FixYa.com
Tags:
Unotron Keyboard and Mouse
Wireless Optical mouse - C5100M
posted by patches23 on Apr 24, 2008
I have searched to no avail, all lights are on ( mouse and received) just plugged in for the first time and windows wont recognise, ( I am running XP) I have searched for drivers, cant seem to find any? cheers
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Apr 25, 2008
Not Rated (0)
IrishDruid
Rank:Guru Guru
Rating: 87%, 704 votes
Hello patches23,
Try the following procedure:
1. Go to your device manager. START>CONTROL PANEL>SYSTEM (If using XP, make sure you have chosen 'classic view' from the left side panel)>click on the 'Hardware' tab and you should see DEVICE MANAGER. Click this button.
2. Find the entry MICE AND OTHER POINTING DEVICES and click on the (+) sign next to it. Now you should see your mouse or just “HID compliant mouse” listed there. Double click this.
3. In the box that pops up, choose the "Driver" tab.
4. Click the button that says 'Uninstall Driver'.
5. Once this is done, right click on the MICE AND OTHER POINTING DEVICES entry again and from the menu chose "Scan for hardware changes" to reinstall or upgrade the driver.
6. On the 'General Properties' tab of the device, click 'Troubleshoot' to start the Troubleshooting Wizard and follow the on-screen instructions.
Hopefully, this should resolve the problem..
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! or Helpful rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Comment by IrishDruid, posted on May 03, 2008
Just wanted to inquire if your issue is resolved, or if there is anything further I can do to assist you…
If you find that the solution/answer I provided led you to, or resulted in a fix, please take a moment to close the ticket with a FixYa! rating under my solution. I would be very grateful for your show of appreciation.
Should you have any further questions, please feel free to post them here.
Cheers!
IrishDruid
Comment by IrishDruid, posted on May 31, 2008
P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved.
  • "FixYa!" - The solution provides great advice on how to solve the problem. (Positive Rating)
  • "Helpful" - The solution provides useful leads that helps solve the problem. (Positive Rating)
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated. (Negative Rating)
  • "Inappropriate" - The solution has absolutely nothing to do with the problem. (Negative Rating)
If your issue is not still not resolved, do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can.
IrishDruid
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Keyboards and Mice problems?
Keyboards and Mice
i cannot open this websites in...
youtube, orkut Answer This...
Keyboards and Mice
Audio Failure From Audio Sound...
A younger nephew trying to... Answer This...
Keyboards and Mice
my logitech portable blue tooth...
i work in an alarm room w/... Answer This...
Keyboards and Mice
help turning off num lock
hi i am having problems with... Answer This...
Keyboards and Mice
Microphone not working Need...
I plugged in my Microphone and... Answer This...
Repair Service
Find Keyboard and Mice Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
