Question about Texas Instruments TI-84 Plus Calculator
How do i get rid of shadeRes in my window T84
  • Texas Instru... Master
  • 8,073 Answers
You might have activated the application called Inequalz. It solves inequations. One of its feature is the shading of solution regions and the resolution of the shading is called ShadeRes. When you press the Window function key you see the ShadeRes value before the usual window dimensions.
To get rid of the Inequalz application (kick it out of memory without removing it completely from calculator)
  1. press the Apps key.
  2. Use downArrow to put focus on Inequalz and press ENTER
  3. In the new screen that is displayed "INEQUAL RUNNING" select [2:Quit Inequal].
Posted on Aug 05, 2010
How do I remove the SIM card from the ZTE T84?
TELSTRA T84 - User Manual - ZTE Australia
www.ztemobiles.com.au/downloads/User_guides/T84_Help%201.1.pdf
Sep 1, 2015 - Hold the SIM card with the cut corner as shown below and push it fully into the SIM slot until it clicks and locks into place. 3. Make sure to fully close the SIM slot cover to maintain water protection integrity. INSTALL A MICRO SD CARD (OPTIONAL). A microSD card can be installed or removed while the ...
How to remove a sim card zte maven - YouTube
? 0:25
https://www.youtube.com/watch?v=dLJu9X-3JO4
Feb 4, 2016 - Uploaded by ALBERTO CESIN
Remove sim card maven.
How do I remove the SIM card from the ZTE T84? - Fixya
www.fixya.com/support/t26884640-remove_sim_card_from_zte_t84 28 mins ago - Hi, a 6ya Repairman can help you resolve that issue over the phone in a minute or two. Best thing about this new service is that you are never placed on hold and get to talk to real repair professionals here in the US. click here to Talk to a Repairman (only for users in the US for now) and get all the help you ...
[PDF]TELSTRA T84 - User Manual - Product Review
https://s.productreview.com.au/products/manuals/319619_581c16cc16314.pdf ZTE Australia provides dedicated support with a local call centre and social ... Hold the SIM card with the cut corner as shown below and push it fully ... remove the battery. • With low network signal conditions battery life is reduced. • Turn off Bluetooth and Wi-Fi when not in use, and set the screen brightness to automatic to ...
Telstra Tough Max T84 Questions & Answers - ProductReview.com.au
https://www.productreview.com.au/qa/telstra-tough-max.html how to remove sim card from telstra tough ZTE T84. pam.fraser.1253 asked on Oct 19, 2017. Answer this. brian. I used my fingernails though, you could possibly use a tiny screwdriver if you like. brian replied on Nov 11, 2017. brian. Once you've opened the hatch at the top just tip the piece of trash upside down above ...
Feb 10, 2018 | ZTE Cell Phones
I ring they do not know it is me t84
Is there a question here? What is 't84'?
Dec 01, 2016 | Lands Phones
Incline raises full and wont go down,t84
1)signal false coming console or display board
2) main motor controller is faulty.
3)Pot attached of the elevation motor ,need adjustment
4) geared slip from elevation motor , carring false signal to console.
Proceed to Test it.
Dec 11, 2011 | Horizon T84 - Treadmill
I can't play pes 2010 because of gpu shader 2.0
Direct X 10 GPU with full Shader Model 4.0 support delivers unparalleled levels of graphics realism and film-quality effects.is what the manufacturers web site says
RECOMMENDED SYSTEM REQUIREMENTS:
[for the game]
* Windows XP SP3, Vista SP1
* Intel Core2 Duo 2.0GHz or equivalent processor
* 2GB RAM
* 8GB free hard disk space
* 8x DVD-ROM Drive
* DirectX 9.0c compatible video card. 256MB Pixel Shader 3.0 (NVIDIA GeForce 7900 or AMD/ATI Radeon HD2400 or better)
* DirectX 9.0c compatible sound card
* DirectX 9.0c or higher (included on Disc)
* Multiplayer: TCP/IP Broadband Internet connection
* Windows compatible USB Gamepad
* 1280 x 720 monitor resolution
where can i get a "GPU Shader 2.0?"
you need a new graphics card, shaders are a hardware limitation.
you can try to update the card http://www.pcpitstop.com/drivers/download/NVIDIA~GeForce~9500~GT.html i hope this helps you and please vote for me
Dec 02, 2010 | PNY TECHNOLOGIES NVIDIA GEFORCE 9500GT...
Error code t84 ???????? anyone
Hi stuiejohnsto,
As far as I know there is no error code t84. The closest code that has the numbers 84 in error code CC-184.
Anyways, whatever code you may have, it's worth turning the machine off for 10 seconds by the Main ON/OFF swich (inside front door on the left).
With any luck your code should disappear. If not, can you let me know if it gives you a different code to t84
Thanks
Good luck
Tam
Mar 22, 2010 | Konica Minolta Bizhub c203 Copier
How do u get rid of the ShadeRes in your window setting?
Well, that depends.
The real question is: What are you trying to graph?
If you want to graph function y= f(x), then why are you using the Inequalz application, which draws inequations. The ShadeRes(olution) is a system variable needed by the Inequalz application. You can use the default 3 value or change the value to 4, 5, 6, 7, 8.
When Inequalz runs it takes over the graphing functionalities and impose some changes in the calculator configuration, and one of those changes is the appearance of the ShadeRes variable in the Window configuration screen. Also, once the Inequalz App is launched, it remains in memory until you kick it out of Ram, or clear the RAM
My hunch is that you should not be running Inequalz, so I will show you how to unload it of memory so that you can draw your "regular" graphs.
UNLOADING INEQUALZ
  1. Press the [APPS] key
  2. The screen INEQUAL RUNNING is displayed with the following selections
  • 1:Continue
  • 2:Quit Inequal
  • 3:About
You press [2:Quit Inequal] to unload the Application from the memory.
Return to your regular graphing and a Window configuration screen without the ShadeRes variable.
TO SUM UP
If you are drawing inequations with Inequalz, you cannot get rid of the ShadeRes variable. You can only give it another acceptable value.
If you are drawing "regular" function graphs, unload Inequalz from memory.
Jan 21, 2010 | Texas Instruments TI-84 Plus Calculator
Pixel Shader is unavailable for pet vet 2 what does this mean?
it means that your graphic card does not support the pixel shaders...
Pixel shaders are used to improve the quality of an image..
Oct 24, 2009 | ValuSoft Paws & Claws Pet Vet 2: Healing...
Rise and Fall, Civilizations at war
i thiink your gfx card does not support required version of pixel shader....google for ne hack of pixel shader for the game..
Aug 24, 2009 | Midway Home Entertainment Rise & Fall:...
Texas Instruments TI-84 Plus Calculator Logo
3,052 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
