Question about Ricoh Aficio Colour 3006 Color Copier
Ricoh CL 7000 error code SC 387
Read out states: SC 387 error- how do we correct this as the copier does not respond to any command, even after shut off/power on.
  • VAN CO TRINH May 20, 2008
    Thank you. Before receiving your solution, I replaced the yellow toner and it solved my problem. But it is very helpful regarding the Develpment and Drum unit. vanco
  • kelay Sep 05, 2008
    dumping yellow toner not transfering on toi drum
  • 14 Answers
This Code relates to color gamma error in the Yellow development. Possible causes Low toner density in the Y toner,Toner supply Y mechanism problem( not supplying enough toner),Laser exposure problem, image transfer problem. My suggestion would be to ensure you have toner in the cartridge( but by this time it has depleted the developer), and you will need to replace the development unit and possibly the drum Unit. My best guess would be the development Unit.
Munybuny
Posted on May 20, 2008
How do i fix the error code sc 322 of my ricoh 3045 copy machine?
Have to open the Laser unit and clean the laser diodes carefully.
Dec 28, 2015 | Ricoh Aficio 3045 Digital Copier: 45cpm....
Ricoh Afficio cl 7000 sc 552 code what is it?
Try the procedure below. Its a hardware error on the device
Press and hold online + escape, then power on.
Use up and down arrow keys to select SP2
Press Enter
Use up and down arror to locate SP5
Press Enter
Use up and down arrow keys to select 810
Press Enter
Confirm the selection
Power off and on.
The error code is now cleared.
Aug 18, 2008 | Ricoh Aficio CL7000 Laser Printer
Problem Ricoh CL 7200 error SC 542
fuser assy replace it and reset code or have tech come out and fix it
Jul 19, 2013 | Ricoh CL-7200 High Yield Toner Refill Kit...
Ricoh 6513 Error Code Sc.387 Error Code Sc.457 Error Code Sc.350
1. Set SP3-125-003 to a value of
2 to enable Job End & Non-use
3 Self Check Mode.
fore more hrlp visit https://cbrtechsolutions.net
Jan 21, 2011 | Ricoh 6513 Copier
RIcoh CL 7000 having problem within the copier, it's locked and unable to use WHat should i do
Most likely if you have no error code displayed then one of the hard drives is bad.
Feb 07, 2010 | Ricoh Aficio 450 Copier
I KEEP GETTING AN ERROR ON MY RICOH CL 7000 THE ERROR READS SC 221-2
SC No. Item Definition Possible Cause Related
SCs Troubleshooting Procedure Type
SC 221 Synch.
detection signal
error 2
221-001: Y
221-002: M
221-003: C
221-004: K
Main scan length detection is
not properly completed ten
consecutive times.
The front (for C&M) or rear (for
K&Y) laser synchronizing
detector boards are used for
the main scan length
detection, which automatically
corrects the main-scan
magnification.
• Damaged or
disconnected cable
between front (C&M)
or rear (K&Y) laser
synchronizing
detector board and
the LD unit
• Incorrect installation
of front (C&M) or rear
(K&Y) synchronizing
detector board (the
beam does not target
the photo detector.)
• Defective front (C&M)
or rear (K&Y)
synchronizing
detector board
• Defective LD unit
After doing any of the following, print ten
jobs or more to see if the same SC code
is displayed:
1. Turn the main switch off and on.
2. Check or replace the cable
connecting front (for C&M) or rear (for
K&Y) synchronizing detector board
and the LD unit.
3. Check or reinstall the front (for C&M)
or rear (for K&Y) synchronizing
detector board.
4. Replace the front (for C&M) or rear
(for K&Y) synchronizing detector
board.
5. Replace the laser optics housing unit.
6. Replace the BCU.
If a synch. detector board cannot be
replaced, do the following as a
temporary measure:
• Disable main scan length detection
Sep 15, 2009 | Ricoh Aficio CL7000 Laser Printer
Ricoh CL 7000 down due to an SC-685
Do you have the copier feature option installed?
It is most likely just a loose connection on the interface between the main printer unit and scanner section. Turn off main power (red button), and re-seat the connector.
Please let me know and rate solution :)
Apr 17, 2009 | Ricoh Aficio Colour 3006 Color Copier
Error code sc 387 on my Ricoh Aficio 4006
You'll need a tech to run a diagnostic mode to find the exact cause...could be development problem, Transfer belt, ID sensor, etc
Feb 22, 2009 | Ricoh Aficio 450 Copier
Error
I do not recognize either of these codes (187 or 387) as part of the Aficio 2015 error list.
If the code is displayed on the screen, physically TURN OFF the copier with the main switch (red switch), wait 10 seconds and turn it back on. If it's an erroneous error, this should reset the error code. NOTE: THE ERROR CODE MUST BE DISPLAYED FOR THIS TO WORK.
Jul 08, 2008 | Ricoh Aficio 2015 Copier
Ricoh 3006
go to service program 5-810 ( sc reset) press on, turn off the machine an the turn on again. The service code should be gone, if it come back again check for a paper jammeed or wrapping the upper
fusing roller if this is not the case replace the thermistor;
Good luck
Vittorio
Dec 21, 2007 | Ricoh Aficio Colour 3006 Color Copier
1,433 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
