Question about Dryers
Dryer has no heat, Drum is working - Dryers
  • 3,600 Answers
Hi I will give you some tips on what to check then you may have to tear into the machine. First reset your breaker for the dryer it should be on it's own breaker in the electrial box. They use a double pole if it's 220 v once you reset the breakers without any clothes in the dryer try useing it on heat again. If it still don't work you need to be sure you have Voltage to the wall pulg on both sides. You can do this if you have a volt meter or if you don't you can buy a cheep one at radio shack for ten bucks. once you have a meter you need to put the black lead on the grond of the plug and one on one of the other legs of the wall plug, set your meter to 220 volts so you don't damage your meter. If you have 110 volts to the wall socket then your next step is to test the heating element with the ohm meter setting but you need to remove the cover to do this and for me to do this I need the dryer model to give you specfic directions to get to the heater. Hope this helps.
Posted on Jul 30, 2010
There's a slight burning smell coming from the dryer drum.
Some item may have gotten between the drum that rotates and the housing and during the rolling of the drum this item may be heating up from the friction. Check closely to see if you can find anything rubbing on the drum.
Jan 22, 2013 | Maytag PYE2300AY Electric Dryer
Dryer drum turns, no heat, replaced thermal limiter
Your model which we call the 417, is not usually easy to work on. The heating element is located behind the dryer drum. The drum has to be removed to change the element. There is a lot involved but given the cost of a stack unit the element and labor may be worth it.
Feb 17, 2010 | Dryers
Dryer power problems
Yes, all dryers have a belt that turns the drum. Chances are the belt and heat problems are 2 separate issues.. The belt turns the drum from a motor mounted inside the unit, your electric dryer has a heater element/coils that heats the drum your clothes are in. The belt could be bad and heat element also but both at exactly the same time is rare. Try unplugging the unit for about 5minutes and see if it resets. My washer does that sometimes and I have to unplug
Aug 07, 2009 | Whirlpool WED6400S Electric Dryer
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
Dryer does not release any heat
Is yours the gas model? If so I need you to look for some things. Open back door panel and see if while trying to light the igniter is glowing orange. Sea Breeze
May 22, 2009 | Whirlpool LGB6300 Gas Dryer
The heating compenent works, but drum won't spin
Have you checked the belt? That's generally the problem when a dryer stops spinning.
May 19, 2009 | Whirlpool LEQ9858L Electric Dryer
Dryer won't stay heated
check for broken wiring that could be touching the drum cant be sure without being there and checking it out
Aug 09, 2007 | Asko T701 Electric Dryer
Aquarius 1200 wd62 - Dryer not working
Most likely it is some sort of blockage in the vent, although it could be a bad blower. Check the lint filter and vent openings for a blockage.
Jul 27, 2007 | Hotpoint Aquarius WD63 Front Load...
Dryers Logo
51 people viewed this question
Top Dryers Experts
