Question about Samsung LE37S71 37 in. HD-Ready LCD TV
Our samusung LE40M87BDX, clicks for about 3 minutes before the picture comes on, it also turns itself on and does the same. any ideas?
    President:
  • 1,099 Answers
You have to open the back cover of the television to check for dry soldering, if found any resolder the panel,but if otherwise.
You need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where.
Hope this helpout...
Posted on Jul 30, 2010
I have had my Samsung LE40M87BDX for about 3 years now, recently it turns itself on when in standby mode after clicking for a few minutes but if you turn the power off and back on again it clicks for what...
Try what is proposed on the Samsung site:
Unplug the set
Press the on button for 15 seconds
Replug the unit
Samsung site states that if this does not work, the set needs servicing.
Hope this helps
Oct 03, 2010 | Samsung Televison & Video
Sharp Aquos LC-32D41U pictures problem
I have had exactly the same problem. Sounds daft but by not using the remote, and only using the power on/off switch on the TV itself, it is working perfectly...no idea why
Use the remore for changing programmes etc but not for on/off
Try it anyway because I know how annoying this is
Mar 29, 2009 | Sharp LC-32D41U 32 in. LCD Television
Bluetooth trouble !!
Go to settings-bluetooth-on. Then go back-search device-then wait for it to come on. If you know your bluetooth name look for it. Or you could press and hold the button on your bluetooth while you have your phone searching for the device, it should come up on your phone.
Dec 30, 2008 | Samsung J700 Cellular Phone
RCA P52937SG Will not turn on, only makes clicking sound.
I had the same problem with mine. There are two voltage capacitors in there. A low and high. The hig voltage is bad. I had to have mine in the shop. Cost about $400
Sep 15, 2008 | RCA P52937 52" Rear Projection Television
Magnavox 27m53404/17 Picture went out
Hello there, I'm having a major problem with my TV, I have called all of the local TV repair shops and they all are the same, they want money money money before they will even speak with me about the problem I'm having. This is the only TV in my entire household for a family of 4 and we desperately need the TV in working condition for our kids. I don't want to have to put out $500 for another set if I don't absolutely have to.
The Problem...
About 3-4 months ago the TV when turned on, the picture would slowly come into view and be very scrambled and before the picture would come into complete view the TV power would shut itself off, but the power light would remain on. You can hear the "Click" noise when it would shut itself off.
2-3 seconds after it 'shut itself off' then the TV would make the "Click" noise (The same noise it makes when you first turn it on), it would make the "Click" noise over and over and over again but nothing would happen. So i would turn it off and on again and change the channel rapidly until after 2-3 minutes it would come into view and work.
So we decided to leave the TV on 24 hours a day. Then today we awoke and it was off and making the "clicking" noise over and over and over again but with no picture or sound. Now it wont even turn on/off it just sits there and goes "Click, Click Click Click" and doesn't do anything.
I described the problem as best as I can. Here is the TV information and specifications...
Philips 27 Inch Tube TV
Model Number... 27PT54 3S37A
Serial Number... 78438404
105 Watts
60HZ
120V
Date Code March 2003
Now that I typed the model number there are threads everywhere people saying the same issue exactly as me, I will read them but please someone tell me is there anything I can do...
Can anyone explain exactly what is wrong with the Tv and why it's doing this?
Also, what should I expect to pay to repair it?
Any information or help would be appreciated very much.
Thanks in advance,
Anthony
Just got off the phone with certified Philips shop...they said they will repair it for $100-$130 with a $25 down payment just drop it off and he will call me when its done. Does this sound like its worth it or a rip off?
Sep 07, 2008 | Philips 27PT543S 27" TV
Mitsubishi 57" HDTV - has sound and timer light flashes
I had the same problem and my local repair guy soldered a defective sensor so that it goes around that problem. I also had to buy a new bulb. Now my picture is "cloudy" and the repairman has no idea why. I am waiting for them to call back on it.
Mar 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Turns off and on by itself after a few minutes of being on
Another post above says replacing the bulb is the answer. I have one coming as I am having the same problem. I will let you know if thats what it is.
Oct 17, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
I have sound but no opicture
When you replaced the flyback the new flyback is shipped with the screen and focus controls set at minimum. These are the 2 controls on the flyback itself. Turn the set on and let it warm up a minute, then slowly turn up the screen (bottom) control with a small flat-head screwdriver. When the picture is around normal brightness, adjust the focus (top) control until the picture is nice and sharp. Then, turn the brightness and contrast all the way down and set the screen control until you can just see the picture, just above the point where the picture vanishes. Reset the brightness and contrast settings and your picture will be back to perfect.
Jul 02, 2007 | RCA F36650 36" TV
Samsung LE37S71 37 in. HD-Ready LCD TV Logo
307 people viewed this question
Jerry Greenberg
Jerry Greenberg
