Question about Aspire Acer 7520-5071 Notebook
The screen is on but is dark, i think the backlight is not on.
  • 2,632 Answers
You can try to powerdrain the Laptop or Remove the Battery and try to turn it back on if still have the same issue and if the system is running then it might be that there is a problem ith the LCD. you need to get intouch with acer check the warranty for repair so that they can replace you LCD free of charge
Thanks for using Fixya
Posted on Jul 30, 2010
Where is the backlight button on a netbook gateway atom N455?
I think there is no backlight button in any lcd monitors on any laptop. If it's dark, time to buy a replacement lcd screen.
Oct 03, 2013 | Gateway 450ROG Notebook
I have a samsung 1080 full hd 38" flat screen tv,
I think the backlight is failing, you will need to have it replaced. It is also possible that the backlight inverter (power supply) may be faulty but that usually shows up a fault. I think it unlikely that the screen itself has failed unless it has been subjected to pressure damage.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Mar 01, 2011 | Samsung LE40B650T2 40 in. Full HD Crystal...
Hello!!! I need an asistence with my computer screem is so dark... and it has been working fine but yesterday I was watching a movie and after an our becomes to runig alitle beat darking and more dark so...
This looks like a backlight problem. Every LCD has a backlight the older ones have Fluorescent lamps and newer ones have LED.
Most probably your laptops screen is equipped with a fluorescent lamp.
You may need to replace the backlight or the inverter of the screen.
I would not recommend doing it at home because messing with a LCD screen can damage it (make it unrepairable) and you might get electrocuted.
Take your laptop to a qualified technician or if its under warranty you might get it fixed for free.
Thanks. Please feel free to contact me for further assistance.
Aug 09, 2010 | Acer Computers & Internet
How to replace backlight on compaq 2570us laptop
What is wrong with the backlight? The computer screen is just dark? I would start with the inverter. The inverter is usually the problem when the screen goes dark but people think it is the backlight. The backlight alone is very hard to change too. Go with the inverter, I would bet that is the issue.
Apr 02, 2010 | Compaq Presario 2570US Notebook
Backlight problems for E71
i think you have a backlight problem....can you just see whats on the screen if you put a light up close to it. or is it dead. either of them... can be fixed but it will cost a little for repairs. get someone to do it. because there is a lot of delicate soldering to be done...
Nov 12, 2009 | Nokia E71x Cell Phone
Problem with dark LCD screen and accessing the the LCD ribbon that I think is loose
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 10, 2009 | HP Pavilion dv1010us Notebook
Medion laptop screen goes dark?
Shure 'nuff. Sounds like either the inverter or backlight. I would go for the inverter as that seems to be the more common item to fail, it usually is cheaper than the backlight, and easier to replace.
If you need to directed to an online maint manual, let me know.
Ron
Dec 10, 2008 | IBM ThinkPad 770 Notebook
My compaq presario m2000 screen is very dark
You will need to replace the LCD screen. The cheapest way to go is ebay. Here is one.
Thanks and please take a moment to rate as fixya.
Jul 06, 2008 | Compaq Presario R3000 Notebook
Dark screen
if the picture is REALLY dark, like you can just barely see it in a lit room, then the backlight might not be lit. LCD TVshave backlight that shines through the LCD screen which allows you to see the picture.
If it's not the backlight then it would be the brightness/contrast settings that need to be adjusted. If the picture used to be normal and all of a sudden went dark, verify the backlight. Normally you can look through the slots on the top of the set and determine if the backlight is on. If you can see a bright light through any of the slots, the backlight is probably OK... go after the brightness/contrast settings.
Mar 25, 2008 | Vizio L37 Television
My LCD screen went dark
Well looks like you sussed the problem - no backlight Can it be fixed? -I doubt it, unless it is failry new and warranty comes into play Give the Panasonic website Techincal Support Team a look E-mail the problem
Jun 19, 2007 | Panasonic Lumix DMC-FX2 Digital Camera
Aspire Acer 7520-5071 Notebook Logo
47 people viewed this question
Top Aspire Computers & Internet Experts
pankaj rautela
pankaj rautela
Jax Planet
Jax Planet
EKASYS IT SERVICES
EKASYS IT SERVICES
Are you an Aspire Computer and Internet Expert? Answer questions, earn points and help others
