Question about E-Machines eMachines Desktop PC
Computer will seem to start, but
Good morning, I have a e-machine t-5212 I believe. I can power on the computer and it wiil start and display the spash screen withe the rolling bar then the screen goes blank and the hd seems to stop working...any ideas?
  • 85 Answers
If the screen comes up and goes blank again,
1.Remove and replace your RAM with a known good RAM to test with, if it persist or continue, then your operating system by re-updating it,this will help it to recover from the missing files
Posted on Apr 24, 2008
Acer Aspire 5750Z-4877 laptop powers off after morning boot-up
check and see if the cooling fan is running and make sure it is free of dust sounds like over heating shutting down for its own protection
Apr 30, 2017 | Computers & Internet
Emachine T 5212, when i turn it on,, a siren sounds,,then computer shuts off
In your computer (as well as other gadgets), the battery powers a chip called the Real Time Clock (RTC)chip. The RTC is essentially a quartz watch that runs all the time, whether or not the computer has power. The battery powers this clock. When the computer boots up, part of the process is to query the RTC to get the correct time and date. A little quartz clock like this might run for five to seven years off of a small battery. Then it is time to replace the battery.
This does not explain why your computer would not boot, however. You would expect the computer to boot fine but have an incorrect time and date. The reason your computer would not boot is because the RTC chip also contains 64 (or more) bytes of random access memory (RAM). The clock uses 10 bytes of this space, leaving 54 bytes for other purposes. The BIOS stores all sorts of information in the CMOS RAM area, like the number of floppy and hard disk drives, the hard disk drive type, etc. If the CMOS RAM loses power, the computer may not know anything about the hard disk configuration of your machine, and therefore it cannot boot.
Many more modern computers are not quite so dependent on the CMOS RAM. They store the settings innon-volatile RAM that works without any power at all. If the battery goes dead, the clock fails but the computer can still boot using the information in the non-volatile RAM area. I would change the battery and make sure unit is unplugged and my other hand is touching the metal frame on the computer to stop static discharge. Blow out the inside of the computer completely.Start computer with case off and make sure all the fans run and don't sound like a siren.Replace anything not running.It may not boot if the BIOS can't see the hard drives. You might have to start computer and watch the screen and when it asks you to hit a key to get into like the bios do it and see if you can reset it. If nothing seems be running right maybe the power supply went out they are real cheep at Tiger Direct.
Jan 24, 2013 | E-Machines eMachines Desktop PC
Dell optiplex 170l screen problems on shut down
Disconnect the monitor cable from the computer and power on the monitor. It has a built-in diagnostic program. If you see color bars floating around the screen then you monitor is O.K.
Jul 24, 2012 | Dell Computers & Internet
Sony pcv-rs520 boot bios - need BIOS entry key for changing boot drive
Should be the F2 key to enter setup. Make sure you are pressing this key during the VAIO spash screen on boot. If you press it after the spash screen the bois will not load and you will have to power cycle the computer to get the spash sreen back and try again.
Feb 20, 2012 | Computers & Internet
Display screen is streched across monitor
it wiil lcd screen problem if can change lcd screen the problem wiil solve
Jan 27, 2011 | Soyo DYLM24D6 LCD Monitor
Scooter wont work. Charger shows "Green"......its been sitting for months. Just found the charger. When throttle is rolled on it makes a high pithched tone but crank wont turn the wheel...
Hi. I have had a few cases where the machine has been sitting in a damp room and the brake has rusted to the body and wont release. A few light taps with a small screw driver has usually fixed this. You will need to put the machine into free-wheel before doing this.
Could also be a faulty brake unit, that has seized up.
Try pushing the machine in free-wheel mode to see if the motor and drive wiil move.
Normally if there is an electrical fault with the brake assembly, then the machine will have a fault code on the display. good luck. Neil.
May 10, 2010 | RTO 12v 70ah Leoch Battery For Scooter Or...
The display says there is a paper jam, but there is none
Sounds like the printer need to be "reset"
Cancel all print jobs.
Disconnect the printer from your computer
Turn power to printer off and unplug it.
wait 1 min, then reconnect printer to your computer.
then plug printer back in and turn it on.
Start your print job over.
Should the paper jam suppossedly still exist, cancel the print job and run the maitenance program off the printers' menu that is stored on your computer.
Start print job again.
Should the problem still exist contact support at Samsung via the links on their homepage.
Good luck.
Oct 05, 2009 | Samsung SCX-4100 All-In-One Laser Printer
Mitel 5212 ip phone - display has disappeared, can i get it back?
your phone has lost connection with the contoller; call for service. Or your phone is broken. There is no "on or off switch".
Jun 29, 2009 | Mitel 5212 IP Phone
Blank screen; Unresponsive computer, & three beeps in succession
2 short beeps and 1 long beep (repeats 5 times) = Unable to initialize video or video card required but not installed. Sounds like the card may have gone down
Jun 19, 2009 | Intel Desktop Board D845GLVA...
E-Machines eMachines Desktop PC Logo
44 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
