Question about HP Designjet Z6100 InkJet Printer
Hp z6100 turns itself off! no error code just switches off! Makes loads of beeps and sounds like a fax machine! Help
    Champion:
  • HP Expert
  • 202 Answers
It contains m/b like desktop with cpu,ram,hdd etc check ram cpu fan & power supply refix them after cleaning ...............may b ur problem will be resolved.
Posted on Jul 30, 2010
HP Z6100 error code 79:04
79.04 is a system error like ablue screen in windows. The troubleshooting process is very complex. Your best first step would be to disconnect any data cables and restart. If the machine comes to ready then it may be that you are sending data with either a corrupted print job or the wrong driver. If it errors even with the data cable disconnected then you will probably need to reset the eeprom. Make sure that the formatter is seated properly and all components on the formatter are seated properly.
Nov 08, 2014 | HP Designjet Z6100 InkJet Printer
HP DesignJet Z6100 Error 43:10
Hello. The error message indicates a vacuum fan failure. The problem can be solved by replacing the Vacuum Fan Assembly.
Q6651 60286 HP Designjet Z6100 Vacuum Fan Assembly
The service manual with instructions can be downloaded from: http://www.lpscomputer.com/collections/designjet-z6100-parts
Jul 22, 2014 | HP Designjet Z6100 InkJet Printer
I have a hp z6100 and it keeps saying load roller
Do you mean load up Take up Reel, in which case the Take up reel option can be switched off in the paper menu accessible from the front panel on the Z6100.
Feb 22, 2013 | HP Designjet Z6100 InkJet Printer
Hp z6100 plotter error code 46:03
System Error:
46:03
Problem Description:
Primer servo shutdown.
Corrective Action:
Try the following:
1. Switch the Power OFF from the back of the Printer and disconnect the Power cord. Reconnect the power cord and power On the Printer.
2. Replace the Primer Assembly .
3. Replace the PrintMech PCA .
4. Replace the Interconnect PCA .
Feb 06, 2013 | HP Designjet Z6100 InkJet Printer
Hp designjet z6100 error code 21 : 13
Service Station error. Switch the power OFF from the back of the Printer and disconnect the power cord. Check the Primer Tubes. Reconnect the power cord and power On the Printer. Make sure that the Service Station path is clear. Remove any visible obstacles (e.g. screws, plastic parts, etc...) restricting the movement of the Service Station. If the System Error continues, replace the Service Station. If the System Error continues, replace the PrintMech PCA
Jul 27, 2010 | HP DesignJet Z2100 InkJet Photo Printer
HP Z6100 error code 01.2:10
01.2:10
Problem
Description:
ISS PCA problem.
Corrective Action: Try the following:
�� Switch the Power OFF from the back of the Printer and disconnect the
�� If the System Error continues, replace the Ink Supply Tubes and Trailing Cable.
Sep 25, 2009 | HP Designjet Z6100 InkJet Printer
Sending error
I try sending a fax then the paper goes through it makes a loud beep and the message says theres been an error try again this happens all the time no matter who I fax. then it prints out error confirmation stating Mode G3 send error
Jul 29, 2008 | HP 1040 Plain Paper Inkjet Fax
L170 Canon Fax Sound and volume control issues
Sunds as though you have the handset that came with the machine attached to it and the handset ring volume is still on. To turn that off there are 2 black inset switches on the handset itself turn those down or off.
Apr 09, 2008 | Canon FAXPHONE L170 Plain Paper Laser
Solution to fix prolem with machine
Line interface unit is broken beacuse of which the beeping sound comes up. It tries to intiate however fails as a result the sound comes up. Need to replace the printer.
Dec 06, 2007 | HP OfficeJet k60 All-In-One InkJet Printer
HP Designjet Z6100 InkJet Printer Logo
341 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
