Question about Sony Televison & Video
When pressing the guide button, This function cannot be used now appears on the screen
  • pfgander Jul 31, 2010
    The guide was allways available before, suddenly it has dissapeared
  • 115 Answers
The guide is not available in certain modes, This is completely normal.
Posted on Jul 31, 2010
How do i get the internet explorer message that appears from time to time off the screen of motorola mc3190 without having to shut it down
The key combination you looking for to close any window or message in a Windows environment is ALT+F4, depending on the type of keypad the Motorola MC3190G are using.
Please Note: Keypad functions can be changed by an application so the mobile computer keypad may not function as described.
48-Key Keypad
The ALT functions are indicated in blue on the keypad, so in order to use these, you have to activate the ALT Functions first by pressing the BLUE BUTTON (FUNC) (Right side below ENTER button) and then press the CTRL BUTTON (left side below BKSP button).
After the key combination is pressed, the ALT icon appears on the taskbar on WinCE devices or the ALT icon appears at the bottom of the screen on Windows Mobile 6.5 devices.
Now you can press the "D" button to use F4, this will close any window or message that is currently in view.
38-key Keypad
Press the blue FUNC BUTTON (Right side below RIGHT ARROW button), and then press CTRL button (Middle below UP ARROW button), now you can press the F4 button.
28-Key Keypad
Press the blue FUNC button (Bottom right next to Power button), and then press the CTRL button (Top right side below RIGHT ARROW button), now you can press number 4 to use F4.
Hope this helps, good luck.
Jul 02, 2014 | Zebra Symbol MC3190G Handheld Mobile...
'tab' button doesn't work on Motorola MC3190
You get 3 different keypad models of the Motorola MC3190:
- 28 Key Numeric
- 38 Key Shifted Alpha
- 48 Key Alpha Numeric
So depending on the type of keyboard your model has, using TAB are different across these 3 keypads.
When the FUNC button is pressed the icon "F" appears on the taskbar on WinCE devices or the icon "Blue Circle" appears at the bottom of the screen on Windows Mobile 6.1 devices.
In order to use the TAB function, do the following:
28 Key Numeric - Press the blue FUNC button (Bottom right next to Power button), and press the RIGHT ARROW button.
38 Key Shifted Alpha - Press the blue FUNC button (Right side below RIGHT ARROW button), and press the RIGHT ARROW button.
48 Key Alpha Numeric - Press the blue FUNC button (Right side below ENTER button) and press the number 9 button.
Apr 18, 2014 | Zebra Symbol MC3190G Handheld Mobile...
Need to set clock on oxo timer
I also own this model, and the manual isn't availble on OXO's site. But this is what I've learned over the years:
To set clock:
  1. Press and hold clock/timer button for 3 seconds (clock icon will appear on left side of screen).
  2. Input time using keypad then quickly press clock/timer button to save.
To set timer:
  1. Press and release clock/timer button.
  2. If necessary, press clear/memory so timer reads all zeroes.
  3. Enter desired time using keypad (to a maximum of 99hrs:99mins:99secs).
  4. Press stop/start to begin countdown.
  5. Pause countdown by pressing stop/start; resume by pressing button again.
  6. When countdown is complete, timer will beep continuously for 30 seconds and display will flash. Timer will then beep every 10 seconds for 10 minutes until the stop/start button is pressed.
  7. Press clock/timer button to return to clock function.
To time activities:
  3. Press stop/start and plus (+) sign will appear on right side of screen as timer begins counting up.
  4. Pause count-up by pressing stop/start; resume by pressing button again.
  5. When you're finished timing, press stop/start to end timing function.
  6. Press clock/timer to return to clock function.
Sep 30, 2013 | Oxo Good Grips Digital Stainless Steel...
Need manual for oxo #1061978 timer
I own this model also and OXO doesn't offer the manual online. So here's what I've learned to do:
To set clock:
To set timer:
To time activities:
Mar 07, 2013 | Oxo Hardware & Accessories
Instructions for oxo model 1061978
To set clock:
To set timer:
To time activities:
Feb 17, 2013 | Oxo Hardware & Accessories
Pioneer plasma elite pro-504pu how do reset to factory mode on standby mode >??
hi,
u cam reset ur only by the following way.
p { margin-bottom: 0.21cm; }
In order to enter Service Mode, TV guide must be turned off
In order to do this procedure you must have and use the correct remote. The full function remote that
came with the set has a TV Guide Logo in a red box. This is the remote you should use.
NOTE: If TV guide has not yet been setup, then the 1st step is to follow instructions to set TV guide up.
Enter ZIP code, cable or ant. Etc.
1.press and release the "TV Guide". TV guide will appear on the screen.
