Question about Acer Aspire 5500 5570-2609 Laptop
Screen freezing and laptop auto shutdown when over heat
My Aspire laptop screen will freeze with vertical lines. Then the laptop will auto shutdown when it heats to much. As I try to diagnose for the heat. There maybe a problem with the heat sink or the fan. and also the screen I think it will be the flakes or the screen. Would that be true? What are the solutions for it.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 103 Answers
Return unit to manufacturer or retailer for repair
Posted on Jul 30, 2010
Laptop freezing
try check cpu and ram
Feb 02, 2014 | Computers & Internet
Dell laptop periodic buzzing
Sounds like a bad bearing or dust accumulation in the CPU heat-sink fan. If the fan does not cool properly the CPU will overheat and shutdown or freeze the computer.
Jan 29, 2013 | Dell LATITUDE Computers & Internet
My acer 5920 laptop freezes when I click shutdown and it just freezes as windows is shutting down. I have installed windows xp sp2.
If your computer freezes,then the problem is related to the registry. When the Windows registry is filled with errors it can't stop your system from properly communicating information.
The only solution for freezing is to clean the registry of corrupt files and various errors. Not only will this prevent computer crashing, it will also speed up your system considerably.
Get technical assistance here if still the same problem is occurring....http://www.vtechsquad.com/windows-repair/
Jan 20, 2011 | Acer Aspire 5920-6727 Notebook
Aspire 5535 heats up and shuts down when a game is initialized. Fans clean and appears functional. Applied fresh thermal glue to heat sinks. Problem persists.
increase ur ram Scanning computer to eliminate malwares, spywares and the viruses from your laptop.
2- Repairing and cleaning Windows registry.
These two tips are found to be very helpful to fix the laptop shutdown problem. Almost all the computer users surf internet which could result in viruses attacking your system. Some of these infections are really pesky and cause the machines to shutdown randomly.
The registry errors, however, are the internal errors and can become a cause of system crashes and freezes. The registry keys shall be in good health to keep a system perfect.
When I noticed my laptop keeps shutting down everytime, I tested the Intel Software Partner, RegInOut to fix the random shutdown problem with my laptop.
Aug 29, 2010 | Acer Aspire 5050-3242 Notebook
White screen with black vertical hypen lines???
Hi, you should get an update for your graphics driver and the Bios update. After the updates for the driver. Do a hard reset. To do a hard reset. We need to shutdown the notebook. Remove the battery. Remove the power cord. Press and hold the power button for 30 seconds. Do not expect the turn on. That would be weird. Actually we are trying to reset something internally. After this. Test if the issue goes away. Hope this helps!
Mar 04, 2010 | Compaq Presario M2000 Notebook
Tv runs fine for 30-45 minutes then goes black except for bright horizontal line thru center of screen, volume stays on
This is a vertical problem. It may have a bad solder joint or it has a vertical IC or surrounding compoenents heating up and going bad, Try not to have the horizonal line on for to long, it can burn the screen if left on very long. If you have some electronic experience you could get some freeze spray and wait for the set to mess up and spray the freeze around the vertical section and locate the part that is heating up. Be careful because there is HIGH VOLTAGE is this area. Hope this is helpful.
Dec 03, 2009 | Televison & Video
Game screen freezes and there are white vertical lines on the tv
i dnt know about the vertical line but i had the same problemand i solved this by taking it to my nearest computer shop its as simple as that
Apr 14, 2009 | Microsoft Xbox 360 Console
Acer 1690 freezes when plugged into wall adapter
Battery has gone bad. Replace the battery.
Feb 26, 2009 | Acer Aspire 1690 Notebook
Vertical lines, screen freezes, laptop shuts down
it most likely doesnt run on windows me so that theory is out.Take it to dell or call someone to fix it
-CG
Jan 24, 2009 | Dell XPS M1330 Laptop Computer PC...
Problem with my Laptop !
I think you have 2 problem.
1.If you can use after a few minutes ls it freeze up then it can be the software problem or otherwise CPU overheat in your laptop
2.the vertical line on the monitor can cause by loose LCD connector inside you monitor or your LCD have problem.Incase LCD have problem then no other choice is to change it.
Incase when you say after you restart and your LCD work fine then its not a LCD problem, its a loose connector problem..
What I recommend is to clear this problem fast cos it can spoil your LCD monitor.
takecare.
Apr 29, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5500 5570-2609 Laptop Logo
209 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
