Question about EliteGroup K7S5A Pro Motherboard
When I switch my computer on it starts to power up then after 5 seconds it loses all power and begins to start up immediately, 5 seconds no power and so continues like that. I've swapped the power supply and no difference. Any ideas. Cheers.
  • EliteGroup Master
  • 27,725 Answers
Change all of the leads that connect to your hard drive including IDE,SATA electrical extensions aswell
hope this helps
Posted on Jul 31, 2010
2002 town and country shuts off immediately after being started
Start at the ignition switch for losing power in run position. then look at run relay.
Jun 15, 2014 | 2002 Chrysler Town & Country
I have a 95 Camry 4 cyl. I had the Distributor changed last year along with the timing belt, plugs, wires, and fuel filter. Now when I drive it goes about 7 miles and shuts down, after about an hour it...
Lets start at the beginning. The engine computer grounds the pump relay. The relay gets power from the EFI relay when the key switch is on and from the starter fuse when the key switch is in the start position. Do you know if the pump relay is getting power from both sources and a ground from the computer ? Can you run a hot wire to the blue black wire going to the pump and keep it running ?
Aug 05, 2013 | 2000 Toyota Camry
2005 Ion 2 starts and shuts off immediately.
I would begin with the fuel pump relay and see if it is being powered after the engine starts.
Sep 10, 2012 | 2005 Saturn Ion 2
2003 Expedition. Fuel system loses pressure if it sits for a while w/ engine turned off. Symptom: Crank for several seconds (5-10) to build up pressure, re-crank & engine will start immediately. ...
seem to get this problem with the 4 litre jeep engine where you have to crank for a second then twice and it starts on teh thrid crank ,and i havent been able to fathom it out as yet ,but the explorer has a electronic voltage switch on top of the tank thats is operated by the immobilisor ,So what i would do here is to remove the fuel tank and join the two big wires together which effectivly by-passes this switch and i think this may cure your problem .Lower tank on a jack a bit then disconnect the multiplug and the petrol pipes ,join the two wires on this switch which is on top of the sender /pump unit ,pump the fuel out to lighten the load using the fuel pump with two wires to it ,then lift tank back up and reconnect ,good idea to remove the sender unit and check the gauze filter on the end of sender unit whilst you have it out .and check for rust in the bottom of the tank
Mar 23, 2011 | 2003 Ford Expedition
No power to accelerate after replacing battery
if the battery was dead for at least a hour, the computers are resetting its self, try to drive it slow about to 30mph for a couple days computers will change the way transmission shifts and how the rpms act.
Oct 26, 2009 | 2004 Saab 9-3
Epson pituremate
try the following: 1. Turn printer off. 2. Disconnect printer from computer. 3. With printer turned off, hold down both the Paper and the cleaning buttons. 4. Continue to hold the buttons and turn the printer on. 5. When the Paper light starts to flash, release both buttons. 6. Immediately press the Cleaning button and hold it down for at least 10 seconds (until all the lights begin to flash and the printer will begin to reset). 7. When the Power light is steady, the printer should work. 8. Don't forget to clean out the waste ink tray and if necessary replace the waste ink pad. good luck
Mar 24, 2006 | Epson PictureMate InkJet Photo Printer
EliteGroup K7S5A Pro Motherboard Logo
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