2.Navigate to the TV Guide tool bar and use the ">" button to select "setup" in the menu and press
and release the "enter" button
3.use the "arrow down" button to select "default options"
4.press and release the "enter" button and select "general defaults"
5.press and release the "enter" button (opens menu on lower left side)
6. use the "arrow down" button to select "auto guide"
7. use the ">" button to select "off"
8. use the "arrow down" button to select "done"
9. press and release the "enter"
10. press and release the "TV Guide" button to turn the display off
System Reset Using Service Mode:
1. Enter Service Mode
2. Use the "muting" button to select "initialize" screen
3. While on the "initialize" screen
4. Use the "down arrow" button to select "final setup"
5. Press and release the "enter" button to select "data reset"
6. Use the ">" button on the remote to select "yes"
7. Press and hold the "enter" button until the screen goes black release "enter" button on remote.
8. Power the unit off using the remote control
9. Unplug the power cord from the media receiver to complete the reset
10. Plug in the media receiver; turn the system on and reset is complete.
ok
Jan 11, 2011 | Pioneer Televison & Video
I lost the manual to the Canon LaserCLASS 510 and need to delete one of the fax numbers already programmed. I know it's a simple step, but everything I've tried hasn't worked. All I want to do is edit the...
If you still need the manual I have the electronic version of the Reference and Facsimile guides
You may want to print the list of the speed dial numbers before so you know which one(s) you want to edit and to have a backup list in case something bad happens -> Additional Functions button then press arrow keys until 8. Print Lists appears then press Set button. Press arrow keys until Print Lists appears then hit Set button then use arrow buttons until Speed Dial List appears then press Set then select the list you want to print (1-Touch, Coded Dial or Group List)
Additional Functions -> press arrow keys (or plus/minus) until 5. Add. Registration appears then Set button
Presss arrow keys until 2. Coded spd dial appears then press Set button
Press Coded Dial then enter the 3 digit code for the number you want to edit (or use plus/minus) then press Set button
Press arros keys until 1. Tel number entry appears then press Set button
Jun 09, 2010 | Canon LaserCLASS 510 Printer
I tried to draw a graph manually but I kept getting an error message even thoug I did it step by step like the users guide instructions said
Error messages are important to help solve the problem.
Try the following instructions to draw the function Y=5X+2
but first Reset the calculator by pressing the RESET button on back of calculator. I do not want you to run into problems created by old settings.
  1. Turn calculator ON. If you do not see several icons press [MENU].
  2. Use arrow to select the [GRAPH] application and press [EXE].
  3. In the entry screen, the line with Y1= is highlighted. If it is not, use arrow to highlight it.
  4. Press the right arrow, the highlighting disappears leaving you with Y1= and the blinking cursor.
  5. At the position of the cursor type 5 then press the [X, theta,T] key, under the [ALPHA]. On the screen appears 5X, complete your equation by typing [+] 2
  6. Press [EXE] to store function.
  7. If you want to draw other functions, it is time to do so on that screen.
  8. When done, press [F6:Draw].
  9. If the screen does not show a lot of the function, you can use the arrow keys to pan (move the center of the graph. You can pan Up, Down, Left, or Right.
  10. You can also press [SHIFT][V-Window] to set the window limits.
Feb 17, 2010 | Casio FX-9750GPlus Calculator
How do you turn the flash on? (with the vivitar vivicam 8018)
Your camera has a built in flash function which enables you to take photos when the light condition is not good.
1. Press the Up button. (for reference of buttons, please see the below figure mentioned)
2. Press the Up button once until you see the icon appear on the LCD screen. This indicates that the flash is forced on.
3. Press the Up button again to change to the auto flash function.
4. The icon will appear at the top of the LCD indicating that the auto flash is turned on and ready to use.
5. Press the Up button again to change from the auto flash to the red eye function.
6. The icon will appear on the LCD indicating that the red eye reduction function has been activated.
7. To turn off the flash function, press the Up button again until the icon is displayed on the LCD.
Note: A “Low Power” message will appear on the LCD screen, if you select the flash function when the battery power is insufficient. To continue using the camera with the flash, please change new batteries
Feb 13, 2010 | Vivitar ViviCam 8018 Digital Camera
Formatting memory stick.
You can use the MEMORY FORMAT functions to completely delete all images and options on the Memory Card, including protected images. * The format function restores the Memory Card to its initial state. * The Memory Card supplied with this camcorder has been formatted already. Attention If you execute the MEMORY FORMAT function, all images will be erased completely and erased images cannot be recovered. 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to PLAYER mode. 3. Press the MENU button. 4. Turn the MENU DIAL to highlight MEMORY and press the ENTER button. The sub menu will appear. 5. Select FORMAT from the list and press the ENTER button. 6. "ALL FILES ARE DELETED! FORMAT REALLY?" appears on the screen. 7. Using the MENU DIAL, select the item. NO : To return to previous menu YES : To start formatting. 8. Press the ENTER button. If you selected the YES, COMPLETE! appears on the screen when the MEMORY CARD formatting is finished. 9. To exit the menu, push the MENU button.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Televison & Video Logo
85 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
