Question about Sharp LL 172A-B 17" LCD Monitor
When I connect my headhphone to monitor doesn`t work?
If you mean the pale green jack on the back of the monitor, it is not a headphone jack. It is to let you connect the sound output from your computer (usually also a green jack) to a little speaker in the monitor. That speaker is better than nothing, but sound quality is poor.
Posted on Nov 12, 2010
I want to connect a 6 pin s video to a bnc monitor and cant find a connector
SORRY YOU CANT DIRECTLY CONNECT A S-VID CONNECTOR TO A COMPOSITE BNC VIDEO INPUT , THEY DO MAKE CONVERTERS FOR THIS (GOOGLE IT) BUT IT'S BEEN MY EXPERIENCE THAT COST OF NEW/CORRECT MONITOR IS LOWER/SMALLER THAN THESE DEVICES
Jan 31, 2013 | Lorex Home Sentinel Wide Angle Security...
Acer P221W turns off without warning
tried with unplugged and re plugged doesn't resume in normal ?.ok check loose connection in the power adapter.if still doesn't resolved the problem, at this time you will need to check the power supply if it is working.you can use a digital tester or an analog to make a voltage checking.
Oct 07, 2012 | BenQ FP71G 17" LCD Monitor
Is my AOC 9170 monitor compatible with HP Pavillion 6523W Windows 7? Does this monitor have built in speakers?
I am not sure about the speakers. The best way to tell if it has speakers is if you can physically see them. They are usually located at the bottom of the monitor and they look like little screens on either side of it. If it doesn't have HDMI or a line in jack (speaker plug) that you can see then it won't have built in speakers for sure.
If the monitor has the right connections to plug into your HP computer, which it should. Then it will work with your computer. Your computer has both VGA and DVI monitor connections on it so either of these should work as long as your monitor has the connections (which it should have at least one).
Sep 13, 2011 | AOC Monitor
My computer's tower turns on but it doesn't display on the monitor, the monitor shows the normal Self test box so the monitor doesn't seem to be the problem. Also when I press the power off...
Make sure that the cable is connected from your computer to the monitor, and if it is wiggle it and push it in all the way. If it has screws, screw them in. If that does not work, check that your monitor is on the correct input (if it has multiple) then see if anything comes on the monitor. If nothing happens you should buy a new cable from the store. If all of those steps do not work your computer or your monitor might have a more serious problem.
Jul 29, 2011 | Computers & Internet
My acer monitor p191w will turn on acer logo comes on goes black then a screen comes out saying no signal then turns of light turns yellow ...tried restarting monitor nothing
Connect the monitor to a different computer, to see if the monitor works at all.
Connect a different monitor to your computer, to see if your computer really is "sending" a video-signal through the "data" cable. If not, then either the data-cable or the video-card inside the computer is faulty.
Jul 13, 2011 | Acer P191WBD LCD Monitor
My monitor suddenly went black when I awoke it from standby and it only states "video input 1 D - SUB NO SIGNAL" each time I turn the moniitor off an on again. I checked all connectivity to the...
My suggestion is going to be if you have another computer that you can hook up to the monitor and see if it works for it then the problem would be not the monitor but your computer. As it is telling you that it is not recieving a signal. If it still doesn't work then it will be something wrong with the monitor or the cable connecting it.
Jun 20, 2011 | NEC MultiSync 1770NX 17" LCD Monitor
I have a Trulink VGA 4 port KVM switch. Has worked fine for a year plus. Just moved it to a new room, and reconnected the same computers to the switch using a new monitor. I can't get the monitor to work....
Maybe the switch doesn't support the type of monitor that you are trying to use. Have you tried switching back to the old monitor to see if that one still works?
May 04, 2011 | Computers & Internet
I have lg m198wdp monitor tv.problem is white screen
When does it happen?
During Self test? Try this by unplugging the cable that connects to your tower and see if the self test runs. if it does, then your monitor still works. If it doesn't you might need to replace your LCD
During BIOS? If it works then your monitor still works. If it doesn't you might need to replace your LCD
During Windows? then you might need to adjust your display properties or reinstall your video card drivers.
Apr 27, 2011 | LG M198WDP - Flat panel display - TFT -...
Just connected a HF 225 monitor to Vista Home 32 bit. No real manual; install CD does nothing. When I press the Menu or Brightness buttons on the monitor I get no response to keyboard or mouse clicks to...
They only include the Win7 driver on the CD. I'm surprised it doesn't work with Vista. Did you try going into the HF225_win7 directory and clicking on infinstallWIN7?
The monitor menu doesn't work with the keyboard. You have to press a combination of the three buttons to the left of the on-off button. It's not very intuitive.
Aug 08, 2010 | Hannspree 22" widescreen LCD Flat Panel HD...
Sharp LL 172A-B 17" LCD Monitor Logo
129 people viewed this question
Top Sharp Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
pontelemon
pontelemon
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
