Question about Braun Flex XP II 5790 Electric Shaver
Braun 5790 leaks and floods counter when charging/cleaning!
  • 12 Answers
I figured out the problem for my Clean & Renew unit. Mine is 2 years old. About 3 months ago, I cleaned the buildup of whisker material from the TOP of the drain port [Left Side as you look at the unit] If you take out the cleaning solution cartridge and turn the unit upside down, you see the pump and the return ports. The return port is the smaller of the two. I found that there was a mass of dried whiskers in a few clumps clogging the return port. These clumps must have come loose and got caught within the drain port. I had noticed when I had the leaking problem I could hear bubbling just after the pump ran and the shaver turned off. I removed the clumps of whiskers and no more bubbling sounds and NO MORE LEAKS. My guess is that the fluid was draining back into the intake area and leaking on top of the cartridge. Hope this helps
Posted on Dec 12, 2010
How do i reset my braun 5790 shaver.
Fully charge the unit then turn it on and let it run until the batteries are fully discharged....do this cycle a couple of times and it should reset the display to be accurate with the charge on the battery.
Dec 28, 2014 | Braun Health & Beauty
Braun contour 5790 battery replacement
try this link: http://www.braun.com/us/male-grooming/maintenance.html
Jul 15, 2014 | Braun Flex XP II 5790 Electric Shaver
My braun Contour 5790 does not charge in either the cleaning stand or by the cord alone. Can you help me in this dilema?
It my be the batteries but they usually go bad very gradually and you should still be able to use it from the cord. It sounds more like a problem with the circuit board.
I suggest that you first find out if it can be covered under warranty. You can call an authorized service center at 847-869-7755. They can tell by the date code on it when it was made. If it was made less than 2 years ago. you shouldn't need your receipt.
Jan 25, 2010 | Braun Health & Beauty
My former razor, Braun 5414 would take 110-240AC as well as 12 DC. Now have Contour 5790, and want to know if itcan also use12 volt DC.
According to the Braun manual for your 5414 Contour, the specs for charging are printed on the electric shaver cord plug. (it's REALLY small print, so I'd get a magnifying lens to look at it!)
There isn't anything in the manual about the multiple voltage for charging the shaver, so I'd have to defer to the Braun (Gillette/Proctor & Gamble) customer service folks to make absolutely certain of what can and can't be used as a charging voltage before trying.
Here's a link to your manual, in case you're missing yours.
http://www.retrevo.com/d/ds/progress?doc=9142c4ae65df1746d12fc67fdc01df52
You can ALSO reach the Braun Customer Service folks by calling them at 1-800-BRAUN 11 (1-800-272-8611)
I hope you find this Very Helpful and best regards!
Oct 06, 2009 | Braun Health & Beauty
Non cleaning razor
Dear Freddofrog,
please ensure you have removed the plastic plugs from the cleaning fluid container. If you have removed these i would suggest that the fluid contaner is faulty, your place of purchase should exchange this for you with no problem.
May 27, 2008 | Braun Flex XP II 5790 Electric Shaver
Device will not charge...
Just take it back to the store where it was purchased and they will trade it for a "New" (Not broken) one. It's the holiday season and you have a week or two, on returns. There is a two year warranty on the product ( Braun 5790 ), if you want to go that route. You can contact the company @ 1-800-BRAUN-11, the person, "I" spoke with, was very nice and didn't act like I was a problem and she didn't try to just blow me off.
Good Luck-
Nov 20, 2007 | Braun Flex XP II 5790 Electric Shaver
Base floods with solution during cleaning cycle
OK, Remove shaver from cleaning base. Raise top cover as if you are going to replace the cleaning cartridge. Now, look into the cleaning cup where you put the shaver into.You will notice a small hole on the bottom left side. With a Q-tip ,clean out the beard hair from the hole.If you have a model 5301 which is located on the bottom of the base, you should be able to push the Q-tip all the way through the hole. This will allow the liquid to flow back down into the cartridge.This is whats causing the overflow.
Nov 04, 2007 | Braun Flex XP II 5790 Electric Shaver
Clean Cycle Never Ends
i have the same issue but the charge/clean light on the razor itself wont come on or charge at all. Braun said to send it in for repair/exchange and to find out whats wrong with it.
Mar 04, 2007 | Braun Flex XP II 5790 Electric Shaver
Braun Flex XP II 5790 Electric Shaver Logo
841 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
