Question about Craftsman Air Tools & Compressors
2.5hp 40ltr unloader prob?
I have a 2.5 40L project air compressor and every now and then it just stops and hums and so i turn it off and when the unloader valve relessers i turn it on and it goes agin, why is it doing this? it also doesn't matter were the psi is at.
    President:
  • Craftsman Master
  • 1,388 Answers
Motor stalling during the fill cycle would indicate problems with the intank check valve, weak capacitor or low power to compressor. The unloader generally opens only when compressor reaches set pressure. Easy test. Unplug compressor with air in tank and remove the small airline at the checkvalve (brass valve in tank). Listen for air leak. Checkvalve is ok if no leak at brass valve. Test capacitor for 95% rated value. Replace as needed or test for low power. Good luck.
Posted on Aug 03, 2010
Why does my porter cable air compressor hums when it kicks back on?
If the unit comes on a builds pressure, stops normally and when the pressure drops TRIES to come back on BUT just hums, it is because the motor cannot overcome the internal pressure. This is usually because a part called an "unloader" valve has not let the pressure off or there is no unloader. If you post the model number, I can check.
Dec 10, 2016 | Porter Cable Air Tools & Compressors
Air compressor cannot spin up with pressure in tank sometimes
There is an unloader valve and a check valve on the discharge side of the pump. The check valve is not holding and the unloader is not dumping the pressure so the compressor cannot start. Since it is new, you may want to take it back. If not you are going to be replacing parts.
Mar 10, 2014 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
How do i hook my 5hp compressor up direct
By direct, you most likely mean continuous run where the compressor runs to set pressure then a spill valve or unloader will discharge the rest of the air. This can be done with a pilot valve available thru WWW.Grainger.com or ebay. Make sure that the thread sizes will work on your compressor. You do not have to remove the pressure switch, however the unloader must unload before the pressure switch setting. For an idea on plumbing, take a look at gas powered compressors or an electric RolAir compressor that has that feature installed. Good luck.
Oct 24, 2012 | Air Tools & Compressors
Need a point setting for ao smith air compressor ac motor model number opa-0297 s# c56b72b2316508j2 work on air machine with motor installed motor will hum and trip breaker can we set points to stop trip...
There is not a point setting for air compressors. The pressure switch can be adjusted. Remove the cover from the pressure switch. Adjust the nut tighter for a higher cut off pressure or looser for a lower cut off pressure. It sounds like the compressor is trying tostart under load. If the unloader valve is not working, the compressor will draw excess amperage and do what you describe. The unloader valve releases the pressure in the cylinder at the end of the run cycle so the compressor can start the next run cycle under no load.
May 14, 2010 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
Bleeding air from fitting on side of pressure switch, fitting has 1/4 tubing running to it. This pressure switch is new out of the box.
The fitting on the side of the pressure switch is an unloader and should bleed air when the compressor shuts off, if it continues for more than 30 seconds then the tank check valve on the pump discharge line where it enters the tank is not closing off and needs to be checked or replaced
May 04, 2010 | Electric Eyeware Ingersoll Rand 5HP...
Air compressor leaking air
you have a bad check valve ,the little brass valve is working normal
Apr 18, 2010 | Clarke Power Products AC2002A 2 Hp Air...
Coleman 5Hp Compresser
All electric compressors share a basic design with ac power pressure switch with unloader and checkvalve between the pump and the tank. When the pressure switch powers off, it unloads the compressor by releasing the air in the discharge hose. You will notice a small tire stem pin and a lever to engage it somewhere on the pressure switch. If the compressor stops before reaching set cutoff point, the air pressure remains in the discharge hose not allowing the motor to start, thus the hum you hear. Solution is to check for the proper function of pressure switch /unloader, tank check valve (if check valve leaks air back to compressor it will load motor causing hum) and extra measure check capacitor for at least 90% of rated valve. Finally, do not run this compressor with an extension cord, use more hose instead. enjoy
Oct 22, 2008 | Coleman CP0302013 20 - Gallon Portable...
Hitachi EC12 Compressor- weird hum
The burst of air you hear as the compressor shuts off is the cylinder unloading so it will not have to restart against a high pressure load. If the unloader is electrical it would explain the hum that you hear. This could be a normal function.
Aug 24, 2008 | Hitachi EC12 Portable Electric 2hp Air...
Air Tools & Compressors Logo
210 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
