then same thing happened again. Instead of paying for another defrost controller that would probably not work 100% my serviceman used the old paper-clip trick. He took a paper clip, stretched it out and then wrapped one end around the heating element and placed the other end into the drain hole. Thus when the heating element comes on the paper clip keeps the drain hole warm/hot and prevents the water from freezing. It has been 9 months since this fix and I haven't had any ice pooling in bottom of the freezer.
Jun 22, 2009 | LG LRFD25850 French Door Refrigerator
WATER POOLIN AND FREEZING AT ON FLOOR OF FREEZER. ICE MAKER NOT HOOKED UP
you have a blocked drain remove back freezer panel
at the bottom you will find a lot off ice remove it with hot water and clean drain hole the pop is the ice cracking
Apr 17, 2009 | Refrigerators
Kenmore refrigerator freezer not freezing
Yes that is a proplem...when ever that compressor is running that fan motor should be running too.. also you evapurator fan motor should be running also
Aug 20, 2007 | Magic Chef CTB1722 Top Freezer...
Heating & Cooling Logo
106 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
