Question about Xerox WorkCentre C2424DN All-In-One Laser Printer
Scanner workcentre xerox C2424
Why is complicated to scan and save a copy on a file in my computer?
i use a usb to print and it's fine.. there is connection but then if I try to scan nothing happens!!!!
arghhhh
can you help me?
    President:
  • 2,072 Answers
Have you tried going to Xerox.com, click on support, then enter the 2424, then support again, then type in scanning? There is a lot of info there.
You can also call 1-800-821-2797 and ask for second level support.
Posted on Apr 25, 2008
Tip
Disconnecting the Xerox c2424 Document Scanner
The Xerox c2424 Document Scanner has a very high rate of failure. After very limited use it can generate an error code of 39,012.40 indicating that the document feeder is damaged. Xerox's answer to 99% of the document scanner issues is to replace the unit. But while restarting or cleaning can possibly resolve this issue, it is also possible to just disconnect the scanner and use it independently of the document feeder.
Xerox documentation however, does not instruct the user how to do this and tech support won't walk you though it. (So, courtesy of Pastor Ray of Indiana) Listed here are the steps to operating the scanner without the document feeder:
(1) Perform a standard shutdown on the printer.
(2) Disconnect the Document Feeder from the printer IN THE REAR OF THE PRINTER. You still need the side connector hooked up, the one by the power-on switch, power plug, USB port and all the other goodies.
(3) Power up the printer.
(4) It should work. However...
If for some reason the printer won't copy, then just do what I did in my experimentation:
(2) Disconnect the Document Feeder from the printer in the rear of the printer.
(3) Physically remove the Document Feeder, leaving the copy platen visible.
(4) Power up the printer.
At this point you should be able to copy stuff.
(5) Physically reattach the Document Feeder, but DON'T reconnect it!
You should still be able to copy, scan, etc.
on Apr 16, 2010 | Xerox C2424 Copier
I have the message "Unlock scan head" when I turn the screw to the left to unlock it, I get the same message. Is there anything else I should be doing?
If you receive this error even after unlocking the scanhead xerox suggests replacing the scanner assembly. Item Inc offers this part on exchange for much cheaper then xerox. Here's a video to show you how to fix this error/replace the scanner.">
Aug 05, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox m20i scanning problems
its probably set to a low DPI.......change your dpi to like 600 when scanning
Nov 02, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Xerox Workcentre C2424.
You likely need modify darkness or the contrast.
Please take a look at the following from the Xerox site:
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=458,E=0000000001668056207,K=4248,Sxi=0,Case=obj(6796)
Please let me know if this has been helpful or if there is anything else I can do. Thank you.
Sep 19, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox WorkCentre 4150, 3 vertical white lines in all feeder scans
the problem is in the scanner, open it up and see if you can find any smudges, and clean any obstruction, any ink, liquid eraser residuals, can cause this part to appear as lines on your copied faxed image.
dont concentrate on the printer this is a scanner problem
Jul 28, 2009 | Xerox WorkCentre 4150/X Laser Printer
Copy Problem
Since you cleand the scanner and scans are fine, the other item I seen cause that problem is the power supply.
Jan 07, 2009 | Xerox WorkCentre M20i All-In-One Laser...
We have a Xerox M20 Copier/Scanner/Fax/Email which we have always used strictly as a copier. We need to use it as a scanner, to reduce paper in the office and access/share documents electronically. I...
To scan a document to file (Scan to File), the WorkCentre must be directly connected to the workstation using a USB or parallel connection. Scan to File is not supported over an Ethernet connection.
Sep 22, 2008 | Xerox Office Equipment & Supplies
Printer Problem
What model printer is this? The C2424 does not have a laser.
Are you 100 percent sure it is a model C2424?
There is no LSU status code for that machine.
May 14, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Workcentre c2424 Scan - Won't find me so I can scan to personal images
It seems somehow your address was deleted. Recreate the box on the machine and it should be ok.
Mar 29, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox WorkCentre C2424DN All-In-One Laser Printer Logo
79 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
