Question about Refrigerators
Liebherr frige/freezer switching on/off by itself
I have a Liebherr frige/freezer and it keeps switching itself off and on. When it switches off everything is off (inside light, temp display, etc)
When switching on/off I could hear a click comming from the back of the fridge.
Model: CNes 3866 Index 20A/147
    President:
  • 2,468 Answers
Its the main board relays on the board on the back panel or just inside the lower area on the left wall near the compressor compartment
Posted on Jul 30, 2010
Testimonial: "Many thanks for your solution. I will try and take a look but getting to the relays may not be possible without removing the compressor?!!!!"
My Liebherr CNes 3366 fridge freezer has started to build up ice in the bottom of the freezer. How do I check the fan in the fridge is working, (I never see it going)as it may be the cause? thanks r
remove cover and test with a meter or push door switch when door open and should hear fan hum or feel air when door open fan stops unless you push switch
Apr 20, 2017 | Liebherr Refrigerators
Water chute in ice maker keeps freezing?
note that doors of frige should be tightly closed, fan in freezer side should be on & running condition, donot put the items in freezer closely,there should be more gap within all items,adjust thermostat to lower position about half,then press autodefrost switch ,wait for auto restart about one to three hours
Dec 12, 2014 | Amana Refrigerators
I have a Liebherr 7082. Since there was an ice build up in the freezer, I defrosted it. Since I completed the defrosting, the refrigerator will not turn on.
Is there a fuse in the mains cable. Suspect electrics got wet during defrost. Allow to dry thoroughly before switching back on.
Apr 29, 2012 | Liebherr Refrigerators
My Liebherr SBSES7053 had to be moved temporarily. The winecooler/freezer is fine but the fridge although switched on does not seem cold inside. Any suggestions please
please check the distance of your condenser on the wall at the back maybe it has to close thats why a poor circulation of air affect the cooling of unit try to adjust it
Mar 02, 2011 | Liebherr Refrigerators
Liebherr k 2724 4 years old. Light works, but neither the freezer or fridge sections are chilling. Has been this way for 24 hours. Wiring seems ok in back, and light switches off when door closes. Any...
All you to do is to check on the control knob, this could be faulty or loosen , do replace if found faulty . this is the common problem that a refrigerator do have and replacing the control knob solve the problem .
Good luck......
Aug 08, 2010 | Liebherr Refrigerators
My freezer is working but my frige is not cooling
wrong model # ,defrost problem. remove freezer panel, check heater, check limit switch while still covered in ice, if both ohm infinity, replace defrost timer.
Sep 15, 2008 | Haier HTP18GAA Top Freezer Refrigerator
Liebherr frost free fridge/freezer
Try these solutions in these order:
1. Switch off the fridge and leave the door open overnight. Switch it back on in the morning.
Explanation: The sensor inside the fridge gets frozen and cannot control the temperature properly.
2. Switch off the fridge. Unplug it. At the back of the fridge (behind the unit, not inside) there is a large grid. Clean it with a hoover thoroughly. Open the fridge. Dry the back of the fridge if wet (inside the fridge). If frosted wait for it to defrost and then dry it. Plug in the fridge. Switch the fridge back on. This one worked for me.
Explanation: The dust in the grid deprives the fridge from cooling down and the unit can't control the temperature in the fridge section.
3. Switch off the fridge. -Unplug it. Empty it. Turn it upside down. Plug it in. Switch it on for 24 hours. Switch it off. Unplug, return to normal and switch on.
Explanation: This has to do with the pressure of the gas inside the compressor. I have not tried it but this advice as given to me by a qualified electrician when I commented the (in)famous F2 problem in Liebherr fridge/freezers.
Hope it helps. Regards. Albert
Sep 07, 2008 | Liebherr KGBN 3846 Premium BioFresh Bottom...
Refrigerators Logo
252 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
