Mitsubishi 65" 1080p DLP Projection HDTV (WD-Y65)
I own the above referenced television that I purchased in November of 2006, yesterday it started to shut itself down - showing a message for me to check if air flow is blocked. I check and there was nothing blocking air flow. A yellow light remains on in the front of the set and I cannot get it to stay on. The manual says this happens if the room is too hot, but that is not the case. I pressed the reset button hoping that might do the trick, but it didn't help. I also tried shutting the power completely to the tv overnight, but that did nothing either. Does anyone have any suggestions as to what the problem might be and how it can be fixed?
Thanks,
Cristina
  • 1 more comment
  • lguidry Jul 28, 2008
    We own the above referenced television that I purchased in December of 2006, it has recently started to shut itself down - showing a message for me to check if air flow is blocked. We checked and there was nothing blocking air flow. A yellow light remains on in the front of the set and I cannot get it to stay on. The manual says this happens if the room is too hot, but that is not the case. We pressed the reset button hoping that might do the trick, but it didn't help. Any sugestions?
  • Anonymous Nov 29, 2008
    I am currently having the same problem, I purchased the protection plan and thus far they have replaced the lamp itself 2 times, this has not solved the problem and they are to come out for a third time. I will post a resolution should they actually take the time to figure out the core root of this problem.
  • sbaldassano Jan 15, 2009
    I have the mitsubshi wd-y65 ser #104291 and last week the lamp went out after on year of use, I order a new one installed it on tuesday and it went out on friday. Ordered new lamp and now the tv has a burning smell, what does this mean? Please help.
  • 8,617 Answers
Have you cleaned the air filter located on the side of the set? If that doesnt work the thermal sensor will need replacing.
Posted on Apr 24, 2008
How do I fix white dots on my Mitsubishi DLP TV?
Hello. Please call Mitsubishi! Some models the DLP chip is covered under warranty, and all you have to do is pay labor costs, our shop charges $200.
May 11, 2016 | Mitsubishi WD-73827 73" HDTV DLP TV
Mitsubishi dlp wd y65 orange light blinks
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
May 07, 2016 | Mitsubishi WD-Y657 65" DLP Projection TV...
How do I view movies in 3D on the Mitsubishi WD-Y65?
WD-Y65 is NOT a 3D ready TV. You either have to change the TV to see the movie in 3D, or just watch it in 2D in you current TV.
I have the same TV as yours. Current I connect a desktop PC to the TV via DVI port, and I watch Avatar using colorcode 3D(Amber/Blue) with Stereoscopic Player from www.3dtv.at It might be a way for you to enjoy 3D without change the whole thing, but it's an entire different topic.
Jan 08, 2012 | Mitsubishi WD-Y65 65" HDTV
View 3D on wd-y65
Ur tv does nt support 3D. U can still see 3D if connected to PC. With power DVD 11 u can able to watch anaglyph 3D.
Dnt get confused any standard screen (e.g. CRT (big boxes with curved screen)) can view anglyphic 3D content.
Wd-y65 dlp, have sound, no picture, tv shuts down after about 30 seconds. tryed tv reset 3 times,did nothing
sounds like you need a new bulb, mine is doing the same and the lamp light is coming on.
Nov 01, 2010 | Mitsubishi WD-Y65 65" HDTV
How do I replace the bulb in my Mitsubishi WD-Y65?
hofferberr,
I have a tip at http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv which explains how to change the lamp, why when to change the lamp and where to get the best lamp at the best price.
Thanks for using FixYa and for the great rating.
hardrocko
Aug 20, 2010 | Mitsubishi WD-Y65 65" HDTV
My tv keeps shutting down when I turn on. The message on the the TV screen said that "the TV will be shutting down in a few minutes". I resit the lamp in the back of the TV and the TV works after I reset...
The first would be excessive dust causing inadequate airflow through the lamp cage. Cleaning the filter may resolve the problem.
It could also be that one, or both, of the temperature sensors could be defective. This is a known problem to the extent that Mitsubishi extended the warranty an extra two years on your model and similar models with the same design.
Mitsubishi Digital Electronics America, Inc (MDEA) 2006 DLP® Projection Televisions Models: WD-52631, WD-57731, WD-65731, WD-Y57, WD-Y65, WD-57732, WD- 65732, WD-57831, WD-65831.
As part of our commitment to quality and customer satisfaction, MDEA is announcing an extension of the warranty coverage to replace the thermal sensor for the above referenced models. For a period of two additional years beyond the one year limited warranty, MDEA will cover the cost of the thermal sensor (parts and labor) at no charge. All other terms of the MDEA limited warranty will continue to apply.
Nov 30, 2017 | Mitsubishi WD-57732 Projection Television
Hdmi 2 wont work on mitsubishi wd-y65
It sounds similiar to a problem we've had with ours, all components would work in hdmi 1, but hdmi 2 would only work intermitently. They ended up replacing the digital board (fortunately we have the extended warrenty, I'm sure it's not cheap). Sorry hope this helps.
Feb 14, 2009 | Mitsubishi WD-Y65 65" HDTV
Mitsubishi wd-73733 73 need missing screws
Is this a tv problem or stand problem, if stand then I guess you will need to locate another for this set. I guess you could try www.vancebaldwin.com or Mitsubishi direct
Jan 02, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Televison & Video Logo
1,090 people viewed this question
Top Televison & Video Experts
