Monitor Problems (maybe something else)
I am currently having problems with multi-colored pixels popping up on my monitor while it is on. The pixels pretty much stay, and more pop up the longer the computer is on. When I drag windows, the pixels create 'lines' on the screen.
Is this a monitor problem, power supply, or video card?
  • Janice L Sep 05, 2008
    i's and l's display as blue while the rest of the letters are all grey/black in colour. Sometimes other letters as well but mainly those two.
    Genius:
  • 1,554 Answers
Sound like the video card is at fault,
when it happens , unplug the vga cable ,the monitor should go to a osd menu with or without the pixel,
plug back in to card is it still there or changed ,
sounds like the vga card is getting hot , fan may not be working.
Posted on Apr 25, 2008
Color problem
Posted on Aug 27, 2009
Sansui no signal
Acer produces a number of LCD computer monitors. Acer's monitors range from 17 inches to 27 inches. Some monitors offer wide-screen viewing, embedded speakers, high-definition visuals, and various display connection ports. Acer computer monitor problems include common issues such as dead pixels, error messages, and blank screens caused by incorrect connections. Some reviewers have also detected image problems with DVD playback on some models.
"Input Not Supported" Error Message Acer computer monitors such as the G24 may issue an "Input Not Supported" error message when users set the display resolution too high. The G24's maximum display resolution is 1920x1200 with a 60Hz refresh rate. Maximum resolutions vary according to the specific monitor model and according to the capabilities of the computer's video card. b> "Input Out of Range" b> Some Acer computer monitors may report an "Input Out of Range" error message due to incorrectly set monitor refresh rates. Much like the display resolution, each monitor also has specific monitor refresh rates with which it is compatible. Blank Screen or "No Signal" Error b> Like other monitors, Acer computer monitors feature color-coded power indicator lights. If the power indicator light shows green, the contrast or brightness levels may be set too low and should be adjusted via the OnScreen Display. If this does not rid the monitor of a black screen, the monitor may be experiencing hardware failure. The "No Signal" or "Check Cable message" may indicate a problem with the monitor's cable connection with the video card. This error may also appear on a blank screen backdrop if the monitor is plugged into the incorrect port on the computer or if the computer is frozen and needs to be rebooted. Faulty power cords or outlets may cause the screen to be black and to show no power indicator color. b> Image Issues b> Some review sites such as CNET have reported problems with streaking and ghosting during DVD playback on some Acer computer monitors such as the AL1931. (A "ghost" is an identical offset image as the primary or desired image.) Unstable or unclear image issues may be caused by incorrectly programmed VGA timings or incorrectly installed monitor drivers. b> Dead Pixels b> Dead pixels and sub-pixels can cause a variety of display enjoyment problems. Acer will only accept returns on LCD computer monitors that have "more than four (4) defective pixels per million pixels." Further, the central area of the monitor may have no more than one defective pixel. Acer does not differentiate in warranty terms between pixels and sub-pixels. Hope this helps.
Jan 20, 2013 | Acer Aspire 4720 Notebook
2 tiny black spots on screen, one looks like a check mark and one is a dot. Toshiba laptop satellite series. Dead pixels? How can they be fixed. Ran a program that is multi colored flashing lights to no...
Unfortunatly you do have dead pixels, but you cant fix them. Lots of lcd displays have them, some are more noticable than others, it dosent mean your lcd monitor is going to fail soon or anything like that, even brand new lcd monitors have dead pixels it is a comman anoying problem with them.
Sep 23, 2010 | Computers & Internet
Fuzzy screen on Gateway FPD1975W TFT LCD Monitor
With the pixels acting up and the monitor having the same problem on any computer that its connected to. The screen itself is bad and since there are no replacement screens for that monitor, you would have to buy a new monitor or get it replaced if its under warranty.
Jun 02, 2010 | Gateway FPD1975W 19" LCD Monitor
Monitor Shows pixelated colors then flashes no input and turnsoff
If it is a desktop, try another monitor and see if you're gonna get the same problem. If its a laptop, connect an external monitor to it. If the other monitor shows the same thing, it means to say that there's just something wrong with your video card. If that's the case, you might as well uninstall and reinstall the video driver. If in the other case, the other monitor's fine then definitely its your monitor. if there's a reset button or a factory reset button available on your monitor then reset it. If the same thing happens, get it replaced.
May 06, 2009 | Intel ASUS P4P800S-X 848P Socket 478 DDR...
Sudden lost of color gamma - "discoloration"
GO ON LINE AND SEE IF ANYONE ELSE HAS BEEN HAVING THE SAME OR SIMERLY PROBLEMS OR MAYBE A RECALL ON THAT CERTAIN ITEM.
ADDRESS BAR:
BENQ G2110W GAMMA ISSUES,
GAMMA FAILURE,
LOST GAMMA.
ENTER...................... AFTER EACH COMA
ANYTYPE OF PROBLEMS WITH BENQ G2110W
ENTER
GO ON TO ABOUT.COM, ASK.COM, INFO.COM
ROD
Feb 17, 2009 | BenQ G2110W 21" Monitor
Heavy white lines accross the screen
change the ram and viedo card agian
Jun 07, 2008 | Computers & Internet
Red pixels on the Srceen
Dead or stuck pixels are not uncommon in LCD displays, and the less you pay, the more likely it is to happen (as a general rule) Most manufacturers will a dead pixel warranty, ranging from 7 days to lifetime.
Read your warranty carefully, and speak to the place where you bought your display.
I hope that helps, if you have any further problems, please add them ass comments to this question. If I have been able to answer your question (or not) please click on one of the ratings buttons to let everyone know how I did.
Thanks for your feedback, and good luck.
Jan 14, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
On the Screen Red pixels comes in the background
hi
if you are see red pixels then your monitor haveing LCD Panel problume.
thanks
Ashok
Flickering, sparkeling, ghosting, you name it. Related to electricity in house?
No, it is not the electricity in your house, I had the same problem. Send it back to Samsung and get a new one. I have had to send my monitor back 4 times!
Oct 28, 2007 | Samsung SyncMaster 204B 20.1" LCD Monitor
Monitor problem
I have had similar problems. It would appear that the power supply is at fault, not the monitor.
Dec 27, 2006 | Microsoft Likom HD19A 19" LCD Monitor
Computers & Internet Logo
563 people viewed this question
David Payne
David Payne
