Question about Siemens Euroset 5010 Corded Phone
Hi I would like to know how I can save a number to one of the memory locations on my Siemens 5010 phone please? Regards John
Hi
Posted on Nov 11, 2010
Phone was played with by child, now red light shows and no dial tone
Hello
Your phone ahs been locked by mistake. When telephone is locked, except for a saved emergency number, no numbers can be dialled; incoming call can be answered.
To unlock it, Lift Handset, select function. (1) Lock. (0) Unlock. Press SET key and replace handset. OK.
Aug 30, 2011 | Siemens Euroset 5010 Corded Phone
No caller name appears for the numbers already saved with name
Try to save the numbers when the call comes to you phone and if this brings out the memorry then the saved memory must be stored with the Country and STD codes.
If not there are errors in the software and you can try and reset to default settings.
Jun 17, 2011 | Nokia N73 Cellular Phone
When someone calls me only the number shows up and not the name how do i fix this
hi,
the main reason for that is that you have a double entry of names in your phonebook or you save the same name and numbers in the phone memory as well at the sim card.
delete one of them either in the phone memory or in the sim card and your ok.
hope this helps you.
Dont forget to rate me. Thanks...
Regards,
John
Jan 15, 2011 | Sharp Cell Phones
I have put my sim card into my samsung f480 but the contacts have not transferred over. I know that my contacts are definately saved to my sim, please help!!!
hi,
if you are sure that your contacts are in the Sim, you can copy it in your samsungs memory from your sim card. Some unit will show your sim contacts unless you transfer it in your phones memory.
you can check that option at the Contact or Phonebook menu of your phone.
Hope I get your problem.
Don't forget to rate me. Thanks.
regards,
John
Jan 14, 2011 | Cell Phones
When i open my n72 any file it show memory low delete some data
hi,
you must delete unimportant files from your phones memory or else it will crash soon.
it will need sufficient memory to process data. instead, save your files on your memory card.
most files that uses big memory spaces are the videos n mp3's. you must delete some of that.
message me if you have more questions.
Don't forget to rate me. Thanks...
Regards,
john
Jan 11, 2011 | Nokia N72 Cellular Phone
One of the message in my inbox is not getting deleted and i can neither receive messages nor send messages........please help urgently
hi,
here is what you can try to do.
You can delete that message at the delete message option at he message menu.
If still cannot be deleted you can restore your phone to original setting.
You can locate this menu at the phone settings then Restore factory settings.
You will be ask a security code (default is 12345) and will restore your phone after.
Warning:
Restoring your phone can erase all your files save in the phones memory including the contacts.
Hope this will help you.
Best regards,
John
Jan 06, 2011 | Nokia 7610
Sir when I am dailling my numbers are not recorded
HI there,
For clarification of your problem, may I know what exactly the phone model that you have.
Did you mean that only number and not the name of your contact appeared on the screen or into your call registry?
In some cases like this, it just happen that you have eventually has done a double entry of the number on your phone book or into your cellphone. If you have entered or save 2 or more names on one number, the unit will only display the number and not the name assigned to it, because it will not display multiple name on one same number.
Also check if your contact was saved into the phone memory or into the SIM memory. Check the phone book settings and check the memory in use, by default choose >>Phone - SIM memory, to use both locations.
Please kindly let me know, and hope to hear more info soon.
Thank you for using fixya.
Jun 22, 2010 | Cell Phones
Unable to send or receive picture messages
For saving setting you will have some free memory if free memory is not available then It will not install.
For installing please first release some memory from phone memory.
Let me know If I can help you further regards this problem
Regards
nidostyle
Nov 17, 2008 | Sony Ericsson K610i Cellular Phone
Siemens 2520 gigaset base
Hi Mike,
Its an easy fix, you need to tell the phone what area code your in. Push menu, go to system settings, enter your pin, scroll forward to "area codes" press enter twice, enter your area code and push enter to save. Now the phone knows where your located and wont add the 1 and the area code. CG
Mar 21, 2008 | Siemens Gigaset 2420 Cordless Phone
Programming a number for memory
Memory
Store up to ten 20-digit numbers in memory for quick dialing.
Storing a Number in Memory
1. Make sure the phone is OFF (not in TALK mode).
2. Press the MEMORY button.
3. Press a number (0-9) to store the dialed number in that memory location.
4. Press the MEMORY button again.
5. Use the handset number keypad to enter the telephone number (up to 20 digits, including pauses) and press the MEMORY button again to save the number. The unit beeps to confirm.
6. To enter another number in a different memory location, return to step 1 and repeat the process.
Nov 03, 2007 | Uniden Cordless Phone
Siemens Euroset 5010 Corded Phone Logo
453 people viewed this question
Top Siemens Lands Phones Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
