Question about Reddy HEATER RLP30 30,000-BTU PORTABLE LP PROPANE FORCED AIR HEATER
L.P. Propane Heater not staying lit Fairly new heater (Reddy) 30,000 BTU Piezo Igniter not functioning use long match and unit fires nice. plug in /turn on blower good once I let go of primer valve button 1 minute even unit ceases to function. could hold in primer all day it runs do not think thermocoupler as unit will start. Thanks
  • 1,476 Answers
Sounds like you have a bad gas hold on valve. I have a tip at http://www.fixya.com/support/r4258201-fix_gas_reddy_heaters_will_not_continue which explains the problem, how to fix it and where to get the parts. Let me know if you need more help.
Thanks for using FixYa and for the generous rating.
hardrocko
Posted on Jul 30, 2010
VERY GOOD "spark" HOOKED UP YOU CAN SMELL THE GAS WHEN YOU HOLD THE BUTTON IN IT WILL IGNITE THE GAS WHEN THE FAN OFF BUT DOES NOT
Possible weak gas flow to igniter may require adjustment, have a qualified gas technician check it.
press the helpful button
Jan 08, 2016 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
Propane heater wont stay running
is the sensor for the thermocouple located in the right spot in the flame,remove it and if you have access to a propane torch,heat the end till its red hot and leave it connected to the gas valve,then start the unit and this will tell you if the sensor is properly positioned in the pilot flame on the unit itself,if not you could have a defective new thermocouple or another safety device keeping it from staying lit or the gas valve is faulty
Jul 28, 2010 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
My universal lp forced air heater model 30 fsa wont stay lit
if its lit by a pilot your thermocouple is bad the purpose of the thermocouple it to keep the gas valve open
Oct 24, 2009 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
Reddy Heater won't stay running
Dear travelinman4, 02-21-2009 18:24 EST (USA)
Re: Reddy Heater "Won't Stay Running"
Model R150A
Old Fuel? Added a Can of Fuel Booster? Used Starter Fluid?
Spark Plug or Igniter?
Gas, Propane, or Kerosene?
jack
Feb 21, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy heater rlp 100
Sounds like the thermocouple is not working or the flame is not hitting the thermocouple. It may take 30 seconds of flame or longer to keep it on. Check for a loose connection at the gas valve.
Either a 30# or 110# tank of propane will work. You might even get by for a short period of time using a gas grill tank, depending upon how cold it is outside.
Oct 26, 2007 | Reddy Heater-30,000 BTU Propane Forced-Air...
Reddy heater model 28725
propane heater uses a hot surface ignitor. this operates off 120 volts and glows red/orange when actuated. it stays lit throughout the heater on operation.  on the backplate of the combustion chamber is a high limit with two wires coming off it.  these two wires connect to the spade connectors on the flame detector cappillary.  Once you establish a fire, the flame detector generates a 750 millivolt signal which is applied to the pilot/main valve assembly.  My diagram will show this. 1fa8284.jpg
Oct 12, 2007 | Reddy Heater-30,000 BTU Propane Forced-Air...
Forced air propane heater won't stay lit
two items come into play here - 1) the hot surface cutout and 2) the flame detect Cd cell. Check alignment of the Cd cell or just replace it. The hot surface cutout has two terminals that plug into the two tabs on the millivolt generator.
Feb 06, 2007 | Reddy Heater-30,000 BTU Propane Forced-Air...
Heating & Cooling Logo
753 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
