Question about GE Americana A4425GDTWW Side by Side Refrigerator
WANT A SPARE D110C21RBX5 COMPRESSOR for my my Side
WANT A SPARE D110C21RBX5 COMPRESSOR for my Side by Side American refrigirator or the specification of the compressto try and
My refrigirator isn't cooling but the motor is still working, I would like to know if there is a way that I could put gas in it
I do not recommend you replacing the compressor. Charging refrigerators takes experience and the correct tools. If your refrigerator has lost it's Freon the best step is to replace the refrigerator, Thanks Sea Breeze
Feb 05, 2013 | GE GSS20IEM Side by Side Refrigerator
I have 2004 GE side by side with wather /ice dispenser refrigirator at first dispenser stop warking and now works on and off and no cold
Replace relay and check compressor working. If Compressor works, check with amps for correct amps. If not leak or chock. Call repairman to rectify. Thanks.
Jan 26, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
My Daewoo refrigirator's freezer is cooling but not the lower com
sounds like you need to replace the ptc overload on the compressor as this component supplies start and run power to the compressor and its getting weak and short cycling the compressor,they just unplug and plug into the side of the compressor and when you remove it shake it by hand and if you hear it rattle thats a good sign its bad
May 31, 2010 | Refrigerators
I have a side-by-side Samsung refrigirator RS24FAMS. There is bad smell coming from the back of it. I took off the panel at the lower back but found nothing suspicious. The smell is not from inside the...
there is a drain pan over there next to the compressor ...the old water get there and dry out ...see with flash light all over you might need to clean it (turn unit off) and do it gently ...good luck use some cleaning spray...
Jan 03, 2010 | Samsung RS2630SH Side by Side Refrigerator
My fridge has begun to almost stop making ice. It
Unless it has a broken seal, the fridge is most probably lacking refrigirant or pressure is weak. First thing you should do is check that the compressor is switching regularly and normally. Check refrigirant pressure and re-gas if necessary.
Sep 07, 2009 | GE Q Series GSS25QGT Side by Side...
GE Model # GSS20IEPA WW Fridge warm...freezer is fine
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
any further question let me know.
thanks,
Mar 28, 2009 | GE GSS20IEP Side by Side Refrigerator
Whirpool gold
Sounds like the unit may be stuck in to defrost . The defrost clock is usually inside of the refrigerator compartment up by the thermostat controls. you can take a screw driver and advance the controller to make the compressor come back on . usually when they start to stick they neeed replacing. good luck and please don't forget to rate the answer please. Thanks for using FixYa.
Jan 01, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Need help
A removable panel in the rear gives access to the compressor and condenser. Remove the panel and clean out the condenser. Make sure the condenser fan operates when the compressor runs. Restore the panel to its original position for normal operation.
May 27, 2008 | Maytag MSD2756G Side by Side Refrigerator
Freezer and Refrigirator not cooling
You didn't say if the compressor is running or not. If it is and all other things you stated are running then it has a sealed system problem. The sealed system comes with a 5 yr warranty in most cases (check owners manual). If the compressor is not running then listen for a click at the compressor. If you hear the click then I would replace the relay on the compressor. If you need further help I will need the complete model # off the sticker inside the fridge section.
Nov 09, 2007 | Refrigerators
GE Americana A4425GDTWW Side by Side Refrigerator Logo
373 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
