Error 024-965 paper is in tray, but it keeps saying to load the paper. I do not know much about fixing printer, could someone help me? Jen
  • collins0616 Jul 30, 2010
    the laser printer dell 3110cn is not printing due to error 024-965 paper is in tray but will not print due to error stating load tray. Please advise, I have cleaned wheels.
    Jen
  • 4,281 Answers
Turn off the printer.Pull toner cartridge from it then reconnect .Try with another cartridge then check. If still same issue then you need to do some servicing on fuser unit. For that open back cover of printer then you can find fuser unit open it from printer then open all parts of fuser unit like roller and other parts make sure roller is find and there is not any small paper pices.Clean sensor then check. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Jul 30, 2010
    dell 3110cn laser printer. I am not sure what to do in the back of the printer. It is like a foreign country to me in there. Please describe what you want me to check for. I did the toner removal and it didnot work
  • You have to check fuser umit of printer where paper moves.
    If roller is bad then you get this error.
    Also clean sensor of printer .
    Change roller if it is torn .Then it will work again.
    President:
  • 567 Answers
How to determine your paper feed jamming problems with a printer or copier. how to clean these parts or to determine that they need to be replaced.
  • First install new paper in tray and do not exceed tray limit.
  • Step 2second locate the paper feed tires, tires are grey or black and they contact the paper or will contact the paper when the machine energizes to feed the paper.
  • Step 3third take a flashlight and closely look at the tires to see if they are shinny or dirty from doing two sided prints or copies. never force the tires to turn, as this may damage the unit.
  • Posted on Jul 30, 2010
    • 1 more comment
    • Hilton Bristol Jul 30, 2010
    • if tires are shinny or dirty clean with rag and alcohol (put alcohol on rag only). new tires will have a texture to them when you shine a light on them. if dirty only, clean with light pressure. if the tires are shinny, clean with more pressure. retest and re-clean if needed.
    • Step 5if cleaning the tire several times and it is still shinny and won't feed the paper, you will need new tires.
    • Things You'll Need:
      • alcohol (rubbing not drinking)
      • good clean rag ( one that does not fall apart or leaves lint)( an old piece of bed sheet works great)
      please try this solution
    Hi Jen please uninstall the drivers for the printer and reinstall them again.
    Click on this link to get the latest updated drivers for the printer.http://search.la.dell.com/results.aspx?c...
    Make sure you choose your operating system before you download.
    Hp 5660 photo paper jam from placing in wrong tray.
    HP Printers - 'Paper Jam' Error ' HP® Customer Support
    https://support.hp.com/ca-en/document/c04348351
    This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
    Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
    https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
    Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
    help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
    https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
    A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
    HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
    https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
    Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
    https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
    Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
    ? 14:06
    https://www.youtube.com/watch?v=mrjGs1ahOjw
    May 17, 2016 - Uploaded by HP Printer Support
    Learn how to clear a paper jam hp 5660 photo paper jam Google Search
    Jun 20, 2017 | HP Office Equipment & Supplies
    Canon image runner ir 2520 says load paper but the paper is already on the paper tray please help
    To fix the error:
    - You select setting
    - Device Settings
    - Plain Paper Feed Settings
    - Set up on Rear Tray instead of cassette
    Oct 30, 2016 | Canon Office Equipment & Supplies
    Paper is inserted properly but error message keeps saying "Load paper face down in Main tray"
    i think the printer has 2 trays, one down and the other one on top from where you insert the paper. load the paper there as well. if there is only one tray then check the paper sensor in the bottom, if the paper end sensor comes out of position then it will not detect the paper.
    Jan 06, 2011 | HP Photosmart C6280 Printer
    We have a printer (MX870) that keeps giving us an error stating: there is no paper. There is paper in it but we cannot get it to print...it continues to give us the same error
    From the service manual about the paper issue this is what it says:
    ***Rear tray. There is no paper. Load paper and press [OK].
    Confirm that the rear tray is selected as the paper source. Set the paper in the rear tray, and press the OK button.
    ***Cassette. There is no paper. Load paper and press [OK].
    Confirm that the cassette is selected as the paper source. Set the paper in the cassette,
    Hopefully its just a setting on the printer or the computers printer properties.
    Best of luck..
    Jul 06, 2010 | Canon PIXMA MX870 Wireless Office...
    Paper jam
    check paper jam error you need do:
    1) between paper input tray and cartridge check any pieces paper
    2) between cartridge and fuser area do same thing
    3) check fuser and pressure roller(near fuser) any pieces of paper there
    4) after fuser to output tray
    all above step checking for avoid any pieces paper obstruct any sensor through all paper road, so that cause jam error
    hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
    May 25, 2009 | Brother MFC 8500 All-In-One Laser Printer
    My OKI B6300 printer have problem: "pull out all trays, clear jam" & "clear jam & close cover A" These 2 screens keep alternating. I am familiar with saying, "clear jam & close cover A" because I had...
    There are several reasons why this error keeps coming up, and seeing the date I will assume that you fixed it. But for those that are looking for the solution:
    Sometimes it is caused by the feed rollers not picking up the paper - remove the trays and replace the rollers ($30 kit) both in the tray and in the printer.
    Sometimes it is caused by a small piece of paper jammed in works somewhere. Remove all trays, turn it on its side and use a flashlight to look around. It really doesn't take much to mess it up.
    Take a look at the tray roller and make sure it is spring loaded. If the spring comes out or the retarder breaks tis will cause misfeeds as well.
    Feb 12, 2009 | OKI B6300n Printer
    Lexmark T644 MP Feeder STOP ASKING FOR MP FEEDER???!!!
    Thanks mate, it worked for me too and my works printers (work in IT and this 'error' was driving us crazy)
    Jul 29, 2008 | Lexmark T644 Laser Printer
    Xerox Phaser 8200 false "Replace Paper Tray" message
    I've had a similar problem with a client's 8200 printer, and looking at the right hand side of the tray someone had previously put some tape over the topmost 'slot' (above where the green slider goes across).
    I put some new tape over the top slot and the 'replace paper tray' message went away.
    Admittedly, the tape gets pushed in so I don't know how long it will be before the tape gets dislodged and the error re-appears.
    The printer is well out of warranty and they don't want to pay anything to get it fixed... so this solution is fine with them.
    Hope this helps someone else out there :-)
    Jul 02, 2008 | Xerox Phaser 8200 Laser Printer
    Tray 1- load plain letter
    Linda,
    On printer check media/paper type tray 2 or 3 is plain and tray 2/3 is set for letter paper size too, via printer control panel. Also check under paper handling other options for tray 1, also on tray 2 and 3, I think there is a blue little round switch on left should be set as letter not custom.
    Some paper types cannot be feed from anywhere else but tray1/bypass ie labels/laminate/card stock.
    Check print driver on pc has tray 3 option installed and is not set as default to print to manual bypass/tray 1
    light flashing cause printer wants paper type/size that it "thinks" it hasn't got in tray 2/3
    If that dont cover it...post back
    Soulvisitor :-)
    Dec 18, 2007 | HP LaserJet 4100n Printer
    Computers & Internet Logo
    99 people viewed this question
    Alun Cox
    David Payne
    David Payne
