Question about Craftsman Professional 775 Torque 175 cc 21" RearWheel Drive Lawn Mower (CA) ()
I ran over a small tree stump while mowing and this stald the enginr instantly and now it will not start. and is back firing when trying to. Need help with diagnosis and a manuel to show prseadure for repair please.
  • 43,501 Answers
I have had that happen when my wife and kids ran over stuff...
One time it was just the blade that got bent and the other time it was the motor shaft...
Changing the blade is easy...straightening out the motor shaft is near impossible with major repair tools...
Check and see what is bent, but my thought is that something got bent which throughs everything out of balance and then the motor will not run...
heatman101
Posted on Jul 30, 2010
Why does my engine backfire back through the breather while I try to start the engine
it could be that the aluminum key that hold the flywheel in time with the crankshaft is damaged. it will have to be replaced. if you hit anything while mowing like a tree root or stump. this will cause the problem you have described. hope this help.
Dec 10, 2015 | Garden
How do I fix the deck to ride on mower
Find the missing nuts and bolts you left somewhere by that tree stump you ran into, or that pothole you bottomed out on, or that road you tried to mow. Put them back where they belong.
Mar 14, 2015 | Garden
How can I take a tree down
It depends on how big the tree is and what equipment you have. If it is a small tree, you can dig up around the roots and pull it up. If it is a bigger tree, you might need some help. Anything with a trunk diameter bigger than a few inches will require heavier equipment.
Elisa Jed ' http://www.treesafe.com.au/stump-grinding.php
Apr 02, 2014 | Olive Tree BibleReader Android Apps
Enginr stalled and will not fire when trying to start back up
seen people with this out of gas . your coil may be gone .fuel pump may be gone start with these first.
Jan 18, 2014 | 2009 Chevrolet Express
When engaging blades engine dies after mowing over 2in sawn off tree stump
take deck belt of and check that blades stiil turn by hand most likley bent or broken
Feb 23, 2013 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Ran into tree stump will not start
You blew your flywheel.
Jun 03, 2012 | Garden
I have a Husqvarna 235 that decided it didn't want to start anymore. It's only a few months since I got it. It was used the cut up a small tree that fell down in a wind storm and used again while...
Has the fuel been in it since you last used it? if so drain and re fill with fresh fuel oil, work the primer plenty of times to flush the old fuel out, crank the engine twice only with the choke out, then push it fully back in and crank again until it fires up.
Jun 08, 2011 | Garden
How do you use roundup to kill a tree stump?
Hello, I am a grower and licensed pesticides applicator (40 yrs exp).
Roundup lost the trade mark years ago,"glyphosphate" which is now marketed (cheaper) under many other names,
Will kill a live tree if sprayed on the leaves! Also will damage young trees if you just get over spray on the trunk while spraying weeds.
Also, kills grass as well as broadleaved plants.
To kill a tree you would need to spray the leaves, then wait at least a month before cutting the tree down. I have successfully killed a few stumps by spraying the live suckers.
Be especially careful of spray drift as the finer the droplets are the more effective the chemical is. Read the label!
Aug 29, 2010 | Roundup "" Weed & Grass Killer
Fuel not getting to injectors
Sounds like you need a NEW FUEL PUMP.
CHECK BALL IN PUMP NOT HOLDING RESIDUAL PRESSURE.
Jun 04, 2010 | 1999 Mercury Cougar
Craftsman Professional 775 Torque 175 cc 21" RearWheel Drive Lawn Mower (CA) () Logo
340 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
