Question about Garden
I have a AEG battery drill model BSB14 STX-R serial No 01464F2008.The battery charger has failed.I am experienced in repair of electronic equipment but I need a circut diagram of this charger.The AEG distributor has refused to help,do you know of a web site or other source that might help.
  • tguy895 Jul 31, 2010
    The solution is helpful.I will work along the lines suggested in the last paragraph.Thanks for the help.
  • 905 Answers
Hello tguy,
Manufacturer's often hold schematics very close to prevent other companies from stealing designs (as improvements...). Sometimes, you can find a schematic on the patent application (that proves uniqueness of their design) that may more or less match your charger. Revisions likely won't be indicated though.
There are a few things, as an electronics tech, that you can do though. Most of the integrated circuits (regulator, buck/boost circuit, temp sense, etc) found on the board will have data sheets from the manufacturer. Looking at the pinout for each component will help you visualize how the charger is laid out on the circuit board. Occasionally, manufacturers will lift an application note from the datasheet and use it directly.
You know that semiconductors will have unique outputs based on device. Integrated circuits will have to have power (usually regulated) and ground, as well as possible timing / clock inputs and outputs. Find the datasheet, and start checking out the inputs / outputs of each device.
Assuming that your battery is NiCD, just about any charger designed for NiCD batteries will work as long as the battery it was designed for has the same or smaller capacity. A charger for a 14.4v 1700mAh battery will charge a 3Ah battery, just takes longer. NiCD charge termination is determined by the knee voltage, NiMH are similiar, but a much smaller voltage when fully charged. Lithium battery chargers typically are not interchangeable. So, you may be able to use a different charger, but will have to adapt it to fit the battery from your tool. You are also able to build a charger, even with temperature sensing, based on off the shelf integrated circuits from Linear, National, etc.
If you really absolutely need a schematic, and are not able to find one elsewhere, you can always trace out the paths on the board that you have, and enter them 1 by 1 into a schematic / cad package, or onto paper.
Posted on Jul 30, 2010
I have repacked my AEG 12 volt Li Ion battery but it will not take a charge could one of the electronic components have open circuit?
First thing to do would be to check the voltage output of the charger to ascertain if it is working properly. The voltage out of the charger should be higher than the battery pack voltage. Next (if you have the instruments) check to see if current going through the battery pack. If you have no current flow and still have the correct voltage then one of your cells is either faulty or the pack has open circuit wiring or has been repacked incorrectly.
Sep 27, 2017 | Drills
Charger cracked need a 18v charger
Sorry, do not know which charger, what brand of your drill is, so can not help you. But, you can find it yourself in the below link, there are so many cordless tools battery charger, Bosch, Makita, Black & Decker, AEG and so on. Power Tools Charger
Jun 15, 2014 | Drills
Charger wont charge batteries
The charges has various electronic components. If one fails all the machine fails. It needs an experienced electronic engineer to fix it.
Dec 03, 2013 | Dewalt 18v Battery Hammer Drill Dcd950...
I HAVE AN 12V AEG CORDLESS DRILL WITH LI LION TECHNOLOGY. UNFORTUNATELY ONE OF THE TWO BATTERIES SUPPLIED HAS BECOME UNCHARGEABLE (U/S). IS THERE ANYTHING I CAN DO,
Here is a link for distributors that will sell the battery
http://www.aeg-powertools.eu/distributers/eu
Without a model number of the drill I can only speculate what battery you need, and it appears that this drill is not sold in America, but I could certainly be wrong. I am only going off what what AEG will allow me to research on their website, and America will not come up as a distributor location for the 12v L-Ion batteries. I am also assuming your battery looks like the picture. I hope this helps.
Nov 24, 2010 | Drills
Between us my son and I have 10 18 volt batteries for our Makita power tools which we use in our Carpentry work of these 10 batteries 6 have failed. I have to say the reliabillity of the Ni-cad equipment...
Join the battery collectors club. I have 25 batteries, 12 guns, I quit buying the batteries, I found it cheaper to buy the gun with new batteries and charger once a year. Cause they don't even last that long. I have tried different brands too all the same. Got batteries?? Sure do.
May 15, 2010 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
I have 3 sears 18v battery chargers and they have
re batery got a problem not the charger
Jan 20, 2010 | Drills
R86006 Li Ion 18v Cordless drill - When trigger is pressed, drill runs for a moment and stops. While charging battery, both the green and red lights blink permanently. Is battery and/or drill bad?
Sounds like it is more between the charger and battery. Sounds like a newer model, Can you test it with an alternate battery? Chk the battery voltage and the charger output against the data plates.
Oct 20, 2009 | Ridgid Power Tools Pressing Tools...
My AEG BL9618 battery charger has started to chirp(beep) is this a fault signal as the user manual is pretty thin on troubleshooting
Does the battery still charge?? The reason I ask is that some tool mfr's are starting to play with the chargers. Insert the battery and remove within 5 seconds and reinsert and then does the noise go aaway or change? Makita has started doing this and also some others. If the battery charges I wouldn't worry too much but try the above method and see.
Jun 14, 2009 | Drills
Battery charger does not work for my bosch hammer drill sds plus .. my dad is an electronics engineer and he requires the circuit diagram to investigate the problem, where can i get one for this model .....
My charger (24 v) died also and repair shop wanted too many $ for repair. I happened on-to a charger for a printer (24v 1 amp) at the thrift store for $3.00 and fashioned a connector for connecting to the battery. It takes about 3 hrs to charge the battery but you must disconnect manually. It has been working for many months. It will do for me untill i find a bargan on ebay. The repair shop said that the part that failed was not a component that can be changed. (Multyfunction chip) Hope this helps for the short term. Enjoy
Dec 14, 2008 | Bosch SDS-plus BULLDOG Xtreme Rotary...
Garden Logo
91 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
